Page 85 of 159 1 2 83 84 85 86 87 158 159
Re: Paint job on a budget!? CONTINUED..page 44......... #26138
10/22/06 09:22 PM
10/22/06 09:22 PM
Re: Paint job on a budget!? CONTINUED..page 44......... #26139
10/22/06 09:23 PM
10/22/06 09:23 PM
last
Re: Paint job on a budget!? CONTINUED..page 44......... #26140
10/22/06 09:29 PM
10/22/06 09:29 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Mark, looks great, one thing is your prep work was really good especially since you went with black
Re: Paint job on a budget!? CONTINUED..page 44......... [Re: 69DartGT] #26141
10/22/06 09:45 PM
10/22/06 09:45 PM
Mark,
The paint job does look awesome. If I had known the painting was this easy, and the results would be soooo good, I'd have spent a little more time on prep work and went with black myself on my 280 instead of white. The car didn't really need much. It just sounded too good to be true, so I was skeptical. Now everyone that sees the car don't believe it was a roll on job. Come on everyone, let's see some more...
Re: Paint job on a budget!? CONTINUED..page 44......... #26142
10/24/06 08:51 AM
10/24/06 08:51 AM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Since this is viewed so often I've made it a sticky for awhile
Re: Paint job on a budget!? CONTINUED..page 44......... [Re: 69DartGT] #26143
10/24/06 09:50 AM
10/24/06 09:50 AM
toronto canada
69chargeryeehaa Offline OP
toronto canada
that's why i love this board, the MODS ARE AWESOME!!!!
I posted this same post on thesamba.com, and it was deleted, when a mod said it's the stupidest thing you could do to your car. then here on moparts the thread goes way beyond where i thought it would go. At first i was just looking to share an idea with you guys, one that helped me drive my car without shame, and with good paint without breaking the bank. it's just awesome to see all the sucess stories, all the before and after pictures, i love it. i wonder how many people painted their cars and haven't posted up a pic yet???
it blows me away the quality of work that i'm seeing from people that really have'nt painted any cars before, and with a little elbow grease have a awesome driver, i think all the cars i've seen the the pics look awesome.
Re: Paint job on a budget!? CONTINUED..page 44......... [Re: 69chargeryeehaa] #26144
10/24/06 09:52 AM
10/24/06 09:52 AM
We wanna see Exits work! lol...
Hurry up Exit, we are all waiting
Re: Paint job on a budget!? CONTINUED..page 44......... #26145
10/24/06 10:17 AM
10/24/06 10:17 AM
toronto canada
toronto canada
his cars probabally painted a different color by now lol.
Re: Paint job on a budget!? CONTINUED..page 44......... [Re: 69chargeryeehaa] #26146
10/24/06 10:53 AM
10/24/06 10:53 AM
LOL... you are probably right!
Re: Paint job on a budget!? CONTINUED..page 44......... #26147
10/24/06 10:55 AM
10/24/06 10:55 AM
toronto canada
toronto canada
usually when he goes missing for a day or 2 he comes back with the car a totally different color!!!!
Re: Paint job on a budget!? CONTINUED..page 44......... #26148
10/24/06 07:46 PM
10/24/06 07:46 PM
mark e that gn looks great
Re: Paint job on a budget!? CONTINUED..page 44......... #26149
10/24/06 10:31 PM
10/24/06 10:31 PM
Thanks for the compliments. I had fun doing it and the next one will be better. This thread will probably still be going
Thanks again 69chargeryeehaa
Re: Paint job on a budget!? CONTINUED..page 44......... #26150
10/25/06 04:34 PM
10/25/06 04:34 PM
I also did black on a 88 Honda Accord. Do you have any roller lines in the large areas (hood, roof etc.)? I can see them when I look straight down on mine. Also, I am happy with what I have as I wet sanded and polished, but need to go back and do more wet sanding as I still have more orange peel than I would like and black shows EVERYTHING!
I am also using this car to practice on and I am ordering a Porter Cable 7424 (or from Meguiar's the G100 - same machine) to do the final polishing with as once I have this down I will go to work on my car. This one is my son's! Here is a picture of the finished product.
I will try to get some tomorrow of the side and the hood. Thanks for any help.
Mike
Re: Paint job on a budget!? CONTINUED..page 44......... #26151
10/25/06 06:24 PM
10/25/06 06:24 PM
Here are some shots during the painting process.
The first two are after 5 and 6 coats of paint.
The last one is when finished with wet sanding and polishing.
Re: Paint job on a budget!? CONTINUED..page 44......... #26152
10/25/06 09:35 PM
10/25/06 09:35 PM
Wow that Honda looks great!!! Hi guys im new to the forums and i really joined because of this thread... i come from www.shoforum.com im a muscle car guy but i like 4doors!! Okay currently i went and bought a pontiac lemans fender from the junk yard just so i can try out this method!
so far i have collected the items bellow
Aircraft stripper- removes paint without having to sanding it down.
Miniral spirts-oderless!!!
Bondo- for any sneeky dents i might run in to..
wet/dry sand paper- grit 330-2500
and rustoleum Gloss Black.
and the paint brush/rollers.
Here is how i plan on tackleing the frontier!
Use aircraft stripper and strip the paint off the lemans fender paint.
then fix and dents with bondo and sand down the bondoed areas.
I havent decided if i should use primer or not but i mostlikely wont.
then put my first coat on and wetsand with 330 and each coat i put i will go all the way up to 2500 then i will put another coat over the 2500 grit and polish or should i do 2500 grit then polish without putting a coat over the 2500 grit sanded area??
after that im going to polish with a rotary buffer ( im a semi-pro detailer) and use coats of abrasivep polish/non-abrasive polish and then last end with a high end glaze wax....
what do you think???!
Re: Paint job on a budget!? CONTINUED..page 44......... #26153
10/25/06 11:21 PM
10/25/06 11:21 PM
Another member, all because of this wonderful thread!!! I have questions, could be mostly for 69chargeryeehaa and Marq.
I have a red 1990 240sx. I want to repaint it red. I like painting, always wanted to paint cars, nows my chance. (I don;t count the spray bomb I did on my first 240sx)
I’ve followed the marathon thread of painting a car with a roller. I was set on the tremclad and then I noticed the success with seemingly less work with Brightside.
The reason I was thinking of going with Brightside is because my car is already red. I know its much more involved going from another color to red, more coats etc etc. But since my car is already red and I’m going to go back to the same color I figured this is the way to go. (basically it’s a 1990 that had its rear quarter panels and bumper cover redone from a fender 12 years ago, that aftermarket paint is faded very bad – past the point of saving.)
Unfortunately I won’t be starting this till the next year when I finish my garage, but I may start gathering the supplies now. How many coats would you think I would need to do? I would scuff the whole car obviously, and let the car cure in a hot garage after each coat– or out on the side of the road for the later stages of curing (to make sure no dust gets embedded initially). What are your thoughts on this job, red over red? (my door jambs and crevices are still perfect)
I truly appreciate any feedback, it seems the Brightside way is the way to go for my particular application.
Being in Canada I can get the tremclad easily, has anyone found out after about the Ebay low priced Brightside after???? I've seen people asking but no replies. I might end up painting the car sooner weather depending since I've got my 26x28 pad poured
Sorry for the novel.
Re: Paint job on a budget!? CONTINUED..page 44......... [Re: 69chargeryeehaa] #26154
10/26/06 02:45 PM
10/26/06 02:45 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Yep you guys nailed it. It's my first coat of plutonium green, what do you think?
Really though, I've been in Atlanta since Sunday. I did most of the wetsanding last Friday but I quit halfway through from fatigue and I think I still need to re-sand the areas I did. The orange peel has been tough to get out, and it's everywhere after that spray job.
Re: Paint job on a budget!? CONTINUED..page 44......... [Re: Exit1965] #26155
10/26/06 07:28 PM
10/26/06 07:28 PM
toronto canada
toronto canada
can you scratch it with your fingernail?
Re: Paint job on a budget!? CONTINUED..page 44......... [Re: 69chargeryeehaa] #26156
10/26/06 09:39 PM
10/26/06 09:39 PM
Man I cant beleive this is still alive and well. I've been busy working lately and havent been on for a while. Good to see the posts still keep coming.
Ive got my newest project, an 84 F150. I'll post a picture of the before any bodywork this weekend. I also just finished a 85 F150 4x4 and it turned out great I'll get a pic up of it as well. Painted it Raspberry red (tremclad)
For now here is a pic of the scirocco.
Cheers
Re: Paint job on a budget!? CONTINUED..page 44......... #26157
10/26/06 10:07 PM
10/26/06 10:07 PM
Bakersfield, CA
K
kenzo42 Offline
kenzo42  Offline
K
Bakersfield, CA
This thread is almost at it's limit again of 43 pages.
