Seat Options for 5 point harness #2610753
01/22/19 11:16 PM
01/22/19 11:16 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
What are the options for a street strip car and seats and 5 point racing harness I had purchased the cheap Summit seats and adapted them but I would like a different option
Thoughts?
Pics?
Its for a 68 B Body
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2610761
01/22/19 11:29 PM
01/22/19 11:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Is there a cage/roll bar in use?
How important is comfort?
Are you regular sized?
Do not forget seat mounting, belts hold a driver to/in the seat, if the seat moves any direction in a shunt, the belts become much less effective/restraining, no matter how good or tight the driver WAS wearing them.
Most important driver in my life, is my son, I bought him a containment Racetech seat.
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2610791
01/23/19 12:17 AM
01/23/19 12:17 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I like the aluminum seats. Most guys like Kirkeys. I prefer the Jaz 120-300-03 seat. Smaller, not so huge looking in the car. Comfortable. Easy to mount.
Re: Seat Options for 5 point harness [Re: jcc] #2610816
01/23/19 01:27 AM
01/23/19 01:27 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Good move jcc!
We have a Racetech 4119 seat in the `Cuda as well and installing a custom one in the Challenger build. We like the 119 Series seats due to the ability to back mount them. They are not cheap seats by any means but you get what you pay for. How much is your health and safety worth to you?
Racetech also has a 100 series seats that are more affordable that also has a back mount provision. We are a dealer for them, please email us know if we can help you out thanks!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Seat Options for 5 point harness [Re: RylisPro] #2611005
01/23/19 01:31 PM
01/23/19 01:31 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Good to know up
Is that an air feed black fitting on the lower back on the white seat?
If so, how does it work, is it channeled?
Re: Seat Options for 5 point harness [Re: jcc] #2611037
01/23/19 02:14 PM
01/23/19 02:14 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Yes on the back of 4119 or 9119 seats there is an air duct to hook up a portable fan (or an expensive portable AC unit) to cool down the driver. It is simply a hole that goes through the seat.
Here is the rear of a 9119 carbon/kevlar seat
You can also see the integrated back mount. When tied to the roll cage, the seat is so stiff that you can shake the entire car with it.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2611046
01/23/19 02:32 PM
01/23/19 02:32 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Keep in mind harnesses aren't dot
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2611054
01/23/19 02:44 PM
01/23/19 02:44 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Did you sell the Road Runner?
69 GTX 68 Road Runner
Re: Seat Options for 5 point harness [Re: RylisPro] #2611067
01/23/19 03:01 PM
01/23/19 03:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I assume this is in a road race car. A drag seat would be useless (and dangerous) for you. Different applications will require different seating solutions. A drag car with a roll bar will not use the same set up as a 25.5 or 25.1 chassis. Street car that will be driven miles? Something completely different.
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2611099
01/23/19 03:52 PM
01/23/19 03:52 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Racetech b the good stuff but some people didn't pay that much for their whole car.
2011 Drag Pak Challenger
Re: Seat Options for 5 point harness [Re: CMcAllister] #2611121
01/23/19 04:28 PM
01/23/19 04:28 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
This road race 9119 seat is actually used in drag setups as well. Probably due to its high safety factor and being only 14 lbs.
https://timmcamis.com/shop/racetech-carbon-kevlar.html
Racetech also has a 229 seat for drag cars with a very similar back mount design.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Seat Options for 5 point harness [Re: jcc] #2612701
01/26/19 06:35 PM
01/26/19 06:35 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thanks for the feed
Thanks for the feed back
Comfort is important as it is a street strip car
It has a roll cage cert for 8.50
I am 6 foot and 195 lbs
It is drag race and street oriented, not road race for this car.
1654.5 Mustang
1955 Land Rover
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2612703
01/26/19 06:39 PM
01/26/19 06:39 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
This is the car
And an old pic of the roll cage
1654.5 Mustang
1955 Land Rover
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2612755
01/26/19 08:49 PM
01/26/19 08:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The Racetech seat pictured in FG is comfortable. Its also snug, and offered in a wide version, which you may not need, is also offered in a tall version version, but again, you are right on the edge size wise IMO. I personally have an Alum Custom sized RR containment Kirkey. The Racetech is more comfortable. If car does not have AC, that duct attachment could be useful with just a fan, and could always later add the pricey all in one electrical cooler style. Rollbars with helmets on the street make me nervous, the better the seat restraint, the less chance you have of moving around and contacting a bar with your head, padded or not.
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2612797
01/26/19 10:33 PM
01/26/19 10:33 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
These are what I bought for my 69 GTX street/strip build. Car is not yet finished. I am using 5 point harness.
https://www.stage3motorsports.com/20901W-Corbeau-CR1-Racing-Seat-Wide-Version-Black-Cloth.html
Re: Seat Options for 5 point harness [Re: markz528] #2613011
01/27/19 12:45 PM
01/27/19 12:45 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
How will you run the anti-sub belt with those seats?
Re: Seat Options for 5 point harness [Re: Mattax] #2613211
01/27/19 09:42 PM
01/27/19 09:42 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
The sub belt holes are an option when you buy them so the seats have the holes for the sub belts. I have yet to mount the belts but I have some ideas - looks like there will be adequate room, but it will be tight.
I made custom mounting brackets because the ones I bought were too high.
I can take pics of the seats installed but I wont be home for 2 weeks.
Re: Seat Options for 5 point harness [Re: Mattax] #2613245
01/27/19 10:42 PM
01/27/19 10:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
You can run the crotch belt up from in front of the seat and still be legal at most tracks I've raced on shruggy
I don't recommend doing it that way if you are planning on hitting something hard head on above 45 MPH, sliding your crotch forward three or four inches before hitting that belt may not end up with very pleasant experience whistling work tsk
Re: Seat Options for 5 point harness [Re: Cab_Burge] #2613275
01/27/19 11:39 PM
01/27/19 11:39 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"anti submarine" belts primary purpose in upright seating cars is to keep lap belt from rising ( from the forces acting on the shoulder harness) into your soft venerable stomach area, and over the strongest bone structure in your body, the pelvis. The name is a misnomer, and if your jewels are hurting, you likely have serious other injuries, if you survived.
For clarity, a 3 point OEM belt does not pull up a lap belt in the way a 5/6 belt harness does, and is a different animal in this discussion.
Re: Seat Options for 5 point harness [Re: Kam*Kuda] #2615619
02/01/19 03:53 PM
02/01/19 03:53 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thanks I knew about Kirkey and was concerned that it would be uncomfortable
1654.5 Mustang
1955 Land Rover
