Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2612223
01/25/19 07:31 PM
01/25/19 07:31 PM
Guitar Jones Offline
Not a coincidence. I've seen plenty of bad plug wires that didn't even look bad.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2612239
01/25/19 08:02 PM
01/25/19 08:02 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I'd say that would do it. Crossfire.
Re: Sputter / backfire FiTech fuel injection [Re: John_Kunkel] #2612366
01/26/19 12:32 AM
01/26/19 12:32 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By John_Kunkel
Originally Posted By Supercuda
A backfire fires backward, out the intake. A fart out the tailpipe is a misfire. two completely different problems.
https://en.wikipedia.org/wiki/Back-fire
First sentence says it all.
oh, wikipedia, lol. Wikipedia is only as smart as the last idiot to edit it.
What's next? Snopes?
Don't be the exception.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2612428
01/26/19 03:40 AM
01/26/19 03:40 AM
AndyF Offline
AndyF  Offline
Originally Posted By BDW
Update,
I checked the plug wires and noticed some cracks in the outer rubber.
I had another set, so I replaced them and took the car for a ride.
No backfire and ran great. Coincidence or could that have been it?
Yep that will do it. Bad wires will cause a misfire which dumps raw gas into the hot exhaust system and boom, backfire.
The important lesson is that just because the engine is running poorly doesn't mean the fuel injection is bad. There are lots of things that can go wrong.
Re: Sputter / backfire FiTech fuel injection [Re: Supercuda] #2612832
01/27/19 12:01 AM
01/27/19 12:01 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Other day I got on the gas and it sputtered and seemed to backfire.
Backfired out the exhaust or the intake? IAC reading on the handheld?
Be pretty hard to backfire out the exhaust, that would be a misfire.
back·fire
/ˈbakˌfī(ə)r/Submit
verb
1.
(of an engine) undergo a mistimed explosion in the cylinder or exhaust.
"a car backfired in the road"
synonyms: misfire
"the engine backfired"
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2612907
01/27/19 03:36 AM
01/27/19 03:36 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Cool smile
Re: Sputter / backfire FiTech fuel injection [Re: rumblebee4232] #2613008
01/27/19 12:38 PM
01/27/19 12:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
back·fire
/ˈbakˌfī(ə)r/Submit
verb
1.
synonyms: misfire
Farting out the tail pipe isn't a mistimed issue. It's a no fire issue and some other cylinder's residual exhaust pulse is igniting the air/fuel mixture. As evidenced by the OP's findings.
Coughing out the carb is a mistimed event.
Two different things.
