Page 3 of 3 1 2 3
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: fourgearsavoy] #2610331
01/22/19 11:10 AM
01/22/19 11:10 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted By fourgearsavoy
...and charges 14.6 volts at the battery in the trunk. I used to run an electric water pump and HHR fan with this set-up when I raced the car more.
is not about voltage is about amperes, they are related but diff things. Load is supplied by amperes... and racing is not a problem due the high revs, problem is at iddle
Wiring is very simple and no external regulator to fail up
Gus beer
But internal reg can fail the same wink. Easier to work on an external unit.
Been a Toyota tech for 30 years and a Honda tech for 4 years back in the 80's and have seen MAYBE 3 internal regulators fail so I think the failed regulator is a mute point.
Japanese built Denso alternators might fail in about 200 K
twocents
Is about experiences. I still haven’t got a failed regulator on my 74 Charger in 19 years.
The Bosch alt ( internal reg ) on my parents 75 Mercedes failed once in last 10 years or so.
Both cars being drivers.
What I meant is there is NO LOGICAL REASON to say it won’t fail just because is internal reg. Both can fail the same! But external is easier to test and replace.
Aside in case of emergency you can full field the alt to arrive home being external!
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: BradH] #2610346
01/22/19 11:54 AM
01/22/19 11:54 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not to mention an external regulator can be mounted in a less stressful environment. Seems Mopar put the regulator in the computer and stayed with external regulation.
Don't be the exception.
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: BradH] #2610418
01/22/19 02:24 PM
01/22/19 02:24 PM
AndyF Offline
AndyF  Offline
Originally Posted By BradH
Originally Posted By AndyF
I'm now switching my personal stuff over to low mount alternators since I'm EFI and don't have a fuel pump. I have low mount kits for 90A or 60A Denso alternators. Both would fit with plenty of room in a big block E body car. I doubt that you need 90A in your car so the 60A is probably the way to go.
I don't see the low mount kit on either your or Mancini's web sites. New product?
New product. I have 90A low mount kits in stock but I haven't gotten them boxed up yet for sale. The 60A low mount kit is almost finished, I just need to get the straps powder coated. I'd recommend the 60A kit for your car, especially if you have a full size battery.
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: AndyF] #2610434
01/22/19 02:52 PM
01/22/19 02:52 PM
On a side note, if it goes open (no charging) or full fields (pull a field wire) I would suggest driving home with no charging as opposed to full fielding as max voltage wreakes havoc on the cars' systems cuz they dont like 15+ voltage.
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: BradH] #2610437
01/22/19 02:57 PM
01/22/19 02:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
you can drive with lights on ( including high beams ) and AC or heater at max speed and will release the load and voltage system. Just in case of maximun emergency because your home is 1 hour or so far and your batt could not hold the load. There is a solution or an option anyway being external, imposible to deal being internal.
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: Andrewh] #2610447
01/22/19 03:13 PM
01/22/19 03:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted By Andrewh
more like
https://www.autozone.com/batteries-start...763001_962401_0
odd that 89 shows different. It is still an m-body, but whatever. This is the standard dual field I was talking about.
87 fifth ave does it for me when I look it up.
$12 less at Rockauto.
( search by 7024N PN )
Amazing, they were going on $50 rate quite ago ( remanufactured )
kept searching at Rockauto and found:
PURE ENERGY 7546 $27.89
ACDELCO 3341006 $45.99
REMY 14256 $46.89
Everyone same 78 amps alt, remanufactured, but serpentine belt pulley. Is just about change the pulley and done.
( searched on 86 Charger turbo list )
I bet searching down some other models will get the same
So if we think on the BEST BANG OF THE BUCK as requested... IMHO this is the winner.
EDITING... all these alts are A HAIR WIDER than the stock due the wider stator ( reason why they put more output ). This could be a problem on BBs, but getting a longer belt ( just 1" or 2", can't recall ) is enough to sway the rear of alt from block, and trim a bit the rear spacer to keep the best belt aligment will make the job.
Being there done that
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: BradH] #2610453
01/22/19 03:21 PM
01/22/19 03:21 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
My next bid ( when life allows me to pay for this, on $200 rate ) will be the TuffStuff 8590DP alt
cast finish, 100 amperes double pulley.
Aaand will keep the stock 40 amps ammeter still with this alt. I trust on my Charging system.
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: NachoRT74] #2611343
01/24/19 12:24 AM
01/24/19 12:24 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I'll be honest Nacho, this is a tough call. At night, I'd do it with 37 - but with a higher output alt I don't know. I'm not sure even with everything on the voltage will stay under 15.
Daytime is different. I would definately prefer to run on battery for an hour. Ignition takes so little power - could even jumper the ballast if voltage got really low.
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: NachoRT74] #2611351
01/24/19 12:36 AM
01/24/19 12:36 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Maybe Tuffstuff has become better but I'm not impressed with the one I bought. It had a squeak from the day I bought it. Sent it back forthem to fix and they said it was fine and they returned it to me. Still squeaked. Took it off before a long trip several years ago because I didn't fully trust it.
Fast forward to last year. Needed to replace the alternator quick so reinstalled the Tuffstuff. Squeak only was getting worse. Finally took it off. A little detective work and found the squeak was coming from the brushes???!!!
Yup. Something was on the slip ring that is sticking or grabbing the carbon. down
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: BradH] #2611567
01/24/19 02:44 PM
01/24/19 02:44 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
1.
yes a tough call, but as I told as extreme emergency. You can do it or not, but still have the option. Internal regulator not even the option.
2.
Have got diff feedbacks about tuffstuff alts but latelly they seems to get better.
Which one you got ? I could buy that one from you and maybe fix it ? LOL
Re: Bang-for-the-buck charging system upgrades? '73 E-body [Re: NachoRT74] #2611583
01/24/19 03:07 PM
01/24/19 03:07 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
BTW, thanks for everyone's responses. I still have some things to look into, but you've given me some good ideas on what else can be done. up
Page 3 of 3 1 2 3
