Life expectancy of my red line tires #2610237
01/22/19 01:43 AM
01/22/19 01:43 AM
Buckle of corn belt ,c. lll.
420SIX Offline OP
420SIX  Offline OP
Many of us probably never put on enough miles on some of our cars to wear out a set of tires.
So at what age do you start to worry and junk them ? if stored inside out of the uv spectrum ?
I have a couple sets 20+ years on them....look good... no cracking or dry rot, but I sure think of it when spedo hits triple didgits....I know that is high risk ?
Re: Life expectancy of my red line tires [Re: 420SIX] #2610246
01/22/19 02:09 AM
01/22/19 02:09 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I wouldn't run them at that age no matter how good they look.
Re: Life expectancy of my red line tires [Re: 420SIX] #2610269
01/22/19 03:07 AM
01/22/19 03:07 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Shoot...I wouldn't do 100 mph with a NEW set of those tires!
Re: Life expectancy of my red line tires [Re: Kern Dog] #2610392
01/22/19 01:41 PM
01/22/19 01:41 PM
moparx Offline
moparx  Offline
give 'em to me, and i will dispose of them properly. devil
beer
Re: Life expectancy of my red line tires [Re: Kern Dog] #2610457
01/22/19 03:26 PM
01/22/19 03:26 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
how about 125+?;)
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Life expectancy of my red line tires [Re: 420SIX] #2610496
01/22/19 04:17 PM
01/22/19 04:17 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
We all know of a nasty black Road Runner that's been 140+ with them. I installed mine last year. I did a weekend at Norwalk running 107 mph most runs. I've had the car over 110 multiple times.
Re: Life expectancy of my red line tires [Re: 420SIX] #2610646
01/22/19 08:37 PM
01/22/19 08:37 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
A lot depends on the environmental conditions and how they affect the compounds used in the various layers of the tire but particularly the outer.
After Pikes Peak was fully paved, Jess Neal won the vintage class using a set of original BFG R1. Key was storage environment. Race compounds are even more senstive to environmental heat cycling than normal compounds so this is an unusual case. However it is a good example that age alone is not the only consideration when assessing condition.
Re: Life expectancy of my red line tires [Re: 420SIX] #2610655
01/22/19 08:47 PM
01/22/19 08:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
well, when the tire goes pop and you crawl out to assess the damages then you find out you shouldn't trust your life or your car to 20 year old tires. shruggy
Re: Life expectancy of my red line tires [Re: stumpy] #2610754
01/22/19 11:17 PM
01/22/19 11:17 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
Use your COMMON SENSE....20+ year old tires? Not me! tsk
Plymouth Makes It!
Re: Life expectancy of my red line tires [Re: 420SIX] #2610806
01/23/19 12:49 AM
01/23/19 12:49 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The old tires will be good right up until they are not. The only problem is, that line can change very quickly, you seldom know when it is before hand, and it might only change with one tire, or all of them.
In my best Clint Eastwood voice, "Do you feel lucky today?" Its your car. I prefer not to take the chance. Gene
Re: Life expectancy of my red line tires [Re: 420SIX] #2610968
01/23/19 12:25 PM
01/23/19 12:25 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
As to the old tires no I wouldn’t use them. The new ones at the track the tire really doesn’t see to much heat which is what kills them.
Re: Life expectancy of my red line tires [Re: 420SIX] #2611430
01/24/19 03:47 AM
01/24/19 03:47 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
No need to wonder. There's a test for this.
On a relatively new tire, depress the tread with your thumb and note how pliable and soft it is. This is how a tire should feel.
Repeat this test on old tires in question. If there's a big difference, if hardness and brittleness are detected, the tires are too old. It's time to replace them with new tires no matter how much tread is left and even if there is no visible cracking.
I have a Wide Oval tire that's almost 50 years old, and it's not cracked, probably because it was a spare kept out of sunlight. It's rubber is so hard I could not dismount it myself using a 12-ton press. Had to take it to a tire store.
