Re: 2002 24valve, I need a little more power
[Re: RV2]
#2609392
01/20/19 04:47 PM
01/20/19 04:47 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Do you have an EDGE EZ by chance? They should have been standard and really smarten a stock 02 up.
Sheldon
[Re: RV2]
#2610842
01/23/19 02:04 AM
01/23/19 02:04 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Edge EZ and RV 275 injectors for over 140K now.... I also built a trans with a stock overhaul kit and a Dave Goerend valve body kit and triple disc converter with 250rpm less stall speed. For those others following along, If you have an auto trans even the EZ will run through the stock converter lockup clutch..... I did ..... twice FWIW my 01 long bed 4x4 with trailer loaded is only 17,800 combined.
[Re: J_BODY]
#2610998
01/23/19 01:20 PM
01/23/19 01:20 PM
RUNCHARGER
I stopped at the Edge EZ because it helped it enough for me. I think after that the next stage is injectors. I replaced the exhaust on mine but it didn't do a thing. My son's 01 has a different turbo, manifold, fancy tuner etc. etc. but it isn't necessary I don't think, he just enjoys leaving his Ford buddies in the smoke. If you want lots of power I can find out what all he did if you like.
Sheldon
[Re: RV2]
#2611889
01/25/19 01:27 AM
01/25/19 01:27 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I had a 99 for a few years and an edge EZ was a great add. I think an EZ and some 275 injectors would make a real nice combo.
68 Barracuda Formula S 340
[Re: RV2]
#2623283
02/19/19 01:01 PM
02/19/19 01:01 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
On my '01 automatic I had a Superchips Flashpaq programmer on it. I think it adds about the same power as the Edge EZ. I had it on the truck for 7 years (2011-2018) and was happy with it...big difference over stock. Always left it on the "heavy towing" setting. It really needed a tighter converter, but I never changed it. Pulled my 24' enclosed trailer w/ a 3500 lb car in it pretty well. I'm sure a converter would've made a huge difference.
Sold it this past fall and went Duramax.
[Re: RV2]
#2623600
02/20/19 05:07 AM
02/20/19 05:07 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I have a edge comp box and 100hp injectors, well I did the nozzles in my own injectors. Even with just the injectors, before I installed the comp, it was night and day. Best part of adding 200hp or so was I picked up mpg's. I used to tow almost daily, have to be careful with the egts when going up big hills.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
