Re: DC 590 camshaft comparison
[Re: Hutch]
#2609735
01/21/19 02:54 AM
01/21/19 02:54 AM
Posts: 43,308 Bend,OR USA
Cab_Burge
I remember Dave Wren running a old Cam Dynamics R282 solid roller in his 1971 Cuda 383 SS car in SS/H I think, he let the clutch out around 8000 RPM and tried to shift it between 8600 to 8800 RPM The original Racer Brown that owned that company back in the day probably designed and ground that camshaft for Mopar before they starting opening the doors to the lowest bidders in the early 1980s to the mid 1980s I also remember Joe Alread doing a series of articles on his Mopar sponsored 1972 Road Runner 400 stick car for either Hot Rod or Car Craft magazine in 1972, it had a solid lifter Racer Brown camshaft in it, I'm not sure which grind though My message is there are a lot of better cam grinds to choose from today than back 30 yrs ago
[Re: bobby66]
#2609879
01/21/19 02:36 PM
01/21/19 02:36 PM
Posts: 31,078 Oregon
AndyF
I think AndyF built a long rod 400 with a short piston years ago that did pretty well. Don't think it was 7.100" though. I used Hemi +0.100 rods with off the shelf 1.32 high pistons and a 383 forged crank in a 400 block. It was an off the shelf way to build a high compression 400 back before kits were available. It did work pretty well, that engine made around 600 hp with Porter Racing Head Edelbrock heads. It was a in daily driver Duster that went 10.90 on street tires with full exhaust, full interior, etc. The guy used to drive it to work.
[Re: Hutch]
#2609952
01/21/19 04:50 PM
01/21/19 04:50 PM
fast68plymouth
So. Burlington, Vt.
I shift this between 7500 and 8000 Not sure if any SFT cam change would show a big improvement without taking the time to try a bunch of different ones. Not to mention that most of the fast rate stuff is probably going to require higher spring loads than what std lifters are going to be happy with if you’re trying to buzz the motor 8000.
[Re: Hutch]
#2611203
01/23/19 08:15 PM
01/23/19 08:15 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I have a Direct connection .606 lift cam i going to use in a 340, the duration on these cams will definitely let you wind them up.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: Hutch]
#2614157
01/29/19 05:27 PM
01/29/19 05:27 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you want to go faster, you could tighten the intake lash .010 and see if it likes it. Then try the exhaust. More compression will help as long as you don't have a big dome on the piston. I am geussing you have thrashed it enough to know what it wants for timing. If not back it down a couple first, and see if it helps.
[Re: DblOJoe]
#2615414
02/01/19 01:35 AM
02/01/19 01:35 AM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
It would be nice to see some back to back track testing with some of the newer cams if anyone has done it. "Fading color" cam comparo article was done a few years back on a 421 inch small block, cam manufacturers all took their best shot,and the .590 beat all but one.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
[Re: Hutch]
#2615699
02/01/19 07:47 PM
02/01/19 07:47 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Keith Dunnuck did a cam comparison and a hughes solid cam made 17 hp more than the .590.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Hutch]
#2616190
02/02/19 10:42 PM
02/02/19 10:42 PM
fast68plymouth
So. Burlington, Vt.
Referring to Dunnucks test........ I generally feel that engine builders who work with a lot of the same type of motors often have a good feel for what they like for camshafts.
This proved to be the case in that series of cam tests with the 421 stroker. Dave Hughes had more experience with that type of build than whoever they got on the phone at the other cam suppliers. I felt the Comp cams in particular that were tested were pretty far off from what I would have used. Comp has some really nice lobes available, but what they’re offering for solid flat tappet drag race listings in the catalog leaves a lot to be desired.
[Re: gregsdart]
#2616267
02/03/19 01:31 AM
02/03/19 01:31 AM
Posts: 296 Ontario Canada
Hutch
Ontario Canada
If you want to go faster, you could tighten the intake lash .010 and see if it likes it. Then try the exhaust. More compression will help as long as you don't have a big dome on the piston. I am geussing you have thrashed it enough to know what it wants for timing. If not back it down a couple first, and see if it helps. Did try lashing it to. 024" once cold to be lazy as doing a hot lash makes a mess because these heads don't drain very well. Car lost 2 tenths. If anything it likes the lash a bit loose. Cam is currently retarded 4 degrees also. Tried it 2 degrees advanced, hates that too. Hutch
