Re: 440 Motorhome head swap [Re: toyotajeep] #2610617
01/22/19 07:38 PM
01/22/19 07:38 PM
scratchnfotraction Offline
Originally Posted By toyotajeep
I'm only using these heads because they are in better shape than the other ones. I really am not interested in drilling holes etc. I think it will work with what I have. Kind of practice heads if you will.
There are indeed some differences between these heads and the regular ones. I have to use different plugs etc. but it is mildly inconvenient.
No machining. Just going to run them as is.
that's what I did 20,000 miles ago. but I added the whiplash cam/lifters/springs when I swapped heads out for fresh VJ on the car set. I have the MH#452 with fresh VJ for my 78 new Yorker 440 = I need to look what heads it has now.
use what you got even if it is a 318...LOL!
Re: 440 Motorhome head swap [Re: toyotajeep] #2610679
01/22/19 09:19 PM
01/22/19 09:19 PM
Southern Oregon
toyotajeep Offline OP
Southern Oregon
I'm basically building a mild 440 and doing the rest of the car up pretty well for more HP and I will likely build a better engine later once the car gets sorted.
1989 Dodge Cummins & 1989 Dodge W-250
Re: 440 Motorhome head swap [Re: toyotajeep] #2610739
01/22/19 10:55 PM
01/22/19 10:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My recollection is that the old Paul Rossi Street Fighter heads were made from the motor home heads.
Re: 440 Motorhome head swap [Re: fast68plymouth] #2610855
01/23/19 02:40 AM
01/23/19 02:40 AM
So where the Herb McCandless street and strip ported 452 race heads, I think work
Re: 440 Motorhome head swap [Re: Cab_Burge] #2614080
01/29/19 03:34 PM
01/29/19 03:34 PM
dogdays Offline
dogdays  Offline
Steel shim gaskets leak? Not if the heads and block are flat. AFAIK exactly NO B or RB engine came out of the factory with anything but steel shim gaskets. The same with all V8s until maybe the early to mid 80s, when I believe the LA started using composition gaskets, which prompted the reduction in block deck height from 9.600" to 9.577". Shoot, the intake gaskets on my Poly motor were steel shim! As were the exhaust pipe gaskets.
Look in the factory service manual and see if they recommend spraying or brushing any goop on those steel shims. I bet they don't. If they do, copy the page and post it because I want to see it.
To my way of thinking, adding Copper Coat or Hi-Tack or aluminum paint before installing the gasket puts two slippery layers between the gasket and the block or head. The gasket is coated with what the gasket manufacturer wanted to be there.
Back in the day, when Chrysler was forever quitting big block engines, they sold 452 heads for insane prices, like $45 each. The 452 head, like all big block heads since the 346, has an intake port that is easier to work especially when installing larger valves. So people started reworking them. They also had hardened exhaust seat areas and some thought the entire chamber was hardened.
Anyway, the most magical thing about the 452 heads was the fact that they were available brand new by the pallet load for insanely low prices.
If you are looking for a 452 head to port, keep your eyes open for the heads with the numeral "!" cast into the end of the head. These heads were a revision and would have had their own casting number except that Chrysler had already made the decision to quit making big blocks. So the heads got thicker ports and maybe slightly better contours.
R.
