Re: N.o.s or 4.10 gears?
[Re: Crabra]
#2606892
01/15/19 01:18 PM
01/15/19 01:18 PM
Posts: 4,209 New York
polyspheric
New York
Which axle do you have, 8-1/4"? Don't invest in it. Nitrous will have far greater results.
Boffin Emeritus
[Re: Crabra]
#2606982
01/15/19 03:55 PM
01/15/19 03:55 PM
Posts: 4,689 On the parachute mount
n20mstr
Shoot it,
you will be amazed at what a little .052 nitrous jet will do. Probably get 3-5 passes out of a bottle also.
....BAD A$$ STREET CAR.....
[Re: Crabra]
#2606984
01/15/19 03:59 PM
01/15/19 03:59 PM
Posts: 11,639 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Gears are a one time expense and install deal. Nitrous needs to have the bottle(s) refilled constantly. What is N2O now? $5/lb?
Is this car street driven? Saving your pennies for a decent 360 or similar upgrade may be the best route.
Getting weight out of the car is the easiest, cheapest way to make it go faster.
[Re: CMcAllister]
#2606989
01/15/19 04:04 PM
01/15/19 04:04 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How about lever C. Buy a running 360 and upgrade the cam slightly.
[Re: Crabra]
#2606994
01/15/19 04:14 PM
01/15/19 04:14 PM
Posts: 20,200 Park Forest, IL
slantzilla
Park Forest, IL
What is your objective?
I can tell you from experience that trying to bracket race with spray is a lot of work. Can it be consistent? Yes, but you have to keep really good control of bottle temp and pressure. Not easy to do on a hot day, especially if you get stuck in the lanes by an oil down or such. If it's cold out that brings on another bunch of fun.
Going from 3.55 to 4.10 will not pick you up as much as you'd think.
Another vote for a 360.
[Re: slantzilla]
#2606998
01/15/19 04:21 PM
01/15/19 04:21 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
Another vote for a 360. I sold a 4 speed Duster to a friend, it had 3.55 posi third member in it,we swap in a posi 4.89 gears third member, it made that car FEEL a lot faster but it didn't make much ET or MPH difference in the 1/4 mile It picked up from 14.5s to 14.20 to 14.30sET If you want to go faster try a better converter and focus on making more power
[Re: Crabra]
#2607048
01/15/19 05:54 PM
01/15/19 05:54 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
Like has been said already, the gear change won't get you much. The 100 shot will pick it up a LOT and be a helluva lot of fun. Definitely the best bang for the buck. Bracket racing it w/ the nitrous may or may not be for you.
[Re: an8sec70cuda]
#2607054
01/15/19 06:13 PM
01/15/19 06:13 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Like has been said already, the gear change won't get you much. The 100 shot will pick it up a LOT and be a helluva lot of fun. Definitely the best bang for the buck. Bracket racing it w/ the nitrous may or may not be for you. But it cost money EVERY time you push the button. Not needed to pick up how much ET he would be happy with.
[Re: Crabra]
#2607086
01/15/19 07:08 PM
01/15/19 07:08 PM
an8sec70cuda
I understand what you're saying John, but he gave us 2 options he's looking at and he's obviously on a budget.
[Re: Crabra]
#2607106
01/15/19 07:35 PM
01/15/19 07:35 PM
Posts: 570 UK
rb446
UK
All depends on how much you want to pick up from 15.6's, assuming your@say 3400lbs all in your making around 175fwhp not knowing your mph..86>87mph?. Adding a 100>125 shot could take you to 13.5's@99>100mph. It will be almost like going to 4.10's with your 3.55's with the added torque of N20 and will lower your 60's as long as you still hook and be the biggest gain you will get for minimal cost/effort over going the NA route.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Crabra]
#2607172
01/15/19 09:22 PM
01/15/19 09:22 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Set of cleaned up 360 or J heads, 4 bbl, intake and a little cam would pick it way up. Converter would be a big help too. Either of the two options are $400 - 500. Pretty good start on other options.
