Re: best way to increase hp in my 318?
[Re: Moparmad]
#2606732
01/15/19 01:00 AM
01/15/19 01:00 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A magnum 318 would be a cam and intake swap. An LA 318 like the one you spec? Here's one build but I don';t think the 302 heads are a solution unless that's what you already have. I'd swap magnums on before I spent a nickle on 302 heads.
[Re: Moparmad]
#2606749
01/15/19 01:32 AM
01/15/19 01:32 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
There is a hotrod mag or some mopar mag link with an article about building a 400hp 318 with parts out of the box.
[Re: Moparmad]
#2606756
01/15/19 01:55 AM
01/15/19 01:55 AM
Supercuda
About to go away
About to go away
up yours
Not sure where in Texas you are basing you humidity comment on, but Texas is a big place and yeah in Houston or eat of I 35 humidity is bad, You get out closer El Paso and not so. Or up in the panhandle.
[Re: Supercuda]
#2606763
01/15/19 02:08 AM
01/15/19 02:08 AM
RapidRobert
I would dial in the timing & the carb then later some EQ mag heads & you can reuse em when you on down the line swap in a stroked 360 (408). 4" cranks are cheap now & the KB pistons ain't too bad.
[Re: NachoRT74]
#2606767
01/15/19 02:33 AM
01/15/19 02:33 AM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
There is a hotrod mag or some mopar mag link with an article about building a 400hp 318 with parts out of the box. That was Mopar Action. Did they use a magnum block? Either way it would be worth copying.
[Re: Montclaire]
#2606908
01/15/19 01:44 PM
01/15/19 01:44 PM
NachoRT74
Valencia, España
There is a hotrod mag or some mopar mag link with an article about building a 400hp 318 with parts out of the box. That was Mopar Action. Did they use a magnum block? Either way it would be worth copying. found this: https://www.hotrod.com/articles/mopp-0409-318-engine-build/Old LA. But I was sure it was a diff article unless the article face was refreshed
[Re: Moparmad]
#2606931
01/15/19 02:17 PM
01/15/19 02:17 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Easiest?
Probably a magnum style top end and a cam in the 220’s@.050, .470-.500 lift.
It’s likely going lose some grunt in that configuration........ you could shorten the duration up a bit to get some of it back.
Something like a Comp 268H should be plenty to get you well into the 300’s with a magnum style top end.
“Cheaper”(possibly) but less powerful....... put 1.88 intake valves in the current heads along with some mild porting, Comp 268XE cam.
[Re: Moparmad]
#2606970
01/15/19 03:33 PM
01/15/19 03:33 PM
Posts: 735 Pa. U.S.A.
moparborn
Pa. U.S.A.
To get 400 HP out of that 318, you are going to have to up your compression. Get a set of closed chamber heads(low cc),thin head gaskets, .022 range. A good cam,480-500 range. Performer style intake. Headers. A turbo or blower set up will get you there but it will be at higher price.
[Re: Twostick]
#2607083
01/15/19 07:01 PM
01/15/19 07:01 PM
BradH
The usual bolt ons and spray the wee out of it.
Kevin Yeah, I was thinking the N2O approach, too. But it wouldn't be my pile of broken parts if I couldn't get a handle on the tune.
[Re: Moparmad]
#2607169
01/15/19 09:17 PM
01/15/19 09:17 PM
fast68plymouth
So. Burlington, Vt.
275-300-ish out if a 318 really isn’t that hard........ then it’s just a 100 shot.
[Re: 5thAve]
#2607264
01/15/19 11:57 PM
01/15/19 11:57 PM
Supercuda
About to go away
About to go away
up yours
400hp isn't that realistic. If you're going to spend that much time and money on a 318 you might as well spend a bit more and start over with a 360. I think you could make a good case for it being cheaper to get 400 hp out of a 360 than a 318, even factoring in a core 360.
