Re: Is Boost the same IF [Re: hemi-itis] #2606164
01/13/19 10:13 PM
01/13/19 10:13 PM
Great Neck,LI,new york
hemi-itis Offline OP
Went from 3% OD to 5% od the AFR dropped almost a full point.What would be the target AFR at WOT?? Timing was at 26* and dropped to 24* at 2500 RPM.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Is Boost the same IF [Re: hemi-itis] #2606165
01/13/19 10:13 PM
01/13/19 10:13 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
In the immortal words of Monte Smith. You can't burn through anything without fuel. Lean won't hurt anything as long as it doesn't have to much timing. I asked Dick Lahaie once. "how much fuel do you dedicate to cooling the charge?" He answered "none, we burn it all"
Doug
Re: Is Boost the same IF [Re: hemi-itis] #2606177
01/13/19 10:36 PM
01/13/19 10:36 PM
So when I increase boost and octane,will it want more timing??
Re: Is Boost the same IF [Re: hemi-itis] #2606189
01/13/19 11:01 PM
01/13/19 11:01 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The more boost, the less timing you want. The higher the intake temp, the more timing you take out.
Re: Is Boost the same IF [Re: hemi-itis] #2606196
01/13/19 11:14 PM
01/13/19 11:14 PM
So the add'l octane is just for the increased effective CR?
Re: Is Boost the same IF [Re: hemi-itis] #2606201
01/13/19 11:22 PM
01/13/19 11:22 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Put the timing down to 20*
Re: Is Boost the same IF [Re: FastmOp] #2606208
01/13/19 11:37 PM
01/13/19 11:37 PM
With the ability of changing the timing every 500 RPM should I curve it or flatline it??
Re: Is Boost the same IF [Re: hemi-itis] #2606235
01/14/19 12:36 AM
01/14/19 12:36 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
You can run it high until it makes boost. My junk has 36 degrees but ramps down as it makes boost.
Re: Is Boost the same IF [Re: hemi-itis] #2606249
01/14/19 12:52 AM
01/14/19 12:52 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A real timing curve is 3 dimensional. Timing should increase with rising rpm, and decrease with rising boost. It should be done on a dyno for best results.
Re: Is Boost the same IF [Re: TRENDZ] #2606257
01/14/19 01:16 AM
01/14/19 01:16 AM
This is the what I have been working on and you have given me the key.From zero to 500 rpm is 18* ramping up to 34* @ 1k RPM,,then at 2500 it is ramped to 26* by 3500.Full boost is in by 4k and rises a tad over 6500.
Now to combine the run curve with the boost retard..... boogie
Re: Is Boost the same IF [Re: hemi-itis] #2606261
01/14/19 01:24 AM
01/14/19 01:24 AM
Will the MSD 6al-2 display timing settings on the laptop while on a chassis dyno?
https://www.holley.com/products/ignition/ignition_boxes/street_and_strip/parts/6530
Re: Is Boost the same IF [Re: hemi-itis] #2606301
01/14/19 03:02 AM
01/14/19 03:02 AM
How much are grids now?
On the only iron block aluminum headed blown pump gas Hemi motor I dyno tuned on a DTS engine dyno like 33 degrees all in at 2500 RPM up to 7300 RPM where that motor made peak HP of 924 HP with 7.0 lbs of boost work That was with 12% underdrive.
We swapped the pulleys and fuel from CA 91 octane pump swill to 116 race gas and up the overdrive to 13% which ended up making 12 Lbs. of boost at 6500 RPM with 25 degrees total timing , that motor didn't like that much lead at 6500 RPM which made 1027 HP down It started to go into detonation and the manifold inlet temps had gone from 130 F to 190 F at 6500 RPM shock shruggy
We stop the test after that pull as the customer car wasn't going to hook 924 HP let alone above 1000 HP on the street shruggy
Re: Is Boost the same IF [Re: hemi-itis] #2606377
01/14/19 12:13 PM
01/14/19 12:13 PM
Cab,that had to to have a static CR under 8:1.Now I am at 9:1,4.385 bore and 4.5 stroke @ 3700 lbs.Old fueler heads by Sanchez.
On 92 pump after 5 passes with timing changes only at 1000/1100 DA 26* was the best MPH of 140mph and 9.4.
For idle and cruise I can see staying in the 30 to 32 range.Next time out I will ramp down to 20* by 3500 rpm and get the afr's up into the 12's.
Also want to thank you guys for clearing up my thoughts and putting me back in the right state of mind! bow beer
My goal is 8.50 in good air and anywhere in the 8's in the heat.
Re: Is Boost the same IF [Re: hemi-itis] #2606388
01/14/19 12:46 PM
01/14/19 12:46 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think that chart is Procharger bragging that they can give you more usable boost because the Procharger heats the intake charge less than a Roots.
2011 Drag Pak Challenger
