Re: Is Boost the same IF
[Re: hemi-itis]
#2606164
01/13/19 10:13 PM
01/13/19 10:13 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Went from 3% OD to 5% od the AFR dropped almost a full point.What would be the target AFR at WOT?? Timing was at 26* and dropped to 24* at 2500 RPM.
[Re: hemi-itis]
#2606189
01/13/19 11:01 PM
01/13/19 11:01 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The more boost, the less timing you want. The higher the intake temp, the more timing you take out.
[Re: FastmOp]
#2606208
01/13/19 11:37 PM
01/13/19 11:37 PM
hemi-itis
Put the timing down to 20* With the ability of changing the timing every 500 RPM should I curve it or flatline it??
[Re: hemi-itis]
#2606249
01/14/19 12:52 AM
01/14/19 12:52 AM
TRENDZ
Milwaukee WI
A real timing curve is 3 dimensional. Timing should increase with rising rpm, and decrease with rising boost. It should be done on a dyno for best results.
[Re: TRENDZ]
#2606257
01/14/19 01:16 AM
01/14/19 01:16 AM
hemi-itis
A real timing curve is 3 dimensional. Timing should increase with rising rpm, and decrease with rising boost. It should be done on a dyno for best results. This is the what I have been working on and you have given me the key.From zero to 500 rpm is 18* ramping up to 34* @ 1k RPM,,then at 2500 it is ramped to 26* by 3500.Full boost is in by 4k and rises a tad over 6500. Now to combine the run curve with the boost retard.....
[Re: hemi-itis]
#2606301
01/14/19 03:02 AM
01/14/19 03:02 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
How much are grids now? On the only iron block aluminum headed blown pump gas Hemi motor I dyno tuned on a DTS engine dyno like 33 degrees all in at 2500 RPM up to 7300 RPM where that motor made peak HP of 924 HP with 7.0 lbs of boost That was with 12% underdrive. We swapped the pulleys and fuel from CA 91 octane pump swill to 116 race gas and up the overdrive to 13% which ended up making 12 Lbs. of boost at 6500 RPM with 25 degrees total timing , that motor didn't like that much lead at 6500 RPM which made 1027 HP It started to go into detonation and the manifold inlet temps had gone from 130 F to 190 F at 6500 RPM We stop the test after that pull as the customer car wasn't going to hook 924 HP let alone above 1000 HP on the street
[Re: hemi-itis]
#2606377
01/14/19 12:13 PM
01/14/19 12:13 PM
hemi-itis
Cab,that had to to have a static CR under 8:1.Now I am at 9:1,4.385 bore and 4.5 stroke @ 3700 lbs.Old fueler heads by Sanchez. On 92 pump after 5 passes with timing changes only at 1000/1100 DA 26* was the best MPH of 140mph and 9.4. For idle and cruise I can see staying in the 30 to 32 range.Next time out I will ramp down to 20* by 3500 rpm and get the afr's up into the 12's. Also want to thank you guys for clearing up my thoughts and putting me back in the right state of mind! My goal is 8.50 in good air and anywhere in the 8's in the heat.
[Re: hemi-itis]
#2606388
01/14/19 12:46 PM
01/14/19 12:46 PM
Posts: 2,636 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I think that chart is Procharger bragging that they can give you more usable boost because the Procharger heats the intake charge less than a Roots.
2011 Drag Pak Challenger
