Re: A stock car flaming with a loser at the cruise control!
[Re: chargervert]
#2602285
01/06/19 01:44 AM
01/06/19 01:44 AM
Posts: 15,996 RI Deep in the rust belt
chargervert
Today I ordered an aluminum waterpump housing,with a high volume waterpump,and a billet thermostat housing,and a billet rear main seal kit from Mancini Racing for the Hemi. I also found out that my 10 millimeter spark plug wires were shipped today.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#2604210
01/10/19 12:38 AM
01/10/19 12:38 AM
chargervert
Who said that Christmas was over! ,I musta been a good boy this year, because my gifts just keep on coming! The gifts will keep coming too,atleast until my bank account is empty! Lol I got my 10 mm Live wires from Steve Davis, and the high volume aluminum water pump, and housing, and the billet water neck too. I also got the billet rear main seal kit too.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#2604213
01/10/19 12:41 AM
01/10/19 12:41 AM
chargervert
I also ordered a mimi starter too. I still have to order a MSD coil, a fuel pump block off plate, and the March serpentine belt pulley set up for the Hemi!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#2606393
01/14/19 12:50 PM
01/14/19 12:50 PM
chargervert
I just got the mini starter for the Hemi!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#2608567
01/18/19 02:01 PM
01/18/19 02:01 PM
Posts: 165 n.h.
ricks_RR
n.h.
[Re: ricks_RR]
#2635558
03/22/19 12:12 PM
03/22/19 12:12 PM
chargervert
I know that I have not updated the thread lately, but it looks like the weather is finally breaking and spring is here, so I am hoping to get back out in the garage and get back to work on the car. I did go to the machine shop the other day to check on the progress of my Hemi engine and he has not started on it yet. This would have been a bad thing, but unfortunately I had an incident with my truck that caused me to have to use some of the funds I had put aside for the Hemi build. A blowout on the left front tire of my diesel Ram,to re out the plastic inner wheel well and the three feet of tread that peeled off the tire tore out the fuse box and wiring harness, basically destroying an otherwise bulletproof truck! While I plan on getting it repaired and back on the road, I had to buy another truck. So the delay at the machine shop has allowed me to almost completely put the funds back together to continue with the Hemi engine build. Keep in mind that if you have a Dodge ram that a blow out on either front tire can completely disable your vehicle. The computer is on the right side, and the fuse box is on the left side. The plastic wheel well will not protect those components in the event of a blowout. I was going 65 mph on the highway when it happened and fortunately no one was injured.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#2635574
03/22/19 12:57 PM
03/22/19 12:57 PM
chargervert
Unfortunately for me, I kinda caused my own problem with this one by taking my new wheels and tires off for the winter, and putting the old ones back on. They were only 4 years old, but it failed badly. The wiring harness is no longer available from Mopar, so I had to source a used one.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#2635577
03/22/19 01:05 PM
03/22/19 01:05 PM
chargervert
Here are my new wheels and tires from a 2018 Ram that bought last fall resting comfortably in the garage! I tried to protect them from the harsh winter elements of New England . I would have been better off just leaving them on the truck! I thought I was doing the right thing, oh well! Anyway this is my new to me truck. I hope to send the diesel Ram to the auto electric shop next week. Hopefully the next installment of this thread will get back to the racecar!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
