727 transmission pan gasket #2603737
01/09/19 02:28 AM
01/09/19 02:28 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Is the fel pro Tos18583 727 a good gasket that seals good? Whats some good 727 transmission pan gaskets?
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2603768
01/09/19 04:08 AM
01/09/19 04:08 AM
5thAve Offline
5thAve  Offline
Im using the oem mopar reusable one. Don't know the part number but any dealer parts dept. should know what it is.
I've never had a problem with any gasket name brand or not as long as the pan is flat.
Re: 727 transmission pan gasket [Re: 5thAve] #2603794
01/09/19 10:19 AM
01/09/19 10:19 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Same here, have used it for many years and have reused it a handful of times without any issues. I think its Part Number 4295875AC but I'm not 100% certain.
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2603841
01/09/19 12:37 PM
01/09/19 12:37 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I wanted the cork look for the resto, but also wanted a metal core to ensure it would stay put. I ended up with a Mahle gasket. Like this one.
https://www.jegs.com/i/Clevite-MAHLE/695/W39003TC/10002/-1?ymm=4294829710+4294829634+4294828937
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2603957
01/09/19 04:09 PM
01/09/19 04:09 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
If you are in Vegas, call Natpro, Part #22170LR. They have them in stock.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 727 transmission pan gasket [Re: DusterKid] #2603972
01/09/19 04:46 PM
01/09/19 04:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By DusterKid
[quote=5thAve] I think its Part Number 4295875AC but I'm not 100% certain.
That's the 904 number, 727 is 2464324AC
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2604163
01/09/19 11:13 PM
01/09/19 11:13 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Moroso blue with steel core. Best valve cover gaskets I've ever used, and it's the same design for the trans pans.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2604186
01/09/19 11:52 PM
01/09/19 11:52 PM
tucson az
frank Offline
frank  Offline
tucson az
I like the oem reusable gasket. Never had a problem with that. Others, I've had a few leaks over time
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2605016
01/11/19 05:01 PM
01/11/19 05:01 PM
crlush Offline
crlush  Offline
Get one from a 48re its plastic with orings, been using the same one for 14 yrs, with many filter changes.
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2606312
01/14/19 05:19 AM
01/14/19 05:19 AM
las vegas,nv
las vegas,nv
Im goin to try this felpro gasket i got free i had a gift card to autozone.this felpro gasket is made out of same gasket material like mopar performance one is.
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2606316
01/14/19 05:57 AM
01/14/19 05:57 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I think that ANY decent quality pan gasket will work just fine ..., in my experience- most leaks are the result of a distorted pan rail and/or the over tightening of the pan bolts.
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2606504
01/14/19 04:25 PM
01/14/19 04:25 PM
las vegas,nv
las vegas,nv
Yah I see.if it continues to leak I'll get the gasket from dealer like people are sayin and maybe a new pan.
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2665504
06/13/19 01:20 PM
06/13/19 01:20 PM
las vegas,nv
las vegas,nv
If you the dealer type gasket do you use any gasket sealer with it? Has anyone used the mopar performance gasket which is part#3960855
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2665510
06/13/19 01:24 PM
06/13/19 01:24 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Make sure the bolt holes are clean from any left over sealer. Debris in the holes will keep the bolt from tightening the pan down properly. I had a issue with leaks and it was because of that.
Re: 727 transmission pan gasket [Re: mopar muscle7271] #2665541
06/13/19 03:00 PM
06/13/19 03:00 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by mopar muscle7271
If you the dealer type gasket do you use any gasket with it? Has anyone used the mopar performance gasket which is part#3960855
No, use the dealer gasket by itself. No sealer either.
As previously mentioned - with ANY gasket the pan has to have a flat flange.
Spend time on a flat surface plate and get the pan rail flat using a punch a little larger than the pan bolt hole size.
Lay the pan flange down, tap the hole flat. Check every hole.
Then flip it over and use a long straight edge to make sure the flange and those bolt holes are all flat.
Make sure every bolt hole in the case is clean with no debris in them.
Hand screw a bolt in each hole and make sure they go all the way in to the washer - I’ve seen guys chasing leaks to find out the bolt was too long, or the case had garbage in the hole.
