Page 2 of 4 1 2 3 4
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603878
01/09/19 01:57 PM
01/09/19 01:57 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
OE 9" center sections are not adequate for any decent power level or abuse. And stock housings are kind of flimsy as well.
Gear ratio options, aftermarket support and development, ease of maintenance, all steel housing, strength with proper prep, all favor the 9.
If I were doing a Mopar for a reasonably close to stock chassis, leaf spring, street/strip deal, where the ratio doesn't need to be dialed in exactly right and where I didn't want to spend 5K, I would use a 60.
Race car, tube chassis or back halfed, narrow 4 link, busy and/or fabricated housing with lots of stuff on it, need to be kept light, need to dial the ratio in, 9" all day long.
Somewhere in between? Depends.
It's not so much one is better than the other, but depending on the intended application, one or the other will probably be a better choice.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603896
01/09/19 02:25 PM
01/09/19 02:25 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
This is a B S question because there is "always more to it". Sounds like you want a Dana, put a Dana in it.
"Just a Bracket car dressed up like a streetcar"
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603964
01/09/19 04:22 PM
01/09/19 04:22 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You could always upgrade to a Dana 70, housing is the same size as a 60 and you get a 10.5" ring gear and you can get gears from 3.55 to into the 7.17 gear ratio...stolen from Jantz engineering
Your Ring & Pinion is 33% stronger with no loss of ground clearance.
Dana rates the 60 @ 6000 Ft-lbs maximum momentary output torque. 35 spl HD.
Dana rates the 70 @ 8000 Ft-lbs maximum momentary output torque. Non HD.
That's a 2000 ft-lb increase in capacity.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: D-60 vs 9"....here we go again.... [Re: CMcAllister] #2603971
01/09/19 04:45 PM
01/09/19 04:45 PM
dogdays Offline
dogdays  Offline
Here's another way of looking at it.....
Back in the day, Ford half-tons used 9" rears. Back in the day, Ford 3/4 tons used Dana 60s.
R.
Re: D-60 vs 9"....here we go again.... [Re: dogdays] #2603977
01/09/19 04:52 PM
01/09/19 04:52 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
R.
Years ago 12 bolt chevies were popular in stock and super stock. Not sure what they prefer now.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2603978
01/09/19 04:53 PM
01/09/19 04:53 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
this is what makes MOPARTS.....LMAO
Who really cares, they both strong, they both have their place....
Personally, id never put a DANA, its a dump truck rear...LMFAO !
Flame on !!!
....BAD A$$ STREET CAR.....
Re: D-60 vs 9"....here we go again.... [Re: pittsburghracer] #2604017
01/09/19 06:11 PM
01/09/19 06:11 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
R.
Isn’t the 9/12 the one to use now? 9” housing with a 12 bolt chevy ring and pinion.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604022
01/09/19 06:20 PM
01/09/19 06:20 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
12 bolt for 9”...
Re: D-60 vs 9"....here we go again.... [Re: TRENDZ] #2604041
01/09/19 06:59 PM
01/09/19 06:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
R.
IIRC the 12 bolt was the most efficient of the popular rear ends.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604055
01/09/19 07:24 PM
01/09/19 07:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Stockers have to use a corporate rear, so for GM cars it's a 12 Bolt for them. Some still use the 8.5. Mopars will use a 8.75 or a 60.
Super Stock can use whatever. I don't know of anyone who's used a 60 in an AH car for many years. The 12 Bolt center section is typically a lightweight car or a Comp deal where the last ounce of efficiency matters and frequent maintenance is part of the drill.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604061
01/09/19 07:35 PM
01/09/19 07:35 PM
Martinsville, IN
cdwmotorsports Offline
Happy Birthday cdwmotorsports  Offline
Martinsville, IN
Also isn’t the Ford 8.8 stronger than a 9”
eBay-cdwmotorsports
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604070
01/09/19 07:50 PM
01/09/19 07:50 PM
Guitar Jones Offline
One thing to consider is the chassis it's going in. A 9" will allow you a narrower chassis in a tube car for more tire clearance than the 60 will.
Re: D-60 vs 9"....here we go again.... [Re: astjp2] #2604241
01/10/19 01:34 AM
01/10/19 01:34 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I had to check - out of curiosity. A 70 is 60lb. heavier than a 60. eek
Re: D-60 vs 9"....here we go again.... [Re: CMcAllister] #2604319
01/10/19 10:04 AM
01/10/19 10:04 AM
Martinsville, IN
Martinsville, IN
The housing of a 70 is 60lbs heavier or the entire assembly? I would think its the entire assembly and mostly concentrated in the brakes.
eBay-cdwmotorsports
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604332
01/10/19 11:17 AM
01/10/19 11:17 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Passenger car D 60s have thinner wall tubing than Ford truck D 60s. Floater style Dana axles have very thick wall tubes. All 70s are floaters, so the tubing is very thick. It doesn’t seem to far fetched that a 70 could be 60lbs heavier without axle ends/ brakes.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604470
01/10/19 04:00 PM
01/10/19 04:00 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Since some think 6000 ft lb strength is not enough, and a dana 70 is too heavy, it is, you can put a dana 70 ring and pinion in a 60 housing. Stronger than a 60 and lighter than a 70. Jantz engineering shows you how.
Re: D-60 vs 9"....here we go again.... [Re: hemienvy] #2604475
01/10/19 04:08 PM
01/10/19 04:08 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Does anybody know the weight difference between a S-60 and 9" with an aluminum center section?
Every thing else being the same ie axles (35 spline axles) spool, axle tubes, axle ends.
Re: D-60 vs 9"....here we go again.... [Re: TRENDZ] #2604491
01/10/19 04:46 PM
01/10/19 04:46 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Comparing images, it looks like a lot of it is in the center section of the housing. Can't see a 70 as a good option for a race car.
Re: D-60 vs 9"....here we go again.... [Re: Biginchmopar] #2604493
01/10/19 04:52 PM
01/10/19 04:52 PM
Me thinks the 40 spline axles gun drill lightweight option are a better choice for both rear ends work twocents
Re: D-60 vs 9"....here we go again.... [Re: Cab_Burge] #2604532
01/10/19 05:49 PM
01/10/19 05:49 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
this is what I was told as well . And I can tell you first-hand a 40 spline with a big gun drill. Was lighter than my 31-spline that wasn't drilled
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Page 2 of 4 1 2 3 4
