Re: D-60 vs 9"....here we go again....
[Re: hemienvy]
#2603878
01/09/19 01:57 PM
01/09/19 01:57 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
OE 9" center sections are not adequate for any decent power level or abuse. And stock housings are kind of flimsy as well.
Gear ratio options, aftermarket support and development, ease of maintenance, all steel housing, strength with proper prep, all favor the 9.
If I were doing a Mopar for a reasonably close to stock chassis, leaf spring, street/strip deal, where the ratio doesn't need to be dialed in exactly right and where I didn't want to spend 5K, I would use a 60.
Race car, tube chassis or back halfed, narrow 4 link, busy and/or fabricated housing with lots of stuff on it, need to be kept light, need to dial the ratio in, 9" all day long.
Somewhere in between? Depends.
It's not so much one is better than the other, but depending on the intended application, one or the other will probably be a better choice.
[Re: hemienvy]
#2603896
01/09/19 02:25 PM
01/09/19 02:25 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
This is a B S question because there is "always more to it". Sounds like you want a Dana, put a Dana in it.
"Just a Bracket car dressed up like a streetcar"
[Re: hemienvy]
#2603964
01/09/19 04:22 PM
01/09/19 04:22 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
You could always upgrade to a Dana 70, housing is the same size as a 60 and you get a 10.5" ring gear and you can get gears from 3.55 to into the 7.17 gear ratio...stolen from Jantz engineering
Your Ring & Pinion is 33% stronger with no loss of ground clearance.
Dana rates the 60 @ 6000 Ft-lbs maximum momentary output torque. 35 spl HD.
Dana rates the 70 @ 8000 Ft-lbs maximum momentary output torque. Non HD.
That's a 2000 ft-lb increase in capacity.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: dogdays]
#2603977
01/09/19 04:52 PM
01/09/19 04:52 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Here's another way of looking at it.....
Back in the day, Ford half-tons used 9" rears. Back in the day, Ford 3/4 tons used Dana 60s.
R. Years ago 12 bolt chevies were popular in stock and super stock. Not sure what they prefer now.
[Re: hemienvy]
#2603978
01/09/19 04:53 PM
01/09/19 04:53 PM
Posts: 4,688 On the parachute mount
n20mstr
this is what makes MOPARTS.....LMAO
Who really cares, they both strong, they both have their place....
Personally, id never put a DANA, its a dump truck rear...LMFAO !
Flame on !!!
....BAD A$$ STREET CAR.....
[Re: pittsburghracer]
#2604017
01/09/19 06:11 PM
01/09/19 06:11 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
R. Years ago 12 bolt chevies were popular in stock and super stock. Not sure what they prefer now. Isn’t the 9/12 the one to use now? 9” housing with a 12 bolt chevy ring and pinion.
[Re: TRENDZ]
#2604041
01/09/19 06:59 PM
01/09/19 06:59 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
R. Years ago 12 bolt chevies were popular in stock and super stock. Not sure what they prefer now. Isn’t the 9/12 the one to use now? 9” housing with a 12 bolt chevy ring and pinion. IIRC the 12 bolt was the most efficient of the popular rear ends.
[Re: hemienvy]
#2604055
01/09/19 07:24 PM
01/09/19 07:24 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Stockers have to use a corporate rear, so for GM cars it's a 12 Bolt for them. Some still use the 8.5. Mopars will use a 8.75 or a 60.
Super Stock can use whatever. I don't know of anyone who's used a 60 in an AH car for many years. The 12 Bolt center section is typically a lightweight car or a Comp deal where the last ounce of efficiency matters and frequent maintenance is part of the drill.
[Re: hemienvy]
#2604070
01/09/19 07:50 PM
01/09/19 07:50 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
One thing to consider is the chassis it's going in. A 9" will allow you a narrower chassis in a tube car for more tire clearance than the 60 will.
[Re: astjp2]
#2604241
01/10/19 01:34 AM
01/10/19 01:34 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
That's a 2000 ft-lb increase in capacity. I had to check - out of curiosity. A 70 is 60lb. heavier than a 60.
[Re: CMcAllister]
#2604319
01/10/19 10:04 AM
01/10/19 10:04 AM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
The housing of a 70 is 60lbs heavier or the entire assembly? I would think its the entire assembly and mostly concentrated in the brakes.
eBay-cdwmotorsports
[Re: hemienvy]
#2604332
01/10/19 11:17 AM
01/10/19 11:17 AM
TRENDZ
Milwaukee WI
Passenger car D 60s have thinner wall tubing than Ford truck D 60s. Floater style Dana axles have very thick wall tubes. All 70s are floaters, so the tubing is very thick. It doesn’t seem to far fetched that a 70 could be 60lbs heavier without axle ends/ brakes.
[Re: TRENDZ]
#2604491
01/10/19 04:46 PM
01/10/19 04:46 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Passenger car D 60s have thinner wall tubing than Ford truck D 60s. Floater style Dana axles have very thick wall tubes. All 70s are floaters, so the tubing is very thick. It doesn’t seem to far fetched that a 70 could be 60lbs heavier without axle ends/ brakes. Comparing images, it looks like a lot of it is in the center section of the housing. Can't see a 70 as a good option for a race car.
