Page 4 of 10 1 2 3 4 5 6 9 10
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2564301
10/15/18 10:45 AM
10/15/18 10:45 AM
an8sec70cuda Offline
Do you have studs or bolts on your valve covers? If you have studs you MAY have trouble getting the passenger's side valve cover off.
My car flexes enough that if I jack it up and take the weight off the front suspension, the valve cover can be removed. I do have valve cover studs.
If it's sitting w/ the weight on the tires, the cover contacts the shock tower when I try to lift it off.
Hopefully yours doesn't do this since you have snout bars on your cage...wish I'd done that.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: racerx] #2564352
10/15/18 12:23 PM
10/15/18 12:23 PM
Originally Posted By racerx
Lookin Good.
Not to ME tsk
OP, you know it will hit the fender well when revved up in neutral, let alone when at WOT shruggy work
I like to see a 1/4 inch + clearances on that, those cast aluminum valve covers will grow out and up when heated up more than you think shruggy
Now get to work fixing it before it marks up the fenderwell and valve cover thumbs wrench grin
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2564401
10/15/18 02:19 PM
10/15/18 02:19 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Bolts on the valve cover and yes I plan to clearance the shock tower. Really glad that I converted to GERST suspension so I don't need the shock tower. Now the real question is if I'll be able to get 1/4 without scratching the paint!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Cab_Burge] #2564616
10/15/18 10:19 PM
10/15/18 10:19 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Lookin Good.
Not to ME tsk
Cab....I was speaking on the build it self, iagree the valve cover is a little to tight for my likings. but i'm sure the op will address that up consider this a bump don't what this thread to get lost.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: racerx] #2564674
10/16/18 12:25 AM
10/16/18 12:25 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
The thread won't get lost! I'm a pic/post [censored]! up
I shortened the Engine Plate and sealed it to the water pump. I also added the bypass mod with a threaded insert to adjust the orifice size. Currently at 1/8 per the other thread on this board.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: an8sec70cuda] #2564818
10/16/18 01:49 PM
10/16/18 01:49 PM
central il.
second 70 Offline
second 70  Offline
central il.
I can't be the only one who has to remove the shock to get the valve cover off am I? LOL
Even with studs removal sucks.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: second 70] #2565413
10/17/18 03:44 PM
10/17/18 03:44 PM
Nope, I forgot to mention that I have to take the shock loose and push the shock stud down out the way.
CHIP
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: an8sec70cuda] #2566246
10/19/18 12:30 AM
10/19/18 12:30 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I have family in town this weekend and won't get any garage time. I'm going to try to pull the valve covers when I get a chance. I'll be sure to snap pics and update the thread.
I might start a new thread for the induction. I "think" that I want the new Sniper 4500 fuel injection. However, I haven't read many success stories, and Thumper Carbs appear to be pretty bullet proof. I'll probably to the exhaust or cooling system next and think on this one a little.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2567715
10/22/18 10:41 AM
10/22/18 10:41 AM
From what I've heard so far, I'd wait a while on the EFI. Put a good carb on it and enjoy it...later on when more of the bugs are worked out of these EFI systems, maybe.
CHIP
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2584724
11/29/18 03:35 PM
11/29/18 03:35 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
This was the closes thing to an "Easy Button" that I've found for my car. I just had to drill a couple holes:
http://www.speedcooling.com/26-Big-Block-Mopar-Radiator-Dual-Fans.html
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: second 70] #2584922
11/29/18 11:07 PM
11/29/18 11:07 PM
Welcome to the real world of owning and having to work on a 426 Hemiroid motor in a stock B body, same thing on E bodies on shoving the passenger side shock stud down to remove that valve cover even with the stock stamp steel OEM valve covers runaway whiney
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2585185
11/30/18 02:39 PM
11/30/18 02:39 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Can you measure the depth of that setup from the core support to the nose of the fans? It looks great and the price is nice too.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Jeremiah] #2585286
11/30/18 06:36 PM
11/30/18 06:36 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
~7.5 inches from the support to the back of the fan motors. I was able to center the water pump between the fans to gain clearance. My car must have had the smaller radiator as I had to drill holes and use 1/4in spacers between the support and radiator mount:
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2585566
12/01/18 09:48 AM
12/01/18 09:48 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Project is coming up nice !!
X 2 on the carb till you get it dialled / enjoy the car and there are some success stories out there with the Sniper 4500 "EFI"
smile
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2603604
01/08/19 09:50 PM
01/08/19 09:50 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Apparently Instagram stopped the hot linking of images. Does anyone have a good pic hosting site?
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2603616
01/08/19 10:19 PM
01/08/19 10:19 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Let me know if you guys can see these pics!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2603619
01/08/19 10:22 PM
01/08/19 10:22 PM
Looks like TTI headers to me work shruggy
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Cab_Burge] #2603660
01/08/19 11:49 PM
01/08/19 11:49 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Yes! You can see the pics! What a pain in the rear, but I'm sure a few of you guys feel the same after FB bought Photobucket and screwed up everything.
2-1/4 primary, 4in collector, O2 bungs. I'm running CNC ported Indy SR heads so I had to special order the 4in collector option on the HEMI625-214 for Coil Over Suspension. O2 bungs are to keep my induction options open. I'm considering the Sniper 4500.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2603741
01/09/19 02:33 AM
01/09/19 02:33 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I've been using https://imgur.com/
It took a little while to figure out how to use it, but I'm pretty happy with it.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Hemi_Joel] #2604069
01/09/19 07:48 PM
01/09/19 07:48 PM
Addison,IL
OUTLAWSSAA Online content
OUTLAWSSAA  Online Content
Addison,IL
Me too on the Imgur
