Dana 60 gear oil capacity.
#2596013
12/23/18 11:01 PM
12/23/18 11:01 PM
dartman366
Mt. Vernon, Ohio
just pulled the aluminum LPW cover off my d-60 to check things over and cannot remember how much oil I need to put back in ,this cover has no sight plug for the correct level just a drain plug and a fill plug up at the top, I have 2 1/2 quart in it so far, how much are you drag racers running in your's?
Re: Dana 60 gear oil capacity.
[Re: CMcAllister]
#2596127
12/24/18 02:33 AM
12/24/18 02:33 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
Drag only? 2 quarts, if that. The Mopar engineers that use to put on the drag seminars always recommended 1 quart gear oil max in both Dana 60 and 8 3/4 as already stated, that was for a drag only car. I would run around 2 quarts on a street car just to be safe
[Re: Cab_Burge]
#2596198
12/24/18 11:21 AM
12/24/18 11:21 AM
dartman366
Mt. Vernon, Ohio
ok guy's 2.5 quarts should hit the happy median then, thank's to all,, PS, the gears still look great after 14 plus years of abuse. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: DoubleD]
#2596308
12/24/18 02:58 PM
12/24/18 02:58 PM
dartman366
Mt. Vernon, Ohio
This cover was bought as a Jeg's house brand, no level plug in it, maybe that is why it was less expensive than the LPW unit altho it had the Ultimate 60 cast into the center outer cast in bracing and bearing cap tensioner bolts, adding another 1/2 quart would not bother me.
[Re: Twostick]
#2596359
12/24/18 04:53 PM
12/24/18 04:53 PM
dartman366
Mt. Vernon, Ohio
I think the consensus was they weren't that good for the street, by the looks of how mine is doing they seem to be ok for drag racing as mine has been on since I built the dana 14 years ago,,,same pro gears and bearings ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: dartman366]
#2596378
12/24/18 05:31 PM
12/24/18 05:31 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
just pulled the aluminum LPW cover off my d-60 to check things over and cannot remember how much oil I need to put back in ,this cover has no sight plug for the correct level just a drain plug and a fill plug up at the top, I have 2 1/2 quart in it so far, how much are you drag racers running in your's? Stock cover, two of these
[Re: Cab_Burge]
#2596833
12/25/18 05:46 PM
12/25/18 05:46 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Drag only? 2 quarts, if that. The Mopar engineers that use to put on the drag seminars always recommended 1 quart gear oil max in both Dana 60 and 8 3/4 as already stated, that was for a drag only car. I would run around 2 quarts on a street car just to be safe Cab, wouldn't there also be a level difference between a spool and a suregrip? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
72 Plymouth Roadrunner 11.08@123.25
[Re: dartman366]
#2600497
01/02/19 04:22 PM
01/02/19 04:22 PM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
2 quarts in a street/strip in a Dana 60. No more needed.
[Re: dartman366]
#2600549
01/02/19 06:06 PM
01/02/19 06:06 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
I have had an LPW cover on mu Camaro's dana since 2001, It is a street car that sees the racetrack once in awhile. Not one issue with the gearset or bearings at all.
[Re: Cab_Burge]
#2601182
01/03/19 10:44 PM
01/03/19 10:44 PM
Posts: 1,115 Usa
A39Coronet
Usa
Drag only? 2 quarts, if that. The Mopar engineers that use to put on the drag seminars always recommended 1 quart gear oil max in both Dana 60 and 8 3/4 as already stated, that was for a drag only car. I would run around 2 quarts on a street car just to be safe Because they had shelves full of spare parts and we're competing in stock/super stock. Gear life wasn't a priority. Whatever the service manual says is what I follow. I've never lost a race because my rear end fluid was slowing me down.
