Re: Building 440 to 500 stroker [Re: '73-Charger-440] #2599138
12/31/18 11:11 AM
12/31/18 11:11 AM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
Originally Posted By '73-Charger-440
I only plan on sending the block in to get machined, my father owns a shop and is very experienced in building engines, but he's a chevy guy and refuses to help me with what I should get, on the other hand he will help me build the engine becuase he's my dad after all.
Sounds like your dad is doing you a favor by staying out of your parts decisions. As Dirty Harry once said 'A good man knows his limitations'.
You have come to probably the best place on the planet for sound, experienced Mopar information. Post your budget, desired power level, and intended use and you will get plenty of responses.
Good luck with your build.
Master, again and still
Re: Building 440 to 500 stroker [Re: '73-Charger-440] #2599169
12/31/18 12:10 PM
12/31/18 12:10 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My F body has been 1.53 60ft with the oval rubber Main leafs. I did ditch the rubber housing insulators.
Doug
Re: Building 440 to 500 stroker [Re: 74RALLYE] #2602466
01/06/19 03:18 PM
01/06/19 03:18 PM
WI
'73-Charger-440 Offline OP
WI
I also want to stroke it because I think it will be a good project, and if I ever want to go with more power I’ll already have it stroked out.
Re: Building 440 to 500 stroker [Re: '73-Charger-440] #2602502
01/06/19 04:31 PM
01/06/19 04:31 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Good plan! You can always buy the base Stealth or Edelbrock aluminum head and then send them off for cnc porting later.
I have a very mild 505 and it is lots of fun. Never rev over 6400.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Building 440 to 500 stroker [Re: '73-Charger-440] #2602767
01/07/19 02:04 AM
01/07/19 02:04 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Thanks for the great info, although I believe the post 72 440 blocks are only rated to 6000 rpms, so I get nervous playing with the idea of pushing it too far, last thin I want is to send a rod into outer space.
I have no idea where you got the idea that the block's year determines the RPM ceiling.
