Re: Need schooling on Eddy Hemi heads [Re: fast68plymouth] #2601465
01/04/19 02:09 PM
01/04/19 02:09 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Originally Posted By fast68plymouth
Hughes must have gotten the “really good” ones from Edelbrock.
The "open spark plug hole" ones. laugh2
Re: Need schooling on Eddy Hemi heads [Re: fast68plymouth] #2601571
01/04/19 04:33 PM
01/04/19 04:33 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The ones I’ve tested were more like 409@.800, on a 4.500 bore.
Exhaust was 240 without a tube and 273 with a 2-1/8” tube.
I would agree the numbers are a little happy! OTB - mine went right around 430 at .800 after being prepped - I have talked with the edelbrock designer on these and he even said much above 440 is the about the outer limits - but I guess with the right hand finish the right flow bench its possible. the hughes exhaust numbers - I would assume they ran those with a tube to get that kind of result - but I don't look at the exhaust side as real world indicator
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2601742
01/04/19 11:58 PM
01/04/19 11:58 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Modern CNC ported mine.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Need schooling on Eddy Hemi heads [Re: Jimi_Vignogna] #2601814
01/05/19 02:54 AM
01/05/19 02:54 AM
AndyF Offline
AndyF  Offline
Originally Posted By Jimi_Vignogna
The newer Mopar aluminum head castings are also the “E” head. I run them on my Hemi stocker. Out of the box , honed the guides put a valve job in them and assembled. Never flowed them was pressed for time. Car ran 9.89@133.00 mph 3600# IMO great cylinder heads. Everything from a factory designed head fits.
Jimi, I bet you wish you would've had those heads 20 years ago! You would've cleaned up at all the races.
Re: Need schooling on Eddy Hemi heads [Re: AndyF] #2898061
03/11/21 09:36 AM
03/11/21 09:36 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Semi-Zombie thread revival lol...
Wonderful pictures of the Edelbrock heads indeed!
As most of us head porters would know, that HUMP is gonna disrupt flow in a BAD place!
Surely its better to FLOW up to and around the guide and NOT have it sticking out?
Compressing the air into a narrower port will make it 'speed-up' just before the valve seat...
Just my thoughts and not scientific fact as I don't currently have a flow bench... fan
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Need schooling on Eddy Hemi heads [Re: fast68plymouth] #2898188
03/11/21 03:02 PM
03/11/21 03:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by fast68plymouth
I guess the correct answer depends on which hump is being referenced 🤦‍♂️
He did say "upstream" so I definitely misunderstood realcrazy
Rich H.
Esse Quam Videri
Re: Need schooling on Eddy Hemi heads [Re: Gtxxjon] #2898189
03/11/21 03:03 PM
03/11/21 03:03 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
They're just trying to maintain some thickness under the spring pocket.
It does look funny.
Rich H.
Esse Quam Videri
