Re: What are you getting miles per gallon on your Ram trucks?
[Re: Twostick]
#2598564
12/29/18 09:37 PM
12/29/18 09:37 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Are you manually checking the mileage, miles divided by gallons or going off the display? Both ways and the computer is almost spot on the usage of fuel via miles traveled. I check it all the time as i am always at the gas station it seems... I just use the truck a few times a week to go to my treatments which are only 2 miles away so maybe that is why it's getting such poor fuel millage as well as the reformulated fuels for winter in Ca. I just wanted to compare notes as to what others were getting. Stu
[Re: MidPenMopar]
#2598655
12/30/18 01:22 AM
12/30/18 01:22 AM
Posts: 4,579 Motor City
6PKRTSE
Motor City
V10 Ram 2500 4X4 here. Never cared to know. It's actually better than most V8 Rams from what I am reading because of the torque it takes so much less pedal to get it moving.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: MidPenMopar]
#2598792
12/30/18 02:11 PM
12/30/18 02:11 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: 360view]
#2598796
12/30/18 02:23 PM
12/30/18 02:23 PM
MidPenMopar
Holy cow is that a lot of issues or what??? In my case the major stuff so far was I had to replace the gears in the factory corporate rear end right (C-clips fall off) as well as the font end axles right afterwards. The great sounding audio system died a couple of years ago and after trying to get some stock parts with no luck i just gave up and put in an aftermarket radio. Stu
[Re: MidPenMopar]
#2599374
12/31/18 07:43 PM
12/31/18 07:43 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
08 H.Q.C. 5.7, 3.91 gear ,12-14 mpg, towing was getting 9 now get 10 1/2 since adding cold air intake and cutback system
[Re: 300by500]
#2599988
01/01/19 05:05 PM
01/01/19 05:05 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
1992 D250 Cummins, 5-speed.24.5 MPGBut it only gets 19 when pulling a loaded trailer. I had one, smelled horrid, fuel cost 60 cents a gallon more, noisy and a head gasket job costs as much as replacing a 360 magnum of the same vintage. On the plus side I ran it on used engine oil mixed 50/50 from the honda dealer. If it did not cost 4x as much as a gas burner to buy one I would probably do that again but they just cost too dog gone much for what little benefit you do get.
[Re: Rhinodart]
#2599998
01/01/19 05:18 PM
01/01/19 05:18 PM
Posts: 1,032 Fitchburg, WI
BIGHOOK
Fitchburg, WI
2015 2500 5.7 Hemi 4x4 regular cab 3.73 gears I average 13-14 in town and 16-17 on the highway, at 138K the mileage never changes. Similar here: 2007 2500 5.7 Hemi 4x4 Regular Cab, 3.73 gears, LT285x70AS tires, 89 Mid-Grade fuel since new. Mileage 90k. Average 12-14 city, 16-17 highway. Drops a bit pulling a trailer. Not as much with max payload in bed.
[Re: 300by500]
#2600333
01/02/19 09:58 AM
01/02/19 09:58 AM
Posts: 8,162 USA
360view
USA
1992 D250 Cummins, 5-speed.24.5 MPGBut it only gets 19 when pulling a loaded trailer. What is your differential (61 ?) And what ratio? https://en.m.wikipedia.org/wiki/Dana_60#Dana_61
[Re: MidPenMopar]
#2601958
01/05/19 04:45 PM
01/05/19 04:45 PM
HotRodDave
Kalispell Mt.
my 2011 5.7 hemi had 300,000 when I sold it, the durability on the gas motors has come way up and the diesels have gone way down because of all the emmissions controls, NVH improvements, sulfer taken from the fuel...
