Re: What are you getting miles per gallon on your Ram trucks?
[Re: MidPenMopar]
#2598070
12/28/18 06:08 PM
12/28/18 06:08 PM
Posts: 2,924 Calgary, Alberta Canada
a12rag
Stu, that sure isn't right . . . I would suspect you have an issue going on, even though you don't have the "Check Engine Light" illuminated . . . I have 2013 Ram 1500 4x4, 5.7hemi, crew cab, and have gotten 15-18mpg around town, and up to 23mpg on the highway (those would be USA Gallon figures, not Imperial) . . .
[Re: MidPenMopar]
#2598087
12/28/18 06:52 PM
12/28/18 06:52 PM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
All city driving, my 2005 would get 10-11 mpg. If you idle a bunch it's going to be worse as well.
[Re: Blusmbl]
#2598105
12/28/18 07:29 PM
12/28/18 07:29 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
All city driving, my 2005 would get 10-11 mpg. If you idle a bunch it's going to be worse as well. So not that far off from me. One other thing is there a lot of hills around here so that play into the low fuel millage too maybe?
[Re: a12rag]
#2598117
12/28/18 08:10 PM
12/28/18 08:10 PM
Posts: 969 manitoba canada
BleedDodge
manitoba canada
Stu, that sure isn't right . . . I would suspect you have an issue going on, even though you don't have the "Check Engine Light" illuminated . . . I have 2013 Ram 1500 4x4, 5.7hemi, crew cab, and have gotten 15-18mpg around town, and up to 23mpg on the highway (those would be USA Gallon figures, not Imperial) . . . My 2010 hemi quad cab does about exactly the same, I’m happy with it. I think it’s reasonable for a 390 horsepower truck. I have a sprint booster on mine to get rid of the throttle delay, and real dual exhaust with two mufflers is all I’ve done to it.
[Re: MidPenMopar]
#2598165
12/28/18 10:16 PM
12/28/18 10:16 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
those 10 and 13 trucks get much better than the earlier ones, 13-15 in town is normal and 17-19 on highway with the earlier ones, the later ones with VVT MDS get another 2-3 MPG.
[Re: MidPenMopar]
#2598171
12/28/18 10:46 PM
12/28/18 10:46 PM
Blusmbl
Plymouth, MI
So not that far off from me. One other thing is there a lot of hills around here so that play into the low fuel millage too maybe? The hills will certainly also degrade your fuel economy, not surprised it's a little worse than my truck was. New they were only rated at 12 mpg city, and that's assuming ethanol free fuel and no hills either. https://www.fueleconomy.gov/feg/Find.do?action=sbs&id=21160
[Re: MidPenMopar]
#2598244
12/29/18 03:55 AM
12/29/18 03:55 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
My 04 hemi quad cab short bed gets 13mpg... in comparison, driving to the same places, same way etc, my cummins gets 18. Where I live it's lots of hills and I rarely drive on the highway.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: MidPenMopar]
#2598272
12/29/18 09:51 AM
12/29/18 09:51 AM
Posts: 5,965 Greenville, PA
redraptor
Greenville, PA
I have noticed i am getting lower and lower fuel mileage out a gallon of 91 octane (as required for this year engine) gas now it's right around 7 MPG and that's about it.
You should be getting double that mileage and you mention you've noticed it getting worse. I would do some investigating like making sure a brake isn't hanging up or do a plug reading to see if it's overly rich for some reason. Either could be a reason for no CLE.
[Re: MidPenMopar]
#2598277
12/29/18 10:23 AM
12/29/18 10:23 AM
Posts: 4,255 Canada
WO23Coronet
Canada
What kind of tires are you running? I take a big hit mpg wise with my 05 QCSB 4wd Hemi when I put on my Duratracs for the winter (vs Wrangler RSA's for the summer). But yeah, 7 mpg is bad, I do better than that here in the dead of winter (-10 F here today) with my Duratracs on. Whens the last time you changed the plugs?
[Re: 360view]
#2598377
12/29/18 02:13 PM
12/29/18 02:13 PM
MidPenMopar
What brand, size and psi in the tires? High rolling resistence tires can reduce MPG by as much as 3.
On the highway 3.91 diff gears on an unloaded Ram pickup decrease MPG by 2 at a steady 60 mph compared to 3.21.
Camper tops generally increase air drag but it varies a lot by topper shape.
You can zero in on whether the tires and/or camper top is hurting MPG by coasting down a steep but steady grade hill in neutral.
They are 275 x 60 x 20 Goodyear Wranglers. I will double check the tire pressure later but they dont seem to be low. I did see going back though the original owner's stack of paperwork the truck was having problems right before i brought it with check engine light issues. The shop the owner took it too did change the plugs at about 80,000 miles. That seemed to fix the problem. You can see in 10 years i have not put on many miles at all.
[Re: buildanother]
#2598513
12/29/18 08:14 PM
12/29/18 08:14 PM
MidPenMopar
Man Stu, it looks like you really do drive quite locally. I hope the thing gets up to temperature for closed loop and all that, or it will remain a pig. Them San fran hills do not help. I live in Chi suburbs, and my 4.7 durango is at 16 for long term average mpg. Once i can get on the freeway and stay at a steady flat pace i can get near 18 MPG at 65MPH.
[Re: Twostick]
#2598564
12/29/18 09:37 PM
12/29/18 09:37 PM
MidPenMopar
Are you manually checking the mileage, miles divided by gallons or going off the display? Both ways and the computer is almost spot on the usage of fuel via miles traveled. I check it all the time as i am always at the gas station it seems... I just use the truck a few times a week to go to my treatments which are only 2 miles away so maybe that is why it's getting such poor fuel millage as well as the reformulated fuels for winter in Ca. I just wanted to compare notes as to what others were getting. Stu
[Re: MidPenMopar]
#2598655
12/30/18 01:22 AM
12/30/18 01:22 AM
Posts: 4,585 Motor City
6PKRTSE
Motor City
V10 Ram 2500 4X4 here. Never cared to know. It's actually better than most V8 Rams from what I am reading because of the torque it takes so much less pedal to get it moving.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: MidPenMopar]
#2598792
12/30/18 02:11 PM
12/30/18 02:11 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: 360view]
#2598796
12/30/18 02:23 PM
12/30/18 02:23 PM
MidPenMopar
Holy cow is that a lot of issues or what??? In my case the major stuff so far was I had to replace the gears in the factory corporate rear end right (C-clips fall off) as well as the font end axles right afterwards. The great sounding audio system died a couple of years ago and after trying to get some stock parts with no luck i just gave up and put in an aftermarket radio. Stu
[Re: MidPenMopar]
#2599374
12/31/18 07:43 PM
12/31/18 07:43 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
08 H.Q.C. 5.7, 3.91 gear ,12-14 mpg, towing was getting 9 now get 10 1/2 since adding cold air intake and cutback system
[Re: 300by500]
#2599988
01/01/19 05:05 PM
01/01/19 05:05 PM
HotRodDave
Kalispell Mt.
1992 D250 Cummins, 5-speed.24.5 MPGBut it only gets 19 when pulling a loaded trailer. I had one, smelled horrid, fuel cost 60 cents a gallon more, noisy and a head gasket job costs as much as replacing a 360 magnum of the same vintage. On the plus side I ran it on used engine oil mixed 50/50 from the honda dealer. If it did not cost 4x as much as a gas burner to buy one I would probably do that again but they just cost too dog gone much for what little benefit you do get.
[Re: Rhinodart]
#2599998
01/01/19 05:18 PM
01/01/19 05:18 PM
Posts: 1,032 Fitchburg, WI
BIGHOOK
Fitchburg, WI
2015 2500 5.7 Hemi 4x4 regular cab 3.73 gears I average 13-14 in town and 16-17 on the highway, at 138K the mileage never changes. Similar here: 2007 2500 5.7 Hemi 4x4 Regular Cab, 3.73 gears, LT285x70AS tires, 89 Mid-Grade fuel since new. Mileage 90k. Average 12-14 city, 16-17 highway. Drops a bit pulling a trailer. Not as much with max payload in bed.
[Re: 300by500]
#2600333
01/02/19 09:58 AM
01/02/19 09:58 AM
Posts: 8,162 USA
360view
USA
1992 D250 Cummins, 5-speed.24.5 MPGBut it only gets 19 when pulling a loaded trailer. What is your differential (61 ?) And what ratio? https://en.m.wikipedia.org/wiki/Dana_60#Dana_61
[Re: MidPenMopar]
#2601958
01/05/19 04:45 PM
01/05/19 04:45 PM
HotRodDave
Kalispell Mt.
my 2011 5.7 hemi had 300,000 when I sold it, the durability on the gas motors has come way up and the diesels have gone way down because of all the emmissions controls, NVH improvements, sulfer taken from the fuel...
[Re: MidPenMopar]
#2602341
01/06/19 06:39 AM
01/06/19 06:39 AM
Posts: 20,677 in a cattle trailer down by th...
Guitar Jones
The 2019 is averaging about 15 right now but that is no highway miles just around town. My 92 CTD gets 22-23 if you are carful with it and don't drive 80-90 down the interstate. The 74? Forget about it, probably 8 on a good day without touching the secondaties.
