Re: Later 440's have sodium filled valves?? [Re: Supercuda] #2594688
12/20/18 01:50 PM
12/20/18 01:50 PM
Here
jcc Offline
jcc  Offline
Here
Originally Posted By Supercuda
that was the pea rattling around in your head.
"Psychological projection - Wikipedia
Psychological projection is a defence mechanism in which the human ego defends itself against unconscious impulses or qualities (both positive and negative) by denying their existence in themselves while attributing them to others." stirthepot
"When one’s appeal is emotional, it does not matter if there is no substance."
Re: Later 440's have sodium filled valves?? [Re: jcc] #2594704
12/20/18 02:43 PM
12/20/18 02:43 PM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted By jcc
Was there a loose weight/plunger inside to facilitate fluid move?
Thought I remember a click when shaken,
Sodium is salt, correct?
I redid a Ford FE 427 Holman and Moody side oiler boat motor for a friend, I could hear something sliding around in the exhaust valve stems when I shook them shruggy
Re: Later 440's have sodium filled valves?? [Re: Cab_Burge] #2594708
12/20/18 02:52 PM
12/20/18 02:52 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Only in part. Salt is sodium chloride (nacl).
https://www.google.com/search?q=sodium&a...me&ie=UTF-8
Re: Later 440's have sodium filled valves?? [Re: Fat_Mike] #2595086
12/21/18 01:57 PM
12/21/18 01:57 PM
dogdays Offline
dogdays  Offline
The 4.5 Mercedes V8 that was used for so many years had sodium filled exhaust valves. Lose the 6' long timing chain and one would find out. Back in about 1984 they were $28 each.
The deal is, the sodium doesn't fill the whole tube, only half. Then when the valve gets hot the sodium melts and physically transports the heat to the valve stem and head.
R.
Re: Later 440's have sodium filled valves?? [Re: Cab_Burge] #2595164
12/21/18 05:59 PM
12/21/18 05:59 PM
Here
jcc Offline
jcc  Offline
Here
Its actually a low melting temp metal, that is very reactive, one reason it transfers heat well in this application.
Re: Later 440's have sodium filled valves?? [Re: jcc] #2595180
12/21/18 06:49 PM
12/21/18 06:49 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
The A148 NASCAR hemi had them and I think John Aruzza told me that the Ball stud hemi had them as well. I have one on the shelf in my office.
Todd
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2595730
12/23/18 10:29 AM
12/23/18 10:29 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If the 5.7 V8 still has solid exhaust valves,
and the 6.4 has sodium filled exhaust valves,
how could two owners design an experiment to measure
the effect of the different valves
on when a cylinder first has audible pinging in real world use?
Maybe some kind of hill climb on a hot dry summer day?
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2595735
12/23/18 10:34 AM
12/23/18 10:34 AM
USA
3
360view Offline
360view  Offline
3
USA
Sample quote
Compression ratio is another factor that affects performance and engine power. The only thing that creates engine power is the size of the explosion of fuel and air in the combustion chambers and more compression creates a bigger the explosion. Once compression ratios start to get bigger, regular fuel can start to ignite before the spark plugs ignites and this can cause problems. So to prevent that from happening, manufacturers recommend or require higher octane fuel (can withstand a greater compression before igniting) on engines that have higher compression ratios.
The 6.4L SRT engine has a compression ratio of 10.9:1, which is significantly higher than the 3.6L engine’s compression ratio of 10.2:1 or the 5.7L HEMI engines compression ratio of 10.5:1. Premium gas (highest octane) is recommended for the 6.4L SRT engine, whereas midgrade gas is recommended for the 5.7L HEMI and regular gas is recommended for the 3.6L engine.
End quote
Truck version of the 6.4 has a lower static CR of 10
From
https://www.universitydodge.com/dodge-gearhead-6-4l-srt-engine-performance-specs/
