Identifying Small Block Trans/Engine Support Brackets #2594435
12/19/18 09:17 PM
12/19/18 09:17 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have any info on the small block trans/engine trans support brackets? Below are some pics of the support brackets. Are there different brackets between 318 and 340? Different from 70 and 71/72+?
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2594436
12/19/18 09:21 PM
12/19/18 09:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Most of them get thrown away as unnecessary. shruggy
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2594463
12/19/18 10:47 PM
12/19/18 10:47 PM
AndyF Offline
AndyF  Offline
Yeah I just threw a box of them away last week. I did have some marked as 904 rather than 727 so there must be a difference there. Otherwise I guess I never paid enough attention to them to spot them in the wild.
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2594473
12/19/18 11:04 PM
12/19/18 11:04 PM
Australia
fullonmopar Offline
fullonmopar  Offline
Australia
Why would they bother fitting them unless they performed a function. Seems a bit odd that the bean counters would let them be fitted. Same down under they usually get tossed out especially when fitting extractors.
Re: Validating Small Block Trans/Engine support Brackets [Re: fullonmopar] #2594474
12/19/18 11:12 PM
12/19/18 11:12 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Ma Mopar had them installed fora reason. Anytime there’s a device mated to the engine to Trans that creates more rigidity can’t be a bad thing.
Abe Lincoln
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2594481
12/19/18 11:20 PM
12/19/18 11:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They were used with automatic transmissions only, not manuals.
So for whatever reason, they felt the extra bracing was needed for them.
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2594487
12/19/18 11:38 PM
12/19/18 11:38 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suspect the reasons Ma Mopar installed those brackets on the small block auto trans car was for resistance from breakage. A small block trans is only supported at the top 1/2 of the transmission. The extra brackets were installed on the bottom of the trans bell, giving support all around the bell. With the motor basically supported at the front of the motor, and the trans supported at the back of the trans, the bell to block is the weakest point in the support system, with breakage of the bell the result of a failure. I could see under grueling stress, the lack of support at the bottom of the bell could have been an issue. Since Mopar had the cover all the possible problems, adding the brackets to the small block auto trans was probably a cheap response.
The stick bell is stronger and more importantly, a separate piece from the trans. Should a failure occur, the stick would only require a bell replacement. A failure with an auto trans would result in replacing a complete trans case and swapping the guts into a new case. Gene
Re: Validating Small Block Trans/Engine support Brackets [Re: poorboy] #2594495
12/19/18 11:49 PM
12/19/18 11:49 PM
A727Tflite Online content
A727Tflite  Online Content
That is the exact reason.
4 x 4 trucks broke cases when the brackets were omitted and even 2 wheel drives did when driven off road.
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2594923
12/21/18 02:29 AM
12/21/18 02:29 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My brother in law had a driveshaft go out of balance at 80 MPH one time, by the time he got it slowed down and to the side of the road, the trans case was busted in several places. Only the torque converter hub kept the trans from falling out! There were chunks of trans case, trans fluid, and an array of other broken stuff that left a trail to the side of the road.
He said he felt a vibration that grew worse very fast, as he hit the brakes hard, he heard a boom, and coasted to a stop on the side of the road. We think he may have lost a u joint, but there was no way of knowing with what was left. Of course, he didn't think he needed to extra brackets on the trans. He has them there now. Gene
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2594995
12/21/18 12:12 PM
12/21/18 12:12 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
318 and 360 brackets are definitely different. I think 360s are longer. Not sure about 340s.
I was able to keep them installed on my 360 with shorty TTI headers. The drivers side just needed a notch cut out of it for collector flange clearance.
Re: Validating Small Block Trans/Engine support Brackets [Re: burdar] #2595204
12/21/18 09:01 PM
12/21/18 09:01 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Why would the 318 and 360 brackets be different? The engines are the exact same outer dimensions.
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2595319
12/22/18 12:48 AM
12/22/18 12:48 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would suspect any difference would be between the 904 trans and the 727 trans, but there may also be differences between the years. One would think that since all the small blocks have the same outer dimensions (except maybe the A motors and the early 273s), all the brackets would mount in the same locations on the blocks, but we are talking about Mopars...
Gene
Re: Validating Small Block Trans/Engine support Brackets [Re: poorboy] #2595368
12/22/18 02:46 AM
12/22/18 02:46 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i seen some broken chevy 4x4 cases before gm retrofitted brackets that bolted to the heavy aluminum flywheel cover they came up with,i wondered if a mount to the frame for those overgrown 203 t cases would have prevented that??
my ladder of success is missing some rungs
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2595617
12/22/18 08:35 PM
12/22/18 08:35 PM
scratchnfotraction Offline
different yrs had mods to them like the notches on the 1s in pics.
some clearance for cooler lines ect..
as far as I have seen they are 904/727 specific sb & BB specific truck & car specific.
I have ditched a lot, had a lot that would not bolt up correctly and have had 1 & 2 installed with headers...most times A-body headers they got ditched.
they come in handy to chop up and make torque straps from engine to frame rail on the cheap.
and I have seen them used on the 4x4 xfers with skid plates to keep from busting the cases.
ma mopar fixed a huge problem on the cheap by stamping out steel trans braces by the thousands.... same as the steering box brace used on late 70s early/mid 80s trucks for cracking frame holes at steering box.
run them if you got them.
Re: Validating Small Block Trans/Engine support Brackets [Re: elmor353] #2595618
12/22/18 08:46 PM
12/22/18 08:46 PM
I think 340/360 are different as is the 1 motor mount on those blocks due to thicker 4" cyl bore cast blocks..
273/318 LA blocks are same me thinks & you cant bore these 3.91 cyls out to 4" IIRC
318/340 are same stroke but you cant bore a 318 block for a 340 piston
but you can STROKE & BORE a 318 block to a 349 up to a 390 CI
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2599086
12/31/18 04:08 AM
12/31/18 04:08 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
The sides are different but the engine size and 904 to 727 relation are the same. Around 76-77 they moved the little square pad on the engine forward 1 inch on both sides to compensate for the longer starter that they started using, same starter just about half an inch longer than the earlier ones.
So the short ones are early and the long ones are after 76-77 period!
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2599087
12/31/18 04:11 AM
12/31/18 04:11 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
If you run exhaust manifolds, find the correct ones and USE THEM!
Re: Validating Small Block Trans/Engine support Brackets [Re: vinnyd76] #2613500
01/28/19 01:59 PM
01/28/19 01:59 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have any photos of their un-restored/restored A-Body with the trans to engine support brackets installed?
Looking to understand color of brackets. It appears the set I have looks to have zinc plating on one and yellow dichromate finishing on the other. Also wanted to know what bolt sizes/lengths were used.
