Re: Later 440's have sodium filled valves??
[Re: Supercuda]
#2594688
12/20/18 02:50 PM
12/20/18 02:50 PM
Posts: 22,810 Bitopia
jcc
Bitopia
that was the pea rattling around in your head. "Psychological projection - Wikipedia Psychological projection is a defence mechanism in which the human ego defends itself against unconscious impulses or qualities (both positive and negative) by denying their existence in themselves while attributing them to others."
[Re: jcc]
#2594704
12/20/18 03:43 PM
12/20/18 03:43 PM
Posts: 43,368 Bend,OR USA
Cab_Burge
Was there a loose weight/plunger inside to facilitate fluid move? Thought I remember a click when shaken,
Sodium is salt, correct? I redid a Ford FE 427 Holman and Moody side oiler boat motor for a friend, I could hear something sliding around in the exhaust valve stems when I shook them
[Re: Cab_Burge]
#2595164
12/21/18 06:59 PM
12/21/18 06:59 PM
jcc
Bitopia
Sodium is salt, correct? I redid a Ford FE 427 Holman and Moody side oiler boat motor for a friend, I could hear something sliding around in the exhaust valve stems when I shook them Its actually a low melting temp metal, that is very reactive, one reason it transfers heat well in this application.
[Re: Prodart440]
#2595735
12/23/18 11:34 AM
12/23/18 11:34 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Sample quote Compression ratio is another factor that affects performance and engine power. The only thing that creates engine power is the size of the explosion of fuel and air in the combustion chambers and more compression creates a bigger the explosion. Once compression ratios start to get bigger, regular fuel can start to ignite before the spark plugs ignites and this can cause problems. So to prevent that from happening, manufacturers recommend or require higher octane fuel (can withstand a greater compression before igniting) on engines that have higher compression ratios. The 6.4L SRT engine has a compression ratio of 10.9:1, which is significantly higher than the 3.6L engine’s compression ratio of 10.2:1 or the 5.7L HEMI engines compression ratio of 10.5:1. Premium gas (highest octane) is recommended for the 6.4L SRT engine, whereas midgrade gas is recommended for the 5.7L HEMI and regular gas is recommended for the 3.6L engine. End quote Truck version of the 6.4 has a lower static CR of 10 From https://www.universitydodge.com/dodge-gearhead-6-4l-srt-engine-performance-specs/
