Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2595764
12/23/18 01:20 PM
12/23/18 01:20 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
specially the chrome timing chain cover! LOL
Re: Getting 400 HP From A Smogger 440 [Re: NachoRT74] #2595881
12/23/18 06:18 PM
12/23/18 06:18 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The chrome ones were thicker/heavier allowing for a cam button.
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2595886
12/23/18 06:37 PM
12/23/18 06:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Cam button??
On the recommended single bolt .484 cam?
Re: Getting 400 HP From A Smogger 440 [Re: fast68plymouth] #2595976
12/23/18 09:42 PM
12/23/18 09:42 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
I suggested the Summit cam because I have one on hand with matching springs. Summit says they should be used with 9.5 compression, but the 509 cam runs good at the low compression? lol This engine is going in a pickup I use to chase parts in. Just wanted to wake it up a little.
Re: Getting 400 HP From A Smogger 440 [Re: Dave Hall] #2595992
12/23/18 10:15 PM
12/23/18 10:15 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Stock ones are plenty thick enough to use with a nylon cam button on a roller. It's what I use.
Re: Getting 400 HP From A Smogger 440 [Re: GY3] #2596140
12/24/18 02:55 AM
12/24/18 02:55 AM
I've seen the buttons leave a mark and remove metal from the stock steel covers, both on chrome and Mopar OEM covers shruggy work
I think the key is how much camshaft end play do you have to the cover shruggy work
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2596211
12/24/18 12:01 PM
12/24/18 12:01 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I was joking about the timing cover just because won't add any power to the engine LOL... if its better for some specific setup, that's a diff deal wrench
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2596236
12/24/18 12:53 PM
12/24/18 12:53 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
You're overlooking the 5lb weight savings of the $150 water pump housing, and it's significant contribution to the package laugh Also, the solid core plug wires were important to mess up everyone's radio signal laugh
Back in the day I skipped the fluff and did a slightly better fuel system instead, but not knowing what was out there I just went with the Carter 4594....
13.0 first time out, and that same day....12.94.
I will never forget that.
The old parts packages might not be relevant anymore, there are ways to do the same thing and be more street friendly, or spend more and get more, but they are....what they are. A place to start. Try it and see what you think.
Without a place to start and some kind of direction, it's all just a gearhead dream. The goal is to turn dreams into reality somehow.
Have a nice holiday all.
Rich H.
Esse Quam Videri
