Page 2 of 3 1 2 3
Re: 572 going to the Dyno [Re: JACK1440] #2593418
12/17/18 10:46 PM
12/17/18 10:46 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
I just got home. We had our challenges. My 2 1/8" tube headers hit the dyno frame so I had to use a set of 2" fender wells I took along so the exhaust ports measure 2.150 across on a 2" tube. That couldn't be helping things. To top it off my pro systems 1050 was giving us a fit and when I went to the truck the box I grabbed out of the garage didn't have the SV1. yup! 1 1/2 south in Baltimore... Ugg anyways after bolting on the dyno tuners 1150 dominator she made 865hp @ 7200 and 760 lbs tq @ 5800. I will post the dyno sheet with all the pulls once I get it. It's being emailed and I haven't got it yet. The motor is making really good power from basically 5200 - 7400. It was above 700 lbs torque @ 4800 and climbed from there. I'm thinking my good headers a carb that works and a vacuum pump and I'll be at 900. Anyways... I'll post the sheet once I get it. Thanks for all the interest.
Re: 572 going to the Dyno [Re: JACK1440] #2593433
12/17/18 10:59 PM
12/17/18 10:59 PM
AndyF Offline
AndyF  Offline
Yep, sounds like a typical dyno day! I've fought thru a lot of those over years where stuff doesn't fit or the customer forgets something. Over time we stopped used customer supplied parts since they usually didn't fit or work. So now we use our own headers, carb, distributor, etc. to fire the engine.
Sounds like she'll make plenty of power for you once you get it in the car with your parts.
Re: 572 going to the Dyno [Re: JACK1440] #2593464
12/17/18 11:32 PM
12/17/18 11:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That’s really good power with using 2” fenderwell headers.
I’m sure it would have been real close to 900 with the bigger tubes.
On a pretty mild 542 with ez heads, going from 1-7/8” fenderwells to my dyno headers was a 40hp difference.
Re: 572 going to the Dyno [Re: fast68plymouth] #2593465
12/17/18 11:35 PM
12/17/18 11:35 PM
Washington
madscientist Offline
Washington
Yep that fender well header is a killer. Usually the tubes are long enough to plumb a corn field.
That hurt you more than the tube diameter. That and most FW headers have notoriously short collectors.
Re: 572 going to the Dyno [Re: JACK1440] #2593607
12/18/18 05:27 AM
12/18/18 05:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That's awesome Jack !! I definetly want to go when you take her to the track. Ron
Re: 572 going to the Dyno [Re: JACK1440] #2593712
12/18/18 12:46 PM
12/18/18 12:46 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The telling tale will be ET, mph once it's in the car. It didn't break. Recorded a fair number with room for easy improvements. What's the car weigh? Trans and gear?
Doug
Re: 572 going to the Dyno [Re: dvw] #2593803
12/18/18 03:32 PM
12/18/18 03:32 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Doug
This is basically how I feel. Lots of easy potential, it survived 9 hard hits and made promising numbers. I need to figure out how much fuel I need also.
The car is a '68 cuda, 727, stall I'm thinking is gonna fall around 6000, dana 4.88 w/ 33" slicks
Re: 572 going to the Dyno [Re: JACK1440] #2593815
12/18/18 03:43 PM
12/18/18 03:43 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I have had 5700, 5900, 6100 flash. The 5900 has been the best, 6100 was almost as good. Tried 4.10 and 4.30 with 10.5W x 31. Both about the same.
Doug
Re: 572 going to the Dyno [Re: JACK1440] #2593838
12/18/18 04:18 PM
12/18/18 04:18 PM
AndyF Offline
AndyF  Offline
4.88 gear seems like a lot with that engine. What is your trap speed going to be with that much power? 145 or 150 mph? Those gears will have you spinning 7500+ rpm. What did the torque curve look like on the dyno? I'm guessing peak torque was in the 5500 to 6000 rpm range? HP peak was probably less than 7000 rpm wasn't it? You might need to drop the gear ratio down to 4.56 or even 4.30 to avoid spinning it too hard in the lights.
Re: 572 going to the Dyno [Re: AndyF] #2593880
12/18/18 05:52 PM
12/18/18 05:52 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I agree. Plus hitting a 4.88 gear with that much torque will be hard to control to say the least. Good job on the motor though. That is pretty typical of that engine variety at least the ones I have done.
Todd
Re: 572 going to the Dyno [Re: JACK1440] #2593887
12/18/18 06:16 PM
12/18/18 06:16 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I would guess with the 33" tall tire a 4.56 would be about the right gear given the combo - that is assuming 1/4 mile racing if it's running 1/8 mile only - I would go with the 4.88 and let it eat
Re: 572 going to the Dyno [Re: JACK1440] #2593901
12/18/18 06:39 PM
12/18/18 06:39 PM
gregsdart Offline
gregsdart  Offline
My combo; 4.56 gear, 33x15x15 goodyear 2078 (105 roll Out) 150 mph logged 7450 trap rpm, 9.5 lennys, stall 6,000 rpm to 6200. I would put a 4.30 in it, no more. If you want to run a 14x32, then 4.10.
With a 2.45 low and a 4.56 gear, the SLR is 11.17, which is awfully high for a 572. Take crank torque at 6,000 x 2 (converter) x11.17= about 17,000 at the hit to the axles on launch. Digest that for an instant. Plan on a transbrake?
Re: 572 going to the Dyno [Re: AndyF] #2593909
12/18/18 07:16 PM
12/18/18 07:16 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
That's the same thing the dyno owner and engine builder said. My plan is to more then likely take some gear out of it.
Andy, your pretty close peak torque was 5800 and peak hp 7200.
Re: 572 going to the Dyno [Re: JACK1440] #2593924
12/18/18 07:50 PM
12/18/18 07:50 PM
AndyF Offline
AndyF  Offline
7200 rpm for a power peak is pretty impressive given the fact that you had fenderwell headers and a borrowed carb. I'm assuming the intake is "out of the box"? With a ported intake, a big carb and the correct headers you'll pick up at least 50 if not 75 hp.
Good luck with the car, it should fly. Even if you have too much gear in the car you can just run it at 3/4 throttle until you get comfortable with the extra power and then back off the gear when you're ready to go full throttle.
One thing to watch out for is converter slip as you reduce gear ratio. A low 9 second car that runs at the local track has been fighting that. He dropped from 4.88 gears to 4.30 gears and the trap RPM barely budged since he had more slip. So you have more than one variable in the equation.
Re: 572 going to the Dyno [Re: JACK1440] #2593931
12/18/18 08:01 PM
12/18/18 08:01 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Thanks Andy
The intake it matched to the heads already. I have mazzaloni 2 1/8" step headers and figuring out the carb now. I had the same thoughts about feeling it out. Definitely not a bring it out on the brake and let it fly combo...
I'll be asking lots of converter questions soon enough.
Hopefully I'll have the dyno sheets soon to post. I haven't received them in my email yet.
Re: 572 going to the Dyno [Re: JACK1440] #2593940
12/18/18 08:20 PM
12/18/18 08:20 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Wrong headers on the dyno or not, that engine makes enough steam to snap my junk in two. eek
Re: 572 going to the Dyno [Re: JACK1440] #2594056
12/19/18 01:03 AM
12/19/18 01:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Jack your dad told me today you guys plan to have it in the car by February. And you are putting in it at his house. Let me know when you guys put it in as I would like to stop by and check it out when you put the eng in. Thanks , Ron
Re: 572 going to the Dyno [Re: JACK1440] #2594378
12/19/18 07:09 PM
12/19/18 07:09 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Will do Ron
Re: 572 going to the Dyno [Re: JACK1440] #2609083
01/19/19 06:37 PM
01/19/19 06:37 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Finally received my dyno sheets. Here they are for viewing pleasure.
dyno1.txt (139 downloads)
dyno2.txt (73 downloads)
dyno3.txt (72 downloads)
dyno4.txt (102 downloads)
Re: 572 going to the Dyno [Re: JACK1440] #2609157
01/19/19 10:51 PM
01/19/19 10:51 PM
Are the oil temps real or room temps? confused
Page 2 of 3 1 2 3
