Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2602457
01/06/19 03:35 PM
01/06/19 03:35 PM
The Historic Hudson Valley
MONC Online content OP
MONC  Online Content OP
Rallye Dash Bezel
Mopar
Or
No
Car
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2602471
01/06/19 04:21 PM
01/06/19 04:21 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
To me ( per what I can see ) the standard dash cluster fits just right over the bezel, not throught, so the bezel could be the same for both! I can't see any round cut on bezel to fit the speedo section, but a speedo shadow/gap over the bezel
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: NachoRT74] #2602553
01/06/19 07:41 PM
01/06/19 07:41 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
The standard dash has a curved cut out for the large speedo and the rallye is straight. just for correctness the picture of the rallye gauges has the road lamp switch in the wrong location. Should be under the dash.
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: spk2go] #2602564
01/06/19 07:56 PM
01/06/19 07:56 PM
New York
rarefish Offline
rarefish  Offline
New York
I think you are looking at the rear speaker fader?
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: rarefish] #2602570
01/06/19 08:12 PM
01/06/19 08:12 PM
I believe spkgo is referring to the pic second 70 posted of the rallye dash that has the road lamp switch in it.
Yes it was factory mounted under the dash , but probably remounted there for ease of use.
Mopar
Or
No
Car
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: rarefish] #2602571
01/06/19 08:12 PM
01/06/19 08:12 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
Look at second 70’s picture where the road lamp switch is.
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2602572
01/06/19 08:13 PM
01/06/19 08:13 PM
Can someone post a picture of the standard dash with a standard dash bezel? Would like to compare how the bezel looks with the dash cluster.
Mopar
Or
No
Car
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2602615
01/06/19 09:49 PM
01/06/19 09:49 PM
BDW Offline
BDW  Offline
That piece is for standard dash, note the rounded cut out for the larger speedo.
That same piece for a rally is solid rectangular, because the rally gauges are flat in that area.
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2602675
01/06/19 11:45 PM
01/06/19 11:45 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Ok... yes it seems the gap I'm looking at is an optical ilusion, being on bezel then thumbs
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: spk2go] #2602782
01/07/19 03:28 AM
01/07/19 03:28 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That is odd on a rallye dash? here's the location on 70 and 71 STANDARD dashes
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2602818
01/07/19 10:48 AM
01/07/19 10:48 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Many years ago it took me about three hours to put a rally Dash into my standard - 73 Challenger, with a friend helping me.. Actually it's pretty easy had to wire up the tach. And the heater control is different. And I use the factory wiring diagram that really help
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: DAYCLONA] #2602942
01/07/19 02:39 PM
01/07/19 02:39 PM
central il.
second 70 Offline
second 70  Offline
central il.
Good eyes the switch is not in the usual location.Since the car was a standard dash the frame wasn't drilled for the normal location so instead of drilling the frame and knowing it wasn't going to be in the right spot anyway I put it where I thought it looked the best.
Mike
