Re: ring and pinion woes... [Re: Snoopy] #259249
03/21/09 05:39 PM
03/21/09 05:39 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Did you use the correct belleville washer under the nut and is it correctly positioned, convex side of washer up?
From the 70 FSM
Yes, I used the right washer, and it is oriented correctly. I'm having a hard time holding the yoke while tightening the pinion nut. Any tricks? I'm using the largest channel locks known to man...
'64 390 Valiant Signet Convertable (WIP...)
Re: ring and pinion woes... [Re: capac] #259250
03/21/09 05:47 PM
03/21/09 05:47 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
AndyF has a yoke holder available here, I think it uses a 3/4" breaker bar or ratchet.
Re: ring and pinion woes... [Re: capac] #259251
03/22/09 02:52 PM
03/22/09 02:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A super-size pipe wrench makes a good yoke holder.
Re: ring and pinion woes... [Re: John_Kunkel] #259252
03/22/09 04:00 PM
03/22/09 04:00 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Thanks for everyones help! I finally was able to crush the sleeve, but it took some enginuity...
Stack of blocks stopping the channel locks, which had a hose clamp around the handle holding the jaws tight. Then I used a floor jack to tighten the nut. Little by little, I would jack it up, then take it all off and measure rotational torque...
Needless to say, just took a test drive and everything is peechy!
Re: ring and pinion woes... [Re: capac] #259253
03/23/09 09:48 AM
03/23/09 09:48 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Well that's an interesting way to do it ...
Re: ring and pinion woes... [Re: JohnRR] #259254
03/23/09 10:37 AM
03/23/09 10:37 AM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Does this make me elligable for some sort of redneck award?
Re: ring and pinion woes... [Re: capac] #259255
03/23/09 11:05 AM
03/23/09 11:05 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
not yet. once those pliers break and smack you in the face- then you get the award
Re: ring and pinion woes... [Re: aarcuda] #259256
03/23/09 01:10 PM
03/23/09 01:10 PM
JohnRR Offline
JohnRR  Offline
Re: ring and pinion woes... [Re: Snoopy] #259257
03/23/09 01:39 PM
03/23/09 01:39 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
That's a yuppie tool Unless you have a concours NOS Hemi yoke that you don't want to scratch then just use a pipe wrench. A pipe wrench is much faster especially if you are setting pinion bearing preload. Just my
Re: ring and pinion woes... [Re: 446acuda] #259258
03/23/09 04:17 PM
03/23/09 04:17 PM
Snoopy Offline
Snoopy  Offline
I'm trying to figure out how you would go about figuring out the torque with that setup.
Re: ring and pinion woes... [Re: Snoopy] #259259
03/23/09 04:45 PM
03/23/09 04:45 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
the pipe wrench would be removed when checking pinion bearing preload with an inch-lb torque wrench just the same as the yoke holder would be removed when checking pinion bearing preload. Both serve the same purpose: to hold the yoke when tightening or loosening the pinion nut. Maybe I just don't understand what you mean?
Re: ring and pinion woes... [Re: 446acuda] #259260
03/23/09 05:07 PM
03/23/09 05:07 PM
Snoopy Offline
Snoopy  Offline
The factory requires a minimum of 170 foot pounds of torque on the pinion nut. How would you calculate the torque applied to the nut, without guessing?
Re: ring and pinion woes... [Re: Snoopy] #259261
03/23/09 05:28 PM
03/23/09 05:28 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
You hold the yoke with anything that you want and use a torque wrench to torque the pinion nut to specs. The torque wrench doesn't care what you hold the yoke with whether it's a 2 foot yoke holder or a 10 foot pipe wrench or anything in between.
Re: ring and pinion woes... [Re: 446acuda] #259262
03/23/09 05:55 PM
03/23/09 05:55 PM
Snoopy Offline
Snoopy  Offline
Show me the torque wrench in his setup.
Re: ring and pinion woes... [Re: Snoopy] #259263
03/23/09 06:10 PM
03/23/09 06:10 PM
JohnRR Offline
JohnRR  Offline
Re: ring and pinion woes... [Re: Snoopy] #259264
03/23/09 06:21 PM
03/23/09 06:21 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
ok I got ya. What I was saying is that it is much quicker setting pinion bearing preload with a pipe wrench since it can be removed much quicker than a pinion holding tool. Odds are, you are going to have to remove the yoke more than a few times to get the correct shim pack for get the preload in specs and it would get old removing that pinion holding tool after a few times. I realize that the yoke holding tool can be used just to remove and install pinion nut and that's obviously what you are getting at and if that's the case, buying an occasional use "specialty tool" doesn't make much sense unless you are going to use it more than a few times a year. There are some specialty tools worth having but this isn't one of them IMO.
