How Worn of a 440 can you Sucessfully Rering #259150
03/19/09 12:30 PM
03/19/09 12:30 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
How worn of a 440 can you rering and not have really low cranking compression? Whats an acceptable limit (on the thrust sides of the bore) to be worn? 4 thousanths? What have you guys accomplished sucessfully. Im reringing one right now and I dont know if I feel comfortable with the ridge that was built up at the top of the bore. This is my first re-ring though, so maybe im just being paranoid.
Re: How Worn of a 440 can you Sucessfully Rering [Re: GTX MATT] #259151
03/19/09 12:36 PM
03/19/09 12:36 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
Another item to consider is the ring groove clearance in the piston. No matter how good the bores are .. if the ring flutters in the piston .. it will lose ring-seal big-time.
Re: How Worn of a 440 can you Sucessfully Rering [Re: GTX MATT] #259152
03/19/09 01:17 PM
03/19/09 01:17 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Also remember that bore wear is not linear as related to time. It may have taken 80 thousand miles to wear the first .005. The next .005 come off in 40 thousand miles and the next .005 come off in 20 thousand miles. Your re-ring may only last another 10 thousand before it goes bad.
Re: How Worn of a 440 can you Sucessfully Rering [Re: TC@HP2] #259153
03/19/09 01:52 PM
03/19/09 01:52 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
If it's got a bad ridge in it maybe the machine shop can hone it out and knurl the piston skirts to make up the difference.
Re: How Worn of a 440 can you Sucessfully Rering [Re: bobby66] #259154
03/19/09 01:59 PM
03/19/09 01:59 PM
NE Ohio
JG71B Offline
JG71B  Offline
NE Ohio
What is considered a bad ridge,how do you tell exactly? A ridge period,or a large or small one?
FJ6 '71 Charger SE 383HP
Re: How Worn of a 440 can you Sucessfully Rering [Re: JG71B] #259155
03/19/09 02:04 PM
03/19/09 02:04 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Any ridge can be bad , if something in the ring travel changes and the rings wants to go further up the bore the rings will slam the ridge and more than likely break . The ridge can be removed , but you have to do it right . I had a block that someone took the ridge off of with a ridge reamer , std bore block , had to be taken to .040. One cylinder needed a sleeve because the nitwit running the ridge reamer egg shaped the top of the bore, that cylinder took .075 to get a round hole ...
Re: How Worn of a 440 can you Sucessfully Rering [Re: JohnRR] #259156
03/19/09 02:14 PM
03/19/09 02:14 PM
NE Ohio
JG71B Offline
JG71B  Offline
NE Ohio
Would'nt the pistons need removed to get rid of the ridge?I've never done it before. Sorry to hi-jack the post,in the same boat kinda.
Re: How Worn of a 440 can you Sucessfully Rering [Re: JG71B] #259157
03/19/09 02:20 PM
03/19/09 02:20 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
not necessarily , it just needs to be clear of the reamer . Yes it has to be removed , but as said if you have a big ridge then you need to look at other things like bore taper , cylinder roundness ... The ring needs to seal for 100% of its travel , not just at the top.
I'll bet at least one of out shadetrees has removed the ridge on a block they never disassembled
Re: How Worn of a 440 can you Sucessfully Rering [Re: JG71B] #259158
03/19/09 02:20 PM
03/19/09 02:20 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Matt,
How bad is the ridge? I have a reamer you can borrow if you want to... But you want to be very careful to only remove the ridge without hitting the ring sealing area. The issue is the sharp corner of the new ring impacting the rounded edge of the step and getting damaged.
Re: How Worn of a 440 can you Sucessfully Rering [Re: moper] #259159
03/19/09 02:37 PM
03/19/09 02:37 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I've already knocked the ridge out with a buddy who has done a few engines in his day, so the ridge is gone. Every cylinder wasnt the same, the largest reading I found was about 10 thousanths real close to where the ridge was, and it became about 7 thousanths with little movement and about 5 at the bottom of the bore.
Most of them were between about 4-6 thousanths throughout the bore, as I said the largest was 10, one was 9, and the next largest was 7.
Dave, like I said I wasn't planning to tear it down originally but I took the intake off and found it was a bit sludgey and figured head gaskets come in the kit, may as well pop the heads off. Good thing I did because IT DIDNT HAVE HEAD GASKETS! I dont know why, I assume someone took it apart and put it back together without the gaskets not planning to run it? Anyway, someones been in it before, and they messed up big time. It looks like the rings were replaced before because they didnt look too worn, and the same person replaced the rod bearings with .010 undersized units. Maltese cross with an X, .010 undersized rod bearings right? WRONG, the main bearings were supposed to be undersized. Heads werent pretty either, one valve was burned clear through to the seat. It has one bad cam bearing too (its MISSING PART OF THE BEARING HAHA). The crank looks good though and I cleaned the pistons and rods up and they're in nice shape too. I was very surprised because they didnt seem to sit far below deck at all.
So im picking up a re-ring and bearing kit (comes with a gasket kit) from Mancini. My buddy Pete had a set of 516s lying around, I told him mine were bad I dont want to shell out for machine work how do his look. Looks like they have fresh exhaust valves and seats, if not theyre in GREAT SHAPE. Hes selling me those, the 67 intake I need, and a set of good HP valve springs (should work well for the 272/272 cam I want to run) for 100 bucks
Can someone explain to me the entire idea behind knurling the skirts and how it works?
Also, my factory service manual indicated an allowance of 2 thousanths (4.32-4.322 inch bore) so I guess I can subtract 2 thousanths from any of my measurements.
What have you guys found on engines you've rerung and how did it turn out? Im just worried im going to put this together and have it run like a low compression turd with 100 psi of cranking compression. My last 440 was VERY tight and I think I may have been spoiled with it, I want this one to run the same but not so confident it will.
Re: How Worn of a 440 can you Sucessfully Rering [Re: IcorkSOAK] #259160
03/19/09 02:51 PM
03/19/09 02:51 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
What do you mean by flutter in the piston? Move freely up and down? (meaning towards TDC and BDC)
Re: How Worn of a 440 can you Sucessfully Rering [Re: GTX MATT] #259161
03/19/09 03:10 PM
03/19/09 03:10 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Gee and I remember a thread where a bunch of members told you to just run it as is ... ...
Knurling the pistons will work very nicely with the rest of the half bleep job you got going on there .
Re: How Worn of a 440 can you Sucessfully Rering [Re: GTX MATT] #259162
03/19/09 04:53 PM
03/19/09 04:53 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Its a thing where you use a knurl tool to raise material on the surface of the piston skirt to reduce clearance/slap. A knurl looks like the criss cross finish you see onthe handle of cheap tools, like made in china ratchets.
It's a technique developed to reuse old parts when new ones are scarce, or too expensive.
Not worth the time on a re ring in a hobby car
A piston that needs a knurl likely needs ring land spacers, etc.., so in reality it needs pistons
My last rering has been a little iffy, but the two before that were great. Good compression, good power, no oil consumption.
It's a low dollar crap shoot. Odds are in your favor if you do it right. The finish on hone will make or break the job.
Back in the day it was a very common thing to do.
Re: How Worn of a 440 can you Sucessfully Rering [Re: dave571] #259163
03/19/09 07:09 PM
03/19/09 07:09 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'd just do the rering and try not to worry about it too much. Either way your final product will be better than it was when you got it. Not like you go into a rering thinking you're going to get another 100,000 miles out of it anyway.
Re: How Worn of a 440 can you Sucessfully Rering [Re: DaytonaTurbo] #259164
03/19/09 07:57 PM
03/19/09 07:57 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
My brother re-ringed his late 440 and it runs great in his Coronet. I just did mine, but I have yet to start it. His engine was fantastic inside, as new looking as a used engine could look. Mine, not so much. The thing I had going for mine was the fact that I had this engine running in a car before and know it wasn't junk. I am figuring it will run at least as good as it used to , hopeing anyway
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: How Worn of a 440 can you Sucessfully Rering [Re: GTX MATT] #259165
03/19/09 08:07 PM
03/19/09 08:07 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
Ring flutter? ...where the ring is not being held firmly square on the cyl wall.
Re: How Worn of a 440 can you Sucessfully Rering [Re: JohnRR] #259166
03/19/09 09:30 PM
03/19/09 09:30 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Yup...you can knurl 'em yourself with two files and a vice. Just loosly clamp the piston/files combo w/files on opposite sides of the skirt and hammer the files in opposite directions causing the piston to rotate. End result will be either a raised area on your piston skirt or a new ashtray.
Re: How Worn of a 440 can you Sucessfully Rering [Re: Bill MeLater] #259167
03/19/09 09:51 PM
03/19/09 09:51 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Knurling is mechanically expanding the piston skirt using amachine to emboss a a pattern on the piston skirt that in effect raises a portion of the skirt with tiny crosshatch ridges somewhat like the handle of some tools.
even on a low buck job like this it is wise to have the crankshaft checked and at least polished and new bearings put in at least on the rods.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: How Worn of a 440 can you Sucessfully Rering [Re: GTX MATT] #259168
03/19/09 10:36 PM
03/19/09 10:36 PM
Indiana
P
Pentastar440 Offline
P
Indiana
I wouldn't do it. Proper cylinder walls should be round and straight. No way to get that without machining. If you are going to all the trouble to pull it apart, why not go ahead and do it right? Having said that, if you do decide to give it a shot, make sure that you use cast rings. They are more forgiving and will conform somewhat to out of round cylinder walls. Maybe you could pick up another engine and build it at your leisure, then swap it out when you are ready? Either way good luck.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: How Worn of a 440 can you Sucessfully Rering [Re: Pentastar440] #259169
03/19/09 11:06 PM
03/19/09 11:06 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Thats kind of the idea, I want this engine to run well for maybe two years while I take care of the little bit of rust, the dent, the interior, and paint it.
Then I can splurge and go all out
