Re: Slant 6 in 37 coupe? Anyone have one?
[Re: codfish]
#2588808
12/07/18 10:08 PM
12/07/18 10:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Substantial difference between a 34 and a 37 Plymouth
[Re: codfish]
#2588928
12/08/18 03:07 AM
12/08/18 03:07 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I never knew of a person pulling a v8 to put a /6 in but I can understand why. To have /6 rod would be cool and unique.
Have a great day Iowan
"obsolete is neat"
[Re: Iowan]
#2588983
12/08/18 11:14 AM
12/08/18 11:14 AM
Posts: 19,480 north of coder
moparx
the engine bay difference between a 34 and a 37 is virtually zero. the body differences are another story. figure on at least some firewall mods and of course, the engine wiring harness. if the GM engine has an electric fan, you may want to consider keeping that. good luck on your project. keep us updated on the progress, please.
[Re: moparx]
#2589032
12/08/18 02:41 PM
12/08/18 02:41 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Ha, never even thought about the LENGTH of the /6 The firewall appears to be stock. It does have an electric cooling fan, which is a pusher so that will help with room fore and aft. As for the wiring harness, it has enough of the 95 Camaro harness to make the fuel injection work (ECM and sensors), but the starting and charging system is all tied into the universal aftermarket harness. codfish
[Re: codfish]
#2589279
12/09/18 11:20 AM
12/09/18 11:20 AM
moparx
i owned a 38 coupe, and my one buddy owned a 37 sedan, plus, i parted out several 37/38 sedans. the firewall is indeed, stock on your car. when the time comes for the mockup of the /6, consider replacing the pusher fan with a factory [OEM] style puller. since the 6 lays over, you may find by ditching the fixed fan and spacer, the firewall mods may be minimal, and the puller fan can be mounted high, missing the engine. as i don't have a /6 here to measure, i can't tell you the length. although the original engine was a 6 as well, it may, or may not, be close. i'm saying this because the inline 6 was a heavy type of casting, while the /6 was a lighter, more "modern" style of casting, and may be very close to the original in size. it was designed to fit in the new A body, and those had not only a lower hood line, but a somewhat cramped engine bay as well. in the very early 70's, my one buddy had a T-bucket with a slant, and that thing would flat out scoot ! i realize that is an apples to kumquat comparison, but the cool factor was way high.
[Re: moparx]
#2589509
12/09/18 06:58 PM
12/09/18 06:58 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
i don't have a /6 here to measure, i can't tell you the length. Roughly 30 inches. Neat project. Looking forward to the progression.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2589515
12/09/18 07:16 PM
12/09/18 07:16 PM
moparx
i don't have a /6 here to measure, i can't tell you the length. Roughly 30 inches. Neat project. Looking forward to the progression. me too !
[Re: codfish]
#2590775
12/12/18 11:42 AM
12/12/18 11:42 AM
Supercuda
About to go away
About to go away
up yours
Huge difference between an SBC based LT1 (which is what he has) and an LS based LT1.
[Re: Supercuda]
#2590780
12/12/18 11:53 AM
12/12/18 11:53 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Huge difference between an SBC based LT1 (which is what he has) and an LS based LT1. So it is Lol. Well that's a little closer power wise to a slant. Would the SBC engine footprint be bigger than an LS? I'm thinking if it is it makes the Gen3 go in easier if there is such a thing as easier in this instance. Kevin
[Re: codfish]
#2590835
12/12/18 02:18 PM
12/12/18 02:18 PM
Supercuda
About to go away
About to go away
up yours
Not that much of a GM guy but my understanding is that the LS is sever so lightly smaller in most respects than the SBC. But that really depends on what is dressing what. Tunnel ram on a 350, it'll be taller, but stock intake vs stock intake the LS can be taller. No distributor on the LS so firewall clearance is better on an LS. Exhaust ports sit higher on an LS, so header clearances can be different. Oil pan choices are slimmer on an LS and not as easily cut and welded to clear. Not really a clear answer for you. https://paceperformance.com/p-3990-engine-dimensions.htmlThe GenIII and various other Mopar engine dimensions http://st.hotrod.com/uploads/sites/21/2016/10/54-Chrysler-engine-dimensionstable.jpg
[Re: Supercuda]
#2590840
12/12/18 02:33 PM
12/12/18 02:33 PM
moparx
i know engine height can vary a ton between installations, but the E58 360 i had in my coupe would have had no issues with running a tunnel ram under the stock hood with no modifications. it would have been CLOSE, but doable. as i used a reversed corvair box on mine, i used a pair of 69/69 passenger side [center dump] manifolds from a 340 dart. owning a junkyard back then helped with parts. center dump headers were not available back then.
[Re: codfish]
#2591237
12/13/18 11:53 AM
12/13/18 11:53 AM
Supercuda
About to go away
About to go away
up yours
No on the bell housing pattern, for the most part. There is a bell the 60's trucks used that incorporated the rear motor mounts that had both patterns. It was for the NP435 truck 4 speed (granny first).
I also have a very vague recollection of a factory adapter plate that allowed the SB bell on a /6 in 60's vans.
