Re: Iron vs alum rocker arm for the street [Re: fastmark] #2586864
12/04/18 01:24 AM
12/04/18 01:24 AM
New York
polyspheric Offline
polyspheric  Offline
New York
they see themselves as problem solvers
I have one you'll find amusing. In (what was) the Iron Curtain countries Harley-Davidson WW2 leftovers are very valuable but extremely expensive to rebuild. "We need those small needle bearings for the transmission shafts, but $$$ and hard to find".
What to do?
They used short sections of wire coat hangars, cut to length, packed in heavy grease.
Boffin Emeritus
Re: Iron vs alum rocker arm for the street [Re: fastmark] #2587002
12/04/18 01:17 PM
12/04/18 01:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quite a few years ago, when I had plenty of time and no $$$, I cobbled quite a few piles of old junk together.
They always ran surprisingly well and nothing ever failed.
Even on old junk, cleanliness and attention to details matter........ and it helps if you kinda know what you’re doing(which is about how it was back then....... I “kinda” knew what I was doing).
Re: Iron vs alum rocker arm for the street [Re: fast68plymouth] #2587034
12/04/18 02:46 PM
12/04/18 02:46 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Somewhat related to the topic question: Anyone else seen their "traditional" iron adjustable rockers (e.g. Crane) leave noticeable wear patterns even on chromed aftermarket rocker shafts? The last set I ran (mid-to-late '90s) left grooves on the loaded areas of the shafts that matched the machining pattern inside of the rockers. I always thought having bushed iron/steel rockers would have been a better idea after seeing that.
Re: Iron vs alum rocker arm for the street [Re: BradH] #2587057
12/04/18 03:29 PM
12/04/18 03:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
I had the same problems with galling trying to use the Speed Pro Hi Po rocker shafts with ductile iron rockers whiney Ended up only using either Iskys or RAS shafts, that cures those problems up
I had to learn the same lesson on CAT aluminum roller rocker arm also, don't use the Speed Pro Hi Po shafts on them either realcrazy tsk
Re: Iron vs alum rocker arm for the street [Re: fastmark] #2587087
12/04/18 04:48 PM
12/04/18 04:48 PM
Boise
Moparteacher Offline
Boise
My Cranes are bushed by RAS and run on undersized shafts. Plus I run full time oiling, to the top, via the lifter galley.
No problems.
Re: Iron vs alum rocker arm for the street [Re: fastmark] #2587115
12/04/18 06:05 PM
12/04/18 06:05 PM
Washington
madscientist Offline
Washington
When the rocker grabs the shaft it's usually a volume/pressure issue. I don't like idle oil pressure less that about 45 pounds hot. It's also why I always use a HV pump. You get more oil there, sooner.
Re: Iron vs alum rocker arm for the street [Re: BradH] #2587282
12/05/18 12:16 AM
12/05/18 12:16 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I've used both Isky and Crane on their recommended shafts without any unusual wear with both solid and hydraulic FT cams with moderate VS pressure.
I've used Isky and Crower (they use to have ductile iron rockers too) on "other" shafts. Not good.
Re: Iron vs alum rocker arm for the street [Re: fastmark] #2587284
12/05/18 12:25 AM
12/05/18 12:25 AM
Boise
Boise
I've measured the OD of the shafts from various manufacturers and found they vary .003" from smallest to largest. This may explain galling when switching them up.
Re: Iron vs alum rocker arm for the street [Re: fastmark] #2587416
12/05/18 11:37 AM
12/05/18 11:37 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
These are Manicinis House brand iron adjustables. I know nothing about them. Probably made overseas to be able to have the low price.
https://www.manciniracing.com/maraenadroar.html
Keep old mopars alive.
