Re: On your back transmission jack ?
[Re: Sixpak]
#2585440
11/30/18 11:38 PM
11/30/18 11:38 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
[quote=Jeremiah]I have this and it has been flawless. It's a must have for a stick shift guy. Automatic will be even easier. "800 lb" Trans Jack https://www.harborfreight.com/automotive...jack-60234.htmlBuy this one and you won't be sorry. I had the one that goes in a floor jack. Then the cheapie small scissor jack and last year when one almost fell off it bought the Harbor Freight one listed above. It works GREAT. I just did the clutch on my NV5600 Cummins with that same jack. Keep in mind it's really meant for flat tranny pan automatics. You have to get creative in order to get it to cradle an oval shaped manual trans case. And I had to modify the chain set up some to get it to be reliable. That NV5600 they say is 400+ pounds and I believe it. It was nice being able to dial in the angle of the trans both vertically and horizontally so the input shaft could go right in. I would not waste money on the cheaper one they sell, the scissor type with the strap. Good advice. That is a big trans. I have used my setup for NP540s and you do have to add some hardware and use the little side things to prop the trans. We were prepared to be dissapointed. I'm still stoked on it years later as it is the only jack here that doesn't leak down overnight.
[Re: n20mstr]
#2585602
12/01/18 12:25 PM
12/01/18 12:25 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I used to pull and install my 4 speed and autos on my back usually just lifting them in.Now I have the best 3 big sons.LOL.I do miss not having the jacks at work since i retired.the good part of working in a shop.Rocky
Chrysler Firepower
[Re: n20mstr]
#2585642
12/01/18 02:08 PM
12/01/18 02:08 PM
Posts: 1,237 North Central, Indiana
Roughbird72
This is what I've used the last three years, but ditched the supplied strap and put a smaller one on. I use a cordless impact to run it up and down. Harbor Freight Jack It also works well for sliding 8 3/4 centers out of the housing too.
72 Plymouth Roadrunner 11.08@123.25
[Re: Iowan]
#2585925
12/02/18 01:20 AM
12/02/18 01:20 AM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
Should do a pole here how many of us put transmissions in off our chest I was a helluva lot younger then. BTDT
'71 Duster '72 Challenger '17 Ram 1500
[Re: Iowan]
#2585950
12/02/18 02:18 AM
12/02/18 02:18 AM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Should do a pole here how many of us put transmissions in off our chest I was a helluva lot younger then. If I remember right a new process four speed weighted 126 pounds and I pulled and installed mine in my 72 Duster three times in one evening. And then the race was rained out the next day. Car up in the air on stands, rolled the transmission on my chest, and lifted it up in. Of course I was 20 years old back then.
[Re: n20mstr]
#2585973
12/02/18 03:10 AM
12/02/18 03:10 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
You been sayin your 39 for 40 years,,,,,,
[Re: n20mstr]
#2586091
12/02/18 01:40 PM
12/02/18 01:40 PM
therocks
Niles , Ohio
Pittsburgh the thing I hated about doing my 833 was the drain plug.Had marks in my chest for a week.Then I got smart and used some padding beffore I sat it on my chest.Many years ago though.Rocky
Chrysler Firepower
