Re: Which Flowmaster is the best application
[Re: gregok]
#2586604
12/03/18 02:29 PM
12/03/18 02:29 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Do you want noise, or mufflers that actually flow?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: gregok]
#2586653
12/03/18 03:51 PM
12/03/18 03:51 PM
Posts: 855 ontario canada kingston
aspenrt360
Dynomax super turbos on all my cars never had an issue runs good too.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
[Re: burdar]
#2587001
12/04/18 01:14 PM
12/04/18 01:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Here is the inside of a Super Turbo. I think I found this picture on here and saved it. I don't like the way the exhaust flows right into the exit pipe. For low hp applications it probably doesn't restrict the flow much but I wouldn't want to use them on anything that is making good power. I'm not really a fan of the sound of these either. Exhaust sound is a very subjective thing. go read the article linked above.
[Re: burdar]
#2587100
12/04/18 05:27 PM
12/04/18 05:27 PM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Unless I'm missing something, both Dynomax mufflers listed in the article are offset inlet and outlet. Those are designed differently inside. The center outlet design is the one that looks restrictive. Not really - they simply cross-flow internally. The sCFM #'s for offset/center, & offset/offset are about the same - around 410 sCFM's for both 2.25" & 2.5" Super Turbo versions. Still, Super Turbos do not do much "tuning" of the sound, but they do more than Ultra Flows. Ultra Flows are like oval glasspacks & other straight-through mufflers. Flowmasters TUNE the sound, but they do not flow impressive sCFM's because the plates internally cause quite significant restrictions.
[Re: gregok]
#2587254
12/04/18 11:30 PM
12/04/18 11:30 PM
Posts: 2,260 IL
furious70
IL
I ran FM 10 series on my fury for a number of years, what's all this complaining about their big mufflers 😎 I do have summit turbos and tailpipes now, plus the turbos themselves, much different now.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: gregok]
#2587431
12/05/18 12:13 PM
12/05/18 12:13 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Dynomax Super Turbos are restrictive as he11 and definitely hurt power! I like Flowmasters personally, but know a lot don't. Never seen the performance drop from Flowmasters a lot claim though. Had a set of 3" 40 series Flowmasters on my cuda w/ a 440 that ran 11.40s in the 1/4 and it ran the same w/ the mufflers or without them.
The Dynomax Ultra Flow, Hooker Max Flow, or Hooker Aerochamber are very good flowing and sounding mufflers too.
[Re: gregok]
#2587434
12/05/18 12:17 PM
12/05/18 12:17 PM
Posts: 3,391 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I had Flowmasters on my 70 B-body, and the drone at highway cruising RPMs was AWFUL.
Switched from manifolds to headers, then switched from an H-pipe to and X-pipe while keeping mufflers the same. Got a little better, but still droned badly.
Your mileage may vary, but I would not use them again.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: gregok]
#2587549
12/05/18 03:39 PM
12/05/18 03:39 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I think I've ran em all lol I tossed Dynomax Super Turbos on my daiy driver Cordoba, 2 1/2" mandrel bends out the rear coming off Hooker SuperComps. Love the sound honestly. No drone, nice sound and fairly quiet at cruising speeds. Best Flowmaster sound I have heard was my motorhome, I loved it. Healthy hydraulic roller 360, headers, Y-pipe into SINGLE 3" exhaust and two 3" Flowmaster 50 series in TANDEM. I loved it. Quiet and gorgeous tone, no drone.
CrAzYMoPaRGuY
[Re: gregok]
#2587601
12/05/18 04:41 PM
12/05/18 04:41 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
It took a couple tries but I felt I got it perfect on one car, I loved the sound of the 2.5" 20" super turbos on my 5.7 magnum r/t daily driver (manifolds, jba catless mids). I also tried 2 chamber flowmasters and hooker aero chamber on it. flowmasters were too loud for long drives for my taste, hooker was slightly quieter but still just a little too much sound. The 20" dynomax required some light fab work to fit, but I liked them the best. The problem with alot of late models is most exhaust for them is spec'd with cats which kill alot of volume. Go catless and suddenly everything is louder and more droney.
I loved the sound of hooker aero chamber 3" on my GTX when I had H pipe, 1 and 7/8 comp headers, and almost the same engine combination as now. However I was chasing power so I went slightly bigger and with ultra flo. I also like those quite a bit. the power thing worked out ok in conjunction with other changes.
For short blasts in a hot rod I'm ok with the classic flowmaster thing, but they better be pretty short drives. To jump in and drive for a couple hours, I'd have to go with old-man 20" super turbos. I believe these are what used to be marketed as hemi super turbos....
Rich H.
Esse Quam Videri
