Re: On your back transmission jack ? [Re: WHITEDART] #2585438
11/30/18 11:35 PM
11/30/18 11:35 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted By WHITEDART
This will work
That is what I use as well...
Re: On your back transmission jack ? [Re: Sixpak] #2585440
11/30/18 11:38 PM
11/30/18 11:38 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted By Sixpak
Originally Posted By pittsburghracer
[quote=Jeremiah]I have this and it has been flawless. It's a must have for a stick shift guy. Automatic will be even easier.
"800 lb" Trans Jack
https://www.harborfreight.com/automotive...jack-60234.html
Buy this one and you won't be sorry. I had the one that goes in a floor jack. Then the cheapie small scissor jack and last year when one almost fell off it bought the Harbor Freight one listed above. It works GREAT.
I just did the clutch on my NV5600 Cummins with that same jack. Keep in mind it's really meant for flat tranny pan automatics. You have to get creative in order to get it to cradle an oval shaped manual trans case. And I had to modify the chain set up some to get it to be reliable. That NV5600 they say is 400+ pounds and I believe it. It was nice being able to dial in the angle of the trans both vertically and horizontally so the input shaft could go right in. I would not waste money on the cheaper one they sell, the scissor type with the strap.
Good advice. That is a big trans. I have used my setup for NP540s and you do have to add some hardware and use the little side things to prop the trans. We were prepared to be dissapointed. I'm still stoked on it years later as it is the only jack here that doesn't leak down overnight.
Re: On your back transmission jack ? [Re: n20mstr] #2585602
12/01/18 12:25 PM
12/01/18 12:25 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used to pull and install my 4 speed and autos on my back usually just lifting them in.Now I have the best 3 big sons.LOL.I do miss not having the jacks at work since i retired.the good part of working in a shop.Rocky
Chrysler Firepower
Re: On your back transmission jack ? [Re: n20mstr] #2585642
12/01/18 02:08 PM
12/01/18 02:08 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
This is what I've used the last three years, but ditched the supplied strap and put a smaller one on. I use a cordless impact to run it up and down. Harbor Freight Jack
It also works well for sliding 8 3/4 centers out of the housing too.
72 Plymouth Roadrunner 11.08@123.25
Re: On your back transmission jack ? [Re: Iowan] #2585925
12/02/18 01:20 AM
12/02/18 01:20 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Originally Posted By Iowan
Should do a pole here how many of us put transmissions in off our chest I was a helluva lot younger then.
BTDT
'71 Duster
'72 Challenger
'17 Ram 1500
Re: On your back transmission jack ? [Re: Iowan] #2585950
12/02/18 02:18 AM
12/02/18 02:18 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If I remember right a new process four speed weighted 126 pounds and I pulled and installed mine in my 72 Duster three times in one evening. And then the race was rained out the next day. Car up in the air on stands, rolled the transmission on my chest, and lifted it up in. Of course I was 20 years old back then.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: On your back transmission jack ? [Re: n20mstr] #2585952
12/02/18 02:22 AM
12/02/18 02:22 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Let me figure this one out .... I’m 38 now so 6 years ago I was ..... 32 ! .... yeah THATS the ticket ! ... smoke
Re: On your back transmission jack ? [Re: n20mstr] #2585973
12/02/18 03:10 AM
12/02/18 03:10 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You been sayin your 39 for 40 years,,,,,, work violin
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: On your back transmission jack ? [Re: n20mstr] #2585980
12/02/18 03:18 AM
12/02/18 03:18 AM
Florida STAYcation
Florida STAYcation
STAY on topic NY gEeZeR ! .... and fOcUs on the details of my post ... I’m alleging THIRTY EIGHT years old ... tsk
Re: On your back transmission jack ? [Re: n20mstr] #2586091
12/02/18 01:40 PM
12/02/18 01:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Pittsburgh the thing I hated about doing my 833 was the drain plug.Had marks in my chest for a week.Then I got smart and used some padding beffore I sat it on my chest.Many years ago though.Rocky
Chrysler Firepower
Re: On your back transmission jack ? [Re: therocks] #2586166
12/02/18 03:38 PM
12/02/18 03:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I was pulling the one out of my Dart on a single post lift. I decided to save time and leave the reverse rod hanging on the trans. When I slid it out of the disc and bellhousing the trans slipped in my hands a little. Luckily for me the reverse rod stuck squarely in my solar plexus. I couldn't even yell for help. I managed to get it set down without dropping it. runaway
Re: On your back transmission jack ? [Re: n20mstr] #2586168
12/02/18 03:47 PM
12/02/18 03:47 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I took 1"x1" and nailed a jack pad square, onto the backside of a piece of 3/4 plywood. I routed out the drain plug boss, to keep the trans level. It doesn't have to be very big. Come in from the front, and the rear remains open. NOW, ask me why I forgot to bring it to Gregs house when we removed it!! Welding one up to use the jack mandrel is the final solution, just like Andy mentioned.
