Would you hit it? (header clearancing question)
#2582305
11/24/18 12:25 PM
11/24/18 12:25 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I am running into a tight fit using the Milodon 31581 oil pan with my stepped TTI headers. There is about .055 clearance between the fitting and primary tube as you can see in the pictures. I'll be swapping out the 90 degree fitting for a 120 due to the change to a QA1 tube K member. https://www.summitracing.com/parts/aer-fbl1545/overview/With such little clearance, would you dent the header tube?
Re: Would you hit it? (header clearancing question)
[Re: Jeremiah]
#2582328
11/24/18 01:24 PM
11/24/18 01:24 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
You could probably you could change the shape of the header tube some without hurting the performance of the engine. I've also seen some low profile fittings . Between the two I'm sure you could get enough clearance to get a good rap on the line and be safe. For drag race use
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Jeremiah]
#2582334
11/24/18 01:31 PM
11/24/18 01:31 PM
WHITEDART
bean town ....Ca
Absolutely header wrap would be your best friend and I think a feeding similar to this will gain you quite a bit
[Re: WHITEDART]
#2582337
11/24/18 01:32 PM
11/24/18 01:32 PM
WHITEDART
bean town ....Ca
The low profiles are sold in 6 8 10 12 and 16..
[Re: sgcuda]
#2582342
11/24/18 01:39 PM
11/24/18 01:39 PM
Posts: 3,525 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Maybe it's the picture, but I don't like the condition of the weld around that fitting. Looks like it could break from vibration at any time. Might be a good time to weld in a new fitting an inch or so back in the pan. To me it looks like you could just cut and reweld the pan fitting closer to the pan and pick up plenty of clearance.
[Re: Jeremiah]
#2582384
11/24/18 02:35 PM
11/24/18 02:35 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I think it is undercut to the tube. It looks like major surgery to move any of it due to the trap door placement.
Maybe I am back to squeezing the tube a little? Is there a way to do it without hurting the coating? It's not the end of the world if it does. Years ago I watched a friend of mine beat the crap out of a couple of tubes on his coated headers, the coating didn't budge. I would have expected it to chip of or something but he put some rags over it and wailed away. Now would I try it on my own headers? Only if I absolutely had to lol.
68 Barracuda Formula S 340
[Re: dvw]
#2582406
11/24/18 03:20 PM
11/24/18 03:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If that tube bend is the first one I wouldnt smash it at all.. move the fitting.. the first bend is the most critical on headers EDIT being the outside of the bend is even worse
[Re: Jeremiah]
#2582484
11/24/18 06:42 PM
11/24/18 06:42 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I have three or four different kinds of heat wrap that I got from buying used NASCAR team braided stainless and fittings. Some of it is in the shape of convoluted tube like the stuff that OEM's use to jacket wiring , but it is a fabric of some sort. Asbestos ? I am not sure what , but it is white in color. Some is silver and the best I can describe it as is 1/8th " thick duct tape. But there are a bunch of different heat wraps that I had never seen in catalogs or magazines that might be the hot tip here. No pun intended. I hope it works , because I used it in a couple different places on my car. As far as where to get it , I might look at industrial sources instead of automotive. McMaster - Carr is great for that kind of thing. https://www.mcmaster.com/
[Re: FastmOp]
#2582523
11/24/18 07:49 PM
11/24/18 07:49 PM
Jeremiah
Rogue River, OR
I'd bang it like the first hooker I seen the day I got out of Prison Ka-Pow! Nothing like modifying ten year/model specific parts to work with (or against) each other. A few motor plate pictures:
[Re: MR_P_BODY]
#2582526
11/24/18 07:53 PM
11/24/18 07:53 PM
Jeremiah
Rogue River, OR
If that tube bend is the first one I wouldnt smash it at all.. move the fitting.. the first bend is the most critical on headers EDIT being the outside of the bend is even worse If I was you I'd move the fitting. Hell if I was you I'd probably made my own oil pan. For my skill level we are safer doing some caveman maneuvers to the the second bend in #3 primary and double wrapping it. If it's down on power I'll grab the button and release the nitrous monster. : )
[Re: Jeremiah]
#2582562
11/24/18 08:36 PM
11/24/18 08:36 PM
MR_P_BODY
For wrap i used a white cotton looking stuff that was developed for NASA..was a 1/4" thick and would drop over a 1000*... I used it on a few places on my car(was proto type stuff)
