Re: Dodge Demon 572 [Re: Raffaplymouth60] #2592885
12/16/18 06:25 PM
12/16/18 06:25 PM
Italy
Raffaplymouth60 Offline OP
Italy
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Dodge Demon 572 [Re: Raffaplymouth60] #2592930
12/16/18 08:44 PM
12/16/18 08:44 PM
I would look at cutting the spacer between the flex plate and crankshaft enough to get what you want for converter end play work
How much end play are you looking to get ?
I seem to remember .080 as the max on my glide confused
I would, and do, contact the converter company to get the specs. they want on end play scope
Re: Dodge Demon 572 [Re: Cab_Burge] #2592938
12/16/18 09:13 PM
12/16/18 09:13 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have about 10 powerglide flex plates and probably 9 different adaptor hubs. Some go behind and some go in front. I'm betting id you look around you will find an adaptor hub that will work for you. Just a small part of my stock
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dodge Demon 572 [Re: Cab_Burge] #2593046
12/17/18 03:46 AM
12/17/18 03:46 AM
Italy
Italy
i think .100 is the clearance .. i will ask at converter builder ! Thanks
Re: Dodge Demon 572 [Re: pittsburghracer] #2593047
12/17/18 03:48 AM
12/17/18 03:48 AM
Italy
Italy
wow ! i will remove tonight and will misure my spacer thickness
