Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2580778
11/20/18 09:20 PM
11/20/18 09:20 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
What pistons/rods and how much compression/boost now? New clutch and 9s next? thumbs
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2580782
11/20/18 09:31 PM
11/20/18 09:31 PM
Renton Washington
Triple Threat Offline
Renton Washington
What does it weigh?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2580890
11/21/18 01:06 AM
11/21/18 01:06 AM
ghinmi Offline OP
ghinmi  Offline OP
It's got the MMX drop in piston/rod package. I actually didn't even figure the compression, just slammed them in and sent it. Quick and dirty. It didn't really need them but I just felt more comfortable having them for Drag Week because I'd be so far from home with no backup plan.
I actually put another Hellcat clutch in it a couple days ago. Not sure that it's got enough steam to go 9s but it keeps getting faster so who knows? Definitely didn't expect the 66mm to make as much power as it already has.
It's just a shade under 4000 lbs usually. Was 3960 right after the 10.38 pass.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2580975
11/21/18 09:49 AM
11/21/18 09:49 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
love this thing.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2581232
11/21/18 07:38 PM
11/21/18 07:38 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
How much boost are you running now? I'm building a similar combo, little bigger turbo and lighter vehicle... it may end up being quicker than I realize based on what yours run.
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2581242
11/21/18 08:19 PM
11/21/18 08:19 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Me likey, fun ride.
"Just a Bracket car dressed up like a streetcar"
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: Just-a-dart] #2581308
11/21/18 10:53 PM
11/21/18 10:53 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
How cool is that!!! Nice ride!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2581333
11/21/18 11:32 PM
11/21/18 11:32 PM
IL
furious70 Online content
furious70  Online Content
IL
How much boost/power did you end up making with the stock engine?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2581638
11/22/18 06:44 PM
11/22/18 06:44 PM
ghinmi Offline OP
ghinmi  Offline OP
The quick pass was on 16 psi. It'll make more but goes slower, all out of turbo. With some fuel pulled out of it I think I can squeak some more boost out of it. And add some timing too. It's a very, very conservative tune.
On the stock stuff it had been 10.50s @ way less mph and a ton better sixty. I forget the mph, sub 130 though. I want to say it was at 10ish psi. It was picking up big power with timing increases but I was afraid of the stock stuff.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2592525
12/15/18 09:02 PM
12/15/18 09:02 PM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
Engine compartment pic? Turbo location?
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2596351
12/24/18 04:41 PM
12/24/18 04:41 PM
IL
IL
I've got a 76mm T6 that I was going to build an EZ headed 400 from parts I have for my Coronet, but thinking more and more about the 5.7. I'm interested in just taking an OEM pull out and starting rather than building one, don't need crazy power (yet). Just a step up from my Fury's very docile turbo setup.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: mcmopar1] #2596646
12/25/18 03:48 AM
12/25/18 03:48 AM
ghinmi Offline OP
ghinmi  Offline OP
The turbo in the red one was passenger side up by the firewall, blue one is passenger side front mount.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2597319
12/26/18 10:15 PM
12/26/18 10:15 PM
IL
IL
What engine management are you using?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2597515
12/27/18 12:14 PM
12/27/18 12:14 PM
ghinmi Offline OP
ghinmi  Offline OP
It's on holley HP efi. I went with the cable drive throttle body so that I didn't need the Dominator. Kind of wishing I would have sprung for the extra money now for the extra inputs and outputs.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2597862
12/28/18 02:31 AM
12/28/18 02:31 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
That is the coolest Jeep ever! What wheel and tire setup are you using for autocross. Looks awesome!
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: MuuMuu101] #2598009
12/28/18 03:37 PM
12/28/18 03:37 PM
ghinmi Offline OP
ghinmi  Offline OP
Thanks! For autocross and street I've got 17x11 C4 Corvette ZR1 wheels. Cheap and effective. And 275/40zr17 Continental ExtremeContact Sports. It's a tradeoff, I could go a bunch bigger but nobody makes a good 17" tire in wide sizes and the 18" stuff gets expensive. It's working pretty good for the budget wheels/tires though.
