Re: Vapor Separator
[Re: lewtot184]
#2580132
11/19/18 11:38 AM
11/19/18 11:38 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
I solder up the return orifice and then drill to desired size. keep in mind that HP440's and hemi's used higher pressure pumps that worked ok with a .060" orifice. lower pressure pumps should use a smaller return orifice. Ok, thank you, the orifice is only one the end so I don't have to solder up the whole tube correct? Also, what pressure would be good with a 440 stroked to 500"?
Re: Vapor Separator
[Re: 70charger512]
#2580209
11/19/18 02:48 PM
11/19/18 02:48 PM
Posts: 3,916 usa
lewtot184
usa
I solder up the return orifice and then drill to desired size. keep in mind that HP440's and hemi's used higher pressure pumps that worked ok with a .060" orifice. lower pressure pumps should use a smaller return orifice. Ok, thank you, the orifice is only one the end so I don't have to solder up the whole tube correct? Also, what pressure would be good with a 440 stroked to 500"? just do a simple solder of the 1/4" nipple and then re-drill to the size you want.
Re: Vapor Separator
[Re: 71birdJ68]
#2582515
11/24/18 07:43 PM
11/24/18 07:43 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
It doesn't say anything about having the screen inside. On their ebay the original diagram is pictured, which shows the screen, so I'm assuming that they wouldn't have no screen but show the correct diagram. Also the condition states they're in their original packaging.
Re: Vapor Separator
[Re: 71birdJ68]
#2582569
11/24/18 08:50 PM
11/24/18 08:50 PM
Posts: 2,592 None
71rm23
None
So, these are NOS? I can only see part of the ad. Don't know NOS but per his ebay auction
Re: Vapor Separator
[Re: 70charger512]
#2582691
11/25/18 03:02 AM
11/25/18 03:02 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
For everyone that helped out and anyone that ever reads this thread: 521 Restorations sells the vapor separator with the correct lengths, correct .060 metered orifice, and the correct screen inside. I just received an email from them. Go buy your valor separator from 521 restorations.
Edit: They're repop, not NOS, but still has all the correct specs.
