Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Cab_Burge] #2580024
11/18/18 11:15 PM
11/18/18 11:15 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
That's YOU TALKING up there ! tsk whistling
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Cab_Burge] #2580098
11/19/18 05:25 AM
11/19/18 05:25 AM
Canada
CrAzYMoPaRGuY Offline
Canada
Thanks for the roses tonight Doc.
NICE TOUCH!!! penguin
CrAzYMoPaRGuY
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Cab_Burge] #2580285
11/19/18 06:12 PM
11/19/18 06:12 PM
kansas
farmboy Offline
farmboy  Offline
kansas
When you figure out how to get a rear main not to leak let me know. I have tried everything I know of, and still have drips. About ready to try and locate an old rope seal, and see if that works.
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: farmboy] #2580387
11/19/18 11:24 PM
11/19/18 11:24 PM
Cab_Burge Online work OP
Cab_Burge  Online Work OP
I'm almost positive that the crank seal is not leaking, there is no sign of oil on the oil pan side of the rear crankshaft flange confused The motor is still in the back of my truck on the transport cart, I'm taking it out tomorrow and I will hang it on the chain hoist and tilt it enough so there is a bunch of oil flooding the back half of the motor to help me find that dang leak wrench
I'll post my results when I figure it out thumbs
I have switch brands of rear seals due to using all the OEM Mopars I had in stock earlier this year but I don't think it is the crankshaft seals or the side seals, we will see confused wrench
