When you figure out how to get a rear main not to leak let me know. I have tried everything I know of, and still have drips. About ready to try and locate an old rope seal, and see if that works.
I'm almost positive that the crank seal is not leaking, there is no sign of oil on the oil pan side of the rear crankshaft flange
The motor is still in the back of my truck on the transport cart, I'm taking it out tomorrow and I will hang it on the chain hoist and tilt it enough so there is a bunch of oil flooding the back half of the motor to help me find that dang leak
I'll post my results when I figure it out
I have switch brands of rear seals due to using all the OEM Mopars I had in stock earlier this year but I don't think it is the crankshaft seals or the side seals, we will see
