Re: Hurst V Gate shifter fitment
[Re: 383man]
#2578270
11/14/18 06:58 AM
11/14/18 06:58 AM
Posts: 10,091 MN
JERICOGTX
MN
Here is a picture of my Road Runners floor pan, and what is needed to fit a Jerico trans with LONG shifter. You will pretty much need to do the same to fit a Hurst V gate.
69 GTX
68 Road Runner
[Re: Stanton]
#2578361
11/14/18 01:51 PM
11/14/18 01:51 PM
Posts: 2,423 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I ran a Hurst V gate in my GTX for years, loved it, no more missed 3rd gear shifts. Now, with my GTX restored, including repairing the hole I cut in the floor pan and reinstalling the factory shifter and console, I remember why I changed to the V gate...jeez this factory shifter sucks, already tired of hitting my knuckles on the dash trying to grab 3rd
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: JERICOGTX]
#2578467
11/14/18 05:58 PM
11/14/18 05:58 PM
RapidusMaximus
Weatherford, Texas
My brain is not grasping how that reduces the throw by 50%...the levers on the trans are still required to move the same amount fore and aft...is the difference in the shifter?
[Re: MadMopars]
#2578473
11/14/18 06:30 PM
11/14/18 06:30 PM
Posts: 4,457 Washington
madscientist
Washington
And how does all that clear the tunnel and all the crap in the way down there?
[Re: RapidusMaximus]
#2578496
11/14/18 07:37 PM
11/14/18 07:37 PM
Posts: 10,091 MN
JERICOGTX
MN
My brain is not grasping how that reduces the throw by 50%...the levers on the trans are still required to move the same amount fore and aft...is the difference in the shifter? Tolerance stack. When you see how much slop the stock style parts have, and the non positive stop, the shift lever multiplies that slop. Trust me, it's a night and day difference. Everything fits the stock tunnel. No way I'd ever go back to stock stuff.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2578545
11/14/18 10:15 PM
11/14/18 10:15 PM
RapidusMaximus
Weatherford, Texas
What are you using for a shift lever? Of course I'm using the stock lever that comes over and up towards the driver's thigh...lol...looks like this
[Re: MadMopars]
#2578574
11/14/18 11:24 PM
11/14/18 11:24 PM
Posts: 10,091 MN
JERICOGTX
MN
Using the exact same shifter handle.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2578604
11/15/18 01:27 AM
11/15/18 01:27 AM
madscientist
Washington
I remember why I changed to the V gate...jeez this factory shifter sucks, already tired of hitting my knuckles on the dash trying to grab 3rd Then you need to do what I did, to my Dads Super Bee. I installed a new Comp Plus mechanism, and then made my own shift Rods with heim joints. It cuts the throw down by half. What size tubing is that? I may give that a shot if you got it in there without hacking stuff out. The biggest PITA will be buying a left handed tap, and that's a phone call to MDS or whoever I buy that crap from.
[Re: madscientist]
#2578654
11/15/18 08:43 AM
11/15/18 08:43 AM
RapidusMaximus
Weatherford, Texas
I remember why I changed to the V gate...jeez this factory shifter sucks, already tired of hitting my knuckles on the dash trying to grab 3rd Then you need to do what I did, to my Dads Super Bee. I installed a new Comp Plus mechanism, and then made my own shift Rods with heim joints. It cuts the throw down by half. What size tubing is that? I may give that a shot if you got it in there without hacking stuff out. The biggest PITA will be buying a left handed tap, and that's a phone call to MDS or whoever I buy that crap from. X2 if those tubes help that significantly I'd be down to build a set also.
[Re: madscientist]
#2578663
11/15/18 10:14 AM
11/15/18 10:14 AM
Posts: 10,091 MN
JERICOGTX
MN
[quote=madscientist What size tubing is that? I may give that a shot if you got it in there without hacking stuff out.
The biggest PITA will be buying a left handed tap, and that's a phone call to MDS or whoever I buy that crap from. [/quote]
1/2" tubing. I just used RH threads. Set it on the bench, and forget about it. IF I needed to make an adjustment, just loosen up one side of it, and turn it a turn or so, but it has been rock steady since being installed. I just bought heim joints on eBay, and went from there.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2578688
11/15/18 12:23 PM
11/15/18 12:23 PM
madscientist
Washington
The biggest PITA will be buying a left handed tap, and that's a phone call to MDS or whoever I buy that crap from. 1/2" tubing. I just used RH threads. Set it on the bench, and forget about it. IF I needed to make an adjustment, just loosen up one side of it, and turn it a turn or so, but it has been rock steady since being installed. I just bought heim joints on eBay, and went from there. [/quote] Cool. So I'm ASSuming that you used 3/8x3/8 hiem joints??? I already have enough LH taps that I'll make mine LH/RH and call it good.
[Re: MadMopars]
#2578882
11/15/18 07:21 PM
11/15/18 07:21 PM
Posts: 9,034 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The Hurst "Super Shifter" is a an H pattern shifter with reverse lockout. Although mine is on the L bracket and has longer rods that requires cutting the tunnel I see no reason it can't be bolted to the trans like a stock shifter and use shorter rods. I just used RH threads. Set it on the bench, and forget about it. IF I needed to make an adjustment, just loosen up one side of it, and turn it a turn or so, but it has been rock steady since being installed. I just bought heim joints on eBay, and went from there. Using all RH threads you're "lucky" if you get the adjustment bang on (but close is probably good enough). With LH and RH threads the adjustment is infinite whereas with only RH threads adjustment is limited to the width of a thread
[Re: Stanton]
#2578963
11/15/18 11:07 PM
11/15/18 11:07 PM
madscientist
Washington
The Hurst "Super Shifter" is a an H pattern shifter with reverse lockout. Although mine is on the L bracket and has longer rods that requires cutting the tunnel I see no reason it can't be bolted to the trans like a stock shifter and use shorter rods. I just used RH threads. Set it on the bench, and forget about it. IF I needed to make an adjustment, just loosen up one side of it, and turn it a turn or so, but it has been rock steady since being installed. I just bought heim joints on eBay, and went from there. Using all RH threads you're "lucky" if you get the adjustment bang on (but close is probably good enough). With LH and RH threads the adjustment is infinite whereas with only RH threads adjustment is limited to the width of a thread The Super Shifter does not have a reverse lockout. The Super Shifter does have a reverse lockout.
