Re: New Gen III Isky Products at Sema
[Re: Adrielp]
#2592186
12/15/18 03:08 AM
12/15/18 03:08 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
My guess is that any new turbo headers are for the newer cars and won't work on the old stuff.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: ghinmi]
#2592224
12/15/18 10:12 AM
12/15/18 10:12 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Looks like Texas Speed is beating Isky to the VVT punch. They announced a lineup of VVT hemi cams at PRI. I forgot to take any pictures but they had one on display. Why Isky was even bothering with the old non-vvt cams first I'll never know. because pre Eagle cams out sell VVTs by 7 to 1 also cam cores are more readily available. Doubtful on the 7 to 1 number. Pretty much anything in the last decade hemi-wise is vvt and lots of people are swapping cams in them. Swap cars, obviously most use non-vvt. Because the cost and availability of vvt cams are silly. Comp is controlling the market with their ridiculously priced core. Seen the Comp sale #s Comp it is 7 to 1 , Comp is not the only one with VVT cores, Bullet and CP both have cores , the CP is limited to .600 lift Bullet has been great to work with.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: 65Dodge440]
#2592225
12/15/18 10:19 AM
12/15/18 10:19 AM
ric3xrt
Trumbauersville PA
I was at PRI last weekend.
Bullet said they have VVT cores on the shelf and to call and they can grind what you want. He said they are less expensive than what we are used to seeing for VVT hemi cams.
CamMotion said he has a VVT hemi on the stand and he's measuring everything before they make one available. Looking forward to what Cam motion can do, Bullet grinds are in the $550 range , I have a custom .710/690 here for a (4.09 X 4.20) 441 build is using Jesel lifters and Rockers.
[Re: MattW]
#2592230
12/15/18 10:25 AM
12/15/18 10:25 AM
ric3xrt
Trumbauersville PA
Hopefully this ends up changing. IMO VVT block are stronger.
BGE is definitely stronger than the 6.1, no if ands or analy retentive buts about it. ....but keep in my Rob Goss went in to the high 6s on a modified 6.1 block before they switched over to the Alum block.
[Re: Silver70]
#2593147
12/17/18 02:23 PM
12/17/18 02:23 PM
Posts: 836 Columbus, OH
65Dodge440
Columbus, OH
Good questions Silver, they may be for the newer cars. They were compact though, like a factory truck exhaust manifold facing forward so they may work on an older car. Would be interesting to see if they would work.
[Re: Adrielp]
#2593252
12/17/18 05:22 PM
12/17/18 05:22 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
The newer cars are tighter under the hood, in front of the engine, beside the engine, on top of the engine...
[Re: Adrielp]
#2593562
12/18/18 02:11 AM
12/18/18 02:11 AM
Posts: 2,260 IL
furious70
IL
The new cars don't have the a arms and steering boxes in the way tho
70 Sport Fury 68 Charger 69 Coronet 72 RR
