5.2 magnum not building coolant pressure## fixed thanks all
#2576174
11/09/18 02:03 AM
11/09/18 02:03 AM
Posts: 3 Alabama
Bama ram
Alabama
Hey guys please help if you can, 93 5.2 magnum.(Heater core bypass during all the testing) With a radiator pressure gauge I hold 16psi with no drop. Cap tested and pass also.. 2nd water pump in a week I can take heater hose off while running and it pumps water out fine, I can pinch the heater hose and it doesn't affect the top return hose to radiator pressure wise.. block flshed through block drains thermostat opens and trickles out enough to get top tank of radiator hot.. cap on and I don't build pressure and starts to over heat. Would cracked heads do this or can someone please point me in the right direction.. it built pressure one time during testing just long enough to cut truck off, crunk it up and it was gone again
Re: 5.2 magnum not building coolant pressure
[Re: Bama ram]
#2576195
11/09/18 02:49 AM
11/09/18 02:49 AM
RapidRobert
cap on and I don't build pressure and starts to over heat. It is overheating? what temp? confirmed with a good gauge? idling/around town or interstate? More details please.
[Re: Bama ram]
#2576228
11/09/18 05:31 AM
11/09/18 05:31 AM
Posts: 20,652 in a cattle trailer down by th...
Guitar Jones
Radiator is partially plugged. Went through this many times.
[Re: Bama ram]
#2576269
11/09/18 11:51 AM
11/09/18 11:51 AM
Posts: 960 Chicago
PurpleBeeper
Chicago
My gut instinct is that your radiator cap is bad, even though it tested good...or maybe just not sealing well on the radiator fill neck. It certainly would explain a lack of pressure in the system + your overheating.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Bama ram]
#2576770
11/10/18 02:01 PM
11/10/18 02:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Every Magnum water pump I have seen comes with the pulley attached, not to mention they look way different and the LA pump is longer. Probably not an LA pump.
[Re: Y3 70 BEE]
#2576931
11/10/18 10:46 PM
11/10/18 10:46 PM
Supercuda
About to go away
About to go away
up yours
Sure you dont have a partial pressure radiator cap? that jogged a memory cell, so I dug it up, http://www.allpar.com/fix/engines/cooling-caps.html
[Re: Supercuda]
#2576943
11/10/18 11:05 PM
11/10/18 11:05 PM
RapidRobert
Supercuda, good read/info, thank you!
[Re: Bama ram]
#2577036
11/11/18 08:36 AM
11/11/18 08:36 AM
Guitar Jones
All the magnums have the fixed pulley with the single nut fan clutch. Only the 91 318 Dakota had a bolt on pulley with the serpentine belt.
So let's recap, water pump replaced, pushes water out the heater hose so it's moving water. Tstat opens, cap tests good and it holds pressure. Block has been flushed out. Hmm, radiator is still partially plugged whether he wants to believe it or not.
[Re: Bama ram]
#2577269
11/11/18 09:42 PM
11/11/18 09:42 PM
RapidRobert
You guys aren't so bad I'm going to have to stick around and check out what this site has to offer You just caught us on a good day (fasten your seat belt), you'll see!
