Re: 70 340 6 pack kickdown rod too short
[Re: f2502011]
#2579230
11/16/18 05:04 PM
11/16/18 05:04 PM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You seem to be focused on the length of the rod but, as you've stated, the trans lever is full back at WOT so the point is moot.
What you should be focused on is the "Start in 1 and floor it slap stick moves to 2nd by itself prematurely.".
[Re: John_Kunkel]
#2580335
11/19/18 09:05 PM
11/19/18 09:05 PM
Posts: 364 US
f2502011
US
What you should be focused on is the "Start in 1 and floor it slap stick moves to 2nd by itself prematurely.". Checked mounts they are good. Today I reinstalled the rod after I tweaked it so it was the same length as a stock one. I was playing with the shifter handle and noticed that sometimes I couldn't get it to fully go into 1. So I drove it. When I would put it down in 1 once I got it to fully go I noticed the accelerator pedal was almost impossible to press. I brought it back and took a look under the hood and the shift linkage and kickdown rod linkage are interfering with each other. So this must be why when you floor it in 1 it automatically moves to 2 because the kickdown rod is pushing the shift selector to the next gear. How can I fix this?
1970 EK2 T/A 727
[Re: f2502011]
#2580347
11/19/18 09:48 PM
11/19/18 09:48 PM
John_Kunkel
Rio Linda, CA
Check the shift linkage for loose or missing plastic bushings, they're known to fall out.
[Re: John_Kunkel]
#2580349
11/19/18 09:50 PM
11/19/18 09:50 PM
Posts: 364 US
f2502011
US
Check the shift linkage for loose or missing plastic bushings, they're known to fall out. has it but its not that color.
1970 EK2 T/A 727
[Re: f2502011]
#2580685
11/20/18 05:02 PM
11/20/18 05:02 PM
Posts: 364 US
f2502011
US
I think I may remove the anti-theft column lock rods and see if that helps
1970 EK2 T/A 727
[Re: f2502011]
#2581112
11/21/18 03:24 PM
11/21/18 03:24 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Check the shift linkage for loose or missing plastic bushings, they're known to fall out. has it but its not that color. Yours are probably white
[Re: f2502011]
#2581130
11/21/18 03:54 PM
11/21/18 03:54 PM
Posts: 566 WA
tman
WA
Do you have a 2nd person to watch what is going on? Have someone push the kickdown linkage back and forth and see what is happening down below. Is it binding on something? After you "tweaked" it, now you can't push on the accelerator. Sounds like it got worse when you adjusted the rod. Almost sounds like the kickdown is not attached at the right place. Do you have a photo where the kickdown is attached to the transmission? The kickdown lever hitting the shift lever at transmission? While car is on ramps or stands, put trans in 1st gear, move kickdown lever back and forth and see what is happening below. Use wheel chocks. Quick article about kickdown and different length levers. https://www.hotrod.com/articles/the-lowdown-on-stock-torqueflite-kick-down-linkage/
[Re: tman]
#2581143
11/21/18 04:32 PM
11/21/18 04:32 PM
Posts: 364 US
f2502011
US
Do you have a 2nd person to watch what is going on? Have someone push the kickdown linkage back and forth and see what is happening down below. Is it binding on something? After you "tweaked" it, now you can't push on the accelerator. Sounds like it got worse when you adjusted the rod. Almost sounds like the kickdown is not attached at the right place. Do you have a photo where the kickdown is attached to the transmission? The kickdown lever hitting the shift lever at transmission? While car is on ramps or stands, put trans in 1st gear, move kickdown lever back and forth and see what is happening below. Use wheel chocks. Quick article about kickdown and different length levers. https://www.hotrod.com/articles/the-lowdown-on-stock-torqueflite-kick-down-linkage/ I believe the intereference of the column lock rear rod in the attached photo that is an anti-theft mechanism has been the issue with it automatically shifting from 1-2 the whole time. I had someone tell me to remove this rod and it would likely solve my issue.
1970 EK2 T/A 727
[Re: Morty426]
#2581144
11/21/18 04:33 PM
11/21/18 04:33 PM
Posts: 364 US
f2502011
US
Check the shift linkage for loose or missing plastic bushings, they're known to fall out. has it but its not that color. Yours are probably white Yes
1970 EK2 T/A 727
[Re: dvw]
#2581207
11/21/18 06:50 PM
11/21/18 06:50 PM
Posts: 364 US
f2502011
US
Are you sure you have the correct throttle pressure kick down lever attached at the valve body? There are different lengths. This would change the attaching point distance of the rod. Maybe it got switched out during a trans overhaul? Doug I'm not sure of anything. How can I tell.
1970 EK2 T/A 727
[Re: f2502011]
#2581305
11/21/18 10:48 PM
11/21/18 10:48 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Are you sure you have the correct throttle pressure kick down lever attached at the valve body? There are different lengths. This would change the attaching point distance of the rod. Maybe it got switched out during a trans overhaul? Doug I'm not sure of anything. How can I tell. Good Read with some pictures on the factory stuff so you can understand what your looking at with different length throttle levers and adjustment , never mind the Lokar cable setup mentioned in the article as that is an aftermarket set up Click on link https://www.hotrod.com/articles/the-lowdown-on-stock-torqueflite-kick-down-linkage/
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: stumpy]
#2581897
11/23/18 01:15 PM
11/23/18 01:15 PM
Posts: 364 US
f2502011
US
If you remove the lock rod remember to set the lever at the bottom of the column or the ignition will lock. Not sure I understand please explain.
1970 EK2 T/A 727
[Re: stumpy]
#2582244
11/24/18 03:19 AM
11/24/18 03:19 AM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
The lock rod moves part of the column that allows the ignition to turn. It is an safety device the car from being started when in gear. Play with the lever and the ignition switch and you will see what I mean. If the lever on the lower column is down you can't get the key out. Ask me how I know this.
[Re: f2502011]
#2582316
11/24/18 01:04 PM
11/24/18 01:04 PM
Posts: 364 US
f2502011
US
Does the rod need to be all the way up or all the way up or all the way down for everything to function?
1970 EK2 T/A 727
