Re: pushrods
[Re: DusterKid]
#2567088
10/20/18 10:22 PM
10/20/18 10:22 PM
RapidRobert
Mike at B3 racing wants .080" & hardened if using guide plates (not sure if you need .080 with your paticular cam/springs or not, just a heads up). Scott foxwell at straub technologies has a utube vid on geometry & getting the right pushrod length which multiple people/shops say is dead on correct (90 deg rocker/valve angle at midlift of your particular cam choice for the rocker height) & with that set, it then sets the "distance" for pushrod length needed for YOUR INDIVIDUAL app. EDIT on the pushrod length, add .020 or so what you prefer for preload for hyd or subtract what your cold lash is for solids.
Re: pushrods
[Re: 79410aspenrt]
#2567276
10/21/18 01:20 PM
10/21/18 01:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Over the years I have bought PRs from multiple places.. SB are the highest price and Trend cones in second.. but Trend was about $40 less.. I also bought from another local place.. OE pushrods.. they dont offer all the different wall thickness but are WAY cheaper.. they build for multiple big companies.. my last set I got from them was for my W-9.. payed $110 for 20 pieces and 3/8 ball and ball they will make all the different lengths ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: pushrods
[Re: DusterKid]
#2567560
10/21/18 11:56 PM
10/21/18 11:56 PM
Posts: 4,213 New York
polyspheric
New York
I assume you're using the largest diameter that will fit?
Boffin Emeritus
Re: pushrods
[Re: LA360]
#2571122
10/29/18 05:58 PM
10/29/18 05:58 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Trend or Smith Bros, 0.080" as a minimum thickness Trend in this motor but I have used both with great results. BGR also makes them in house.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: pushrods
[Re: DusterKid]
#2571506
10/30/18 11:20 AM
10/30/18 11:20 AM
polyspheric
New York
If possible ($$) ask the good mfg. what taper they recco - they need your exact block, head, lobe height, and rocker arm + ratio. Do it once, and it will never bother you again.
Boffin Emeritus
Re: pushrods
[Re: DusterKid]
#2572211
10/31/18 03:58 PM
10/31/18 03:58 PM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
I use Smith Bros. or Manton...both have great service and a great product.
Re: pushrods
[Re: DusterKid]
#2572319
10/31/18 07:06 PM
10/31/18 07:06 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Re: pushrods
[Re: DusterKid]
#2572915
11/02/18 08:43 AM
11/02/18 08:43 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Ive run Crane 3/8 alloys in my 440 for decades.First set was for hyd cam.Had to change them when I went solids.This set has been in at least 30 years.Rocky
Chrysler Firepower
