Valve spring recommendations #2574244
11/05/18 02:26 AM
11/05/18 02:26 AM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
452 heads with this cam, thanks
Engel
K58 is 230*@.050 & .520 lift
K60 is 238*@.050 & .534 lift
Stand behind your word
Re: Valve spring recommendations [Re: Dodge] #2574265
11/05/18 04:36 AM
11/05/18 04:36 AM
Cab_Burge Online work
Cab_Burge  Online Work
If you have access to a valve spring tester then I would shoot for between 140 to 160 Lbs. on the seats and from 325 to 360 lbs. opened on a flat tappet or hydraulic flat tappet cam and lifters and at least have .060 to coil bind on all 16 springs. I shoot for + or - 5Lbs. on the seats, IE 140 to 150 lbs. on all 16 and use shims to get those results up
Make sure on your coil bind clearances, it is far better to have .150 from coil bind at full open than to have .050 from coil bind at max lift tsk twocents
the last set of stock iron heads I set up for a local customer I had to grind some of his darn dampeners to get .060+ from coil bind on a mild hydraulic cam with .545 projected net lift, I told him to use a set of solid lifters with soft checking springs on all 16 valves and make sure and measure the net lift at the retainers to insure he wasn't within .060 from coil bind on all 16 springs scope wrench
A iron block with iron heads will see a small net gain in lift once it is warmed up or running at or above 160 F scope shruggy
Re: Valve spring recommendations [Re: Dodge] #2574288
11/05/18 10:12 AM
11/05/18 10:12 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
an edelbrock spring will work fine. what won't work fine is the valve guide boss height (especially with aftermarket retainers which the edelbrock spring will need). the boss will need to be trimmed.
Re: Valve spring recommendations [Re: Dodge] #2574299
11/05/18 11:09 AM
11/05/18 11:09 AM
gregsdart Offline
gregsdart  Offline
Springs are one of those items that can make or break a combination because of quality. Cheap springs with the same specs as a quality spring are just that, and may not do the job well. If it were my project i would call PAC and get a recomendation for your cam. Spend a couple more$$ and you will sleep well.
Re: Valve spring recommendations [Re: gregsdart] #2574307
11/05/18 11:35 AM
11/05/18 11:35 AM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Thanks everyone. I was looking at comp 911-16 before I asked.
Re: Valve spring recommendations [Re: Dodge] #2574344
11/05/18 12:47 PM
11/05/18 12:47 PM
crabman173
crabman173
911 maybe but 924-16 better IMO It is a double that requires guide be topped for seals etc
911-16 is great spring and will work if installed at correct height but our rule of thumb puts your cam choice with a 924-16
Hope this helps
Re: Valve spring recommendations [Re: ] #2574349
11/05/18 12:56 PM
11/05/18 12:56 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
I tried to search what i needed. Im glad i asked you guys. Thanks for the help.
Re: Valve spring recommendations [Re: ] #2574398
11/05/18 02:25 PM
11/05/18 02:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Hope this helps
i'd use a 924 before a 911. 911 is very aggressive but comp doesn't seem to recommend it for higher lift cams. I don't use 911's anymore.
Re: Valve spring recommendations [Re: Dodge] #2574408
11/05/18 02:37 PM
11/05/18 02:37 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
IIRC engle recommended their 833 springs for that lobe which are similar to the edelbrock. engle did have an 835 spring which is basically a long 833. I think the 835 type spring is what hugh's used when they were selling this engle cam. the 835 will give more seat pressure at 1.90 but I don't think those engles need 140lbs on the seat. those engles are different in respect to comp cams counterparts. they aren't as aggressive and don't have a lot of nose radius like the comps. the 30/38 I have measured 284@.006", 231@.050", 148@.200" for the intake and 291@.006", 237@.050", 152@.200" for the exhaust. a higher ratio rocker other than 1.5 will need a little more spring. I don't use big springs on the engle's I run.
Re: Valve spring recommendations [Re: Dodge] #2574414
11/05/18 02:48 PM
11/05/18 02:48 PM
gregsdart Offline
gregsdart  Offline
Forgot to mention that there are some big advantages to Beehive springs if you can find one that fits your application. I have them on a 408 with a hydraulic roller and dyno testing has proven the combo good to 6500 rpm.
Re: Valve spring recommendations [Re: Cab_Burge] #2574437
11/05/18 03:26 PM
11/05/18 03:26 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Cab, you've been racing almost as long as I've been alive so I will defer to your experience whistling
But isn't that a lot of seat pressure for a flat-tappet, at least when considering long-term wear? I seem to recall reading that lobe (or lifter) wear starts to become a problem at about 150# work
Re: Valve spring recommendations [Re: DrCharles] #2574443
11/05/18 03:31 PM
11/05/18 03:31 PM
Have you ever seen or heard of a cam that wore the heel off from to much spring pressure? grin I haven't work You don't want the lifter to loose contact with the lobes as it closes, or jump around when the lobe starts to open the valves, correct work up
What I have learned is if you don't try something different to go faster or make parts last longer you won't learn or get better or worst whistling
AKA aside, there are many myths in our industry that get repeated over and over, they are not all correct shruggy
Re: Valve spring recommendations [Re: Dodge] #2574473
11/05/18 04:24 PM
11/05/18 04:24 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Good to know, thanks! I'm always learning. What IS the limiting factor for flat-tappet spring pressures then... rocker strength? Side loading? Pushrod deflection? shruggy
Any thoughts on my 451's slightly reground Mini-Express mushroom? It is now 272 @ .050, .652 gross lift with 1.5 rockers, .014/.018 lash now recommended by the grinder. I have Comp 953 springs at approx. 140# seat, 430# over the nose. Just now getting the car on the road (mostly paint jail) so I have not yet wound it up tight. I don't plan to wind it above 6900. Do you think I might need more spring pressure than that? work
Re: Valve spring recommendations [Re: DrCharles] #2574486
11/05/18 05:12 PM
11/05/18 05:12 PM
Washington
madscientist Offline
Washington
Over the nose load is what kills flat lifter cams. Seat load doesn't really matter. If I could get 370 on the seat and 370 over the nose I'd be thrilled. But AFAIK that's an impossible dream.
The reason you have to keep the seat load down is because if you don't, the over the nose load gets too high. It's called spring rate and it nails you every time.
In my case, with an installed height of 1.700 and gross lift of .620 I needed a spring that is 150 on the seat to get 400 over the nose. Only Crane and Doug Herbert had a spring.
It sucks when the installed night is so short, but it's also not good to have a tall installed height and no lift. The spring isn't close enough to coil bind.
Re: Valve spring recommendations [Re: Dodge] #2574554
11/05/18 07:49 PM
11/05/18 07:49 PM
AndyF Offline
AndyF  Offline
I have some Comp 939 springs for sale in the race section that should work. The 939 is good spring for a modest flat tappet cam.
