Valve spring recommendations
#2574244
11/05/18 02:26 AM
11/05/18 02:26 AM
Posts: 777 Washougal,Wa
Dodge
Washougal,Wa
452 heads with this cam, thanks Engel K58 is 230*@.050 & .520 lift K60 is 238*@.050 & .534 lift
Stand behind your word
Re: Valve spring recommendations
[Re: Dodge]
#2574265
11/05/18 04:36 AM
11/05/18 04:36 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
[Re: Dodge]
#2574299
11/05/18 11:09 AM
11/05/18 11:09 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Springs are one of those items that can make or break a combination because of quality. Cheap springs with the same specs as a quality spring are just that, and may not do the job well. If it were my project i would call PAC and get a recomendation for your cam. Spend a couple more$$ and you will sleep well.
[Re: gregsdart]
#2574307
11/05/18 11:35 AM
11/05/18 11:35 AM
Dodge
Washougal,Wa
Thanks everyone. I was looking at comp 911-16 before I asked.
[Re: Dodge]
#2574344
11/05/18 12:47 PM
11/05/18 12:47 PM
crabman173
crabman173
911 maybe but 924-16 better IMO It is a double that requires guide be topped for seals etc 911-16 is great spring and will work if installed at correct height but our rule of thumb puts your cam choice with a 924-16 Hope this helps
[Re: ]
#2574349
11/05/18 12:56 PM
11/05/18 12:56 PM
Dodge
Washougal,Wa
I tried to search what i needed. Im glad i asked you guys. Thanks for the help.
[Re: ]
#2574398
11/05/18 02:25 PM
11/05/18 02:25 PM
Posts: 3,916 usa
lewtot184
usa
911 maybe but 924-16 better IMO It is a double that requires guide be topped for seals etc 911-16 is great spring and will work if installed at correct height but our rule of thumb puts your cam choice with a 924-16 Hope this helps i'd use a 924 before a 911. 911 is very aggressive but comp doesn't seem to recommend it for higher lift cams. I don't use 911's anymore.
[Re: Dodge]
#2574414
11/05/18 02:48 PM
11/05/18 02:48 PM
gregsdart
Forgot to mention that there are some big advantages to Beehive springs if you can find one that fits your application. I have them on a 408 with a hydraulic roller and dyno testing has proven the combo good to 6500 rpm.
[Re: DrCharles]
#2574443
11/05/18 03:31 PM
11/05/18 03:31 PM
Cab_Burge
I would shoot for between 140 to 160 Lbs. on the seats and from 325 to 360 lbs. opened on a flat tappet or hydraulic flat tappet cam Cab, you've been racing almost as long as I've been alive so I will defer to your experience But isn't that a lot of seat pressure for a flat-tappet, at least when considering long-term wear? I seem to recall reading that lobe (or lifter) wear starts to become a problem at about 150# Have you ever seen or heard of a cam that wore the heel off from to much spring pressure? I haven't You don't want the lifter to loose contact with the lobes as it closes, or jump around when the lobe starts to open the valves, correct What I have learned is if you don't try something different to go faster or make parts last longer you won't learn or get better or worst AKA aside, there are many myths in our industry that get repeated over and over, they are not all correct
[Re: DrCharles]
#2574486
11/05/18 05:12 PM
11/05/18 05:12 PM
Posts: 4,457 Washington
madscientist
Washington
Good to know, thanks! I'm always learning. What IS the limiting factor for flat-tappet spring pressures then... rocker strength? Side loading? Pushrod deflection? Any thoughts on my 451's slightly reground Mini-Express mushroom? It is now 272 @ .050, .652 gross lift with 1.5 rockers, .014/.018 lash now recommended by the grinder. I have Comp 953 springs at approx. 140# seat, 430# over the nose. Just now getting the car on the road (mostly paint jail) so I have not yet wound it up tight. I don't plan to wind it above 6900. Do you think I might need more spring pressure than that? Over the nose load is what kills flat lifter cams. Seat load doesn't really matter. If I could get 370 on the seat and 370 over the nose I'd be thrilled. But AFAIK that's an impossible dream. The reason you have to keep the seat load down is because if you don't, the over the nose load gets too high. It's called spring rate and it nails you every time. In my case, with an installed height of 1.700 and gross lift of .620 I needed a spring that is 150 on the seat to get 400 over the nose. Only Crane and Doug Herbert had a spring. It sucks when the installed night is so short, but it's also not good to have a tall installed height and no lift. The spring isn't close enough to coil bind.
