lost truck key 2001 ram please hellllllp #2573325
11/03/18 04:00 AM
11/03/18 04:00 AM
Southern CA
Colin Frolick Offline OP
Southern CA
lost my key so I got a new ignition lock cylinder for $20, but to remove the old one...
you need the key to turn the switch to to press the retaining pin in.
so i am dead in the water / any help you can offer i'm grateful for. Cheers
trying to upload a photo...
Re: lost truck key 2001 ram please hellllllp [Re: Colin Frolick] #2573327
11/03/18 04:25 AM
11/03/18 04:25 AM
Southern CA
Southern CA
pic
Re: lost truck key 2001 ram please hellllllp [Re: Colin Frolick] #2573354
11/03/18 10:30 AM
11/03/18 10:30 AM
Guitar Jones Offline
You should be able to take the VIN, your registration and ID to a dealer and they can cut a key for the original lock cylinder. Or call a locksmith.
Re: lost truck key 2001 ram please hellllllp [Re: Guitar Jones] #2573558
11/03/18 07:14 PM
11/03/18 07:14 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
or a new ignition switch!
Re: lost truck key 2001 ram please hellllllp [Re: Colin Frolick] #2573725
11/04/18 02:02 AM
11/04/18 02:02 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I agree with the dealer option. Cheap and keeps all your locks the same. Return the new lock cylinder and get your money back.
Re: lost truck key 2001 ram please hellllllp [Re: stumpy] #2577006
11/11/18 03:00 AM
11/11/18 03:00 AM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Remove the lock cylinder from the door and take it to a locksmith he should be able to make a key from that.
Re: lost truck key 2001 ram please hellllllp [Re: RalleyA12] #2578905
11/15/18 08:30 PM
11/15/18 08:30 PM
Southern CA
Southern CA
ok to follow up i drilled and broke the old tumbler out and put the new one in. my beater farm truck so maybe i'll disable the door locks and just leave the new key in the ignition ;-) thanks for all the replies
