fyi- NGK plug lengths #2573273
11/02/18 11:29 PM
11/02/18 11:29 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Hi folks,
Was helping get a friends race boat ready for finals and in looking at plugs, we noticed some had been "kissed" by piston domes- first thought was rod bearings as once we saw one, we pulled the plug across from it- same crank journal , sure enough, it was kissed as well on the base/bottom of thread .
Started pulling the rest of the plugs- 4 plugs kissed, others were not across frpm each other- not likely to have lost that many rod bearing with engine good on oil- no noise.
So, I mic'ed the plugs thread length- the four that had kissed pistons were longer- to varying degrees- all the same number NGK race plugs.
Pulled a new box out- these were all closer, but not exact and none as long as the loner ones we had pulled out.
So : FYI, don't trust em- mic em.
Just sayin
Re: fyi- NGK plug lengths [Re: RustyM] #2573288
11/03/18 12:22 AM
11/03/18 12:22 AM
Thanks for the heads up up
What type of motor was this problem occurring in?
Re: fyi- NGK plug lengths [Re: RustyM] #2573304
11/03/18 01:35 AM
11/03/18 01:35 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Maybe counterfeit parts ? NGK is a very good product , thanks for the info.CLICK LINK [video:youtube]https://youtu.be/2F9Cs-Bd8-U[/video]
Re: fyi- NGK plug lengths [Re: RustyM] #2573427
11/03/18 01:05 PM
11/03/18 01:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep I check and ohm every plug on everything.......... thumbs
Re: fyi- NGK plug lengths [Re: Cab_Burge] #2573456
11/03/18 02:21 PM
11/03/18 02:21 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
540 chevy/ afr heads- 8 second index race boat- 1/4 mile
Re: fyi- NGK plug lengths [Re: CSK] #2573458
11/03/18 02:23 PM
11/03/18 02:23 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
folks around here are reporting serious issues with consistency on NGK plugs.
Make sure you measure resistance as Dom suggested.
No, these are not counterfeits.
QC seems to be a current issue .
fyi
Re: fyi- NGK plug lengths [Re: RustyM] #2573687
11/04/18 12:30 AM
11/04/18 12:30 AM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
Are you indexing your plugs? I have to index my plugs or some have been re gapped for me!
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: fyi- NGK plug lengths [Re: RustyM] #2573799
11/04/18 11:18 AM
11/04/18 11:18 AM
PA
moparacer Offline
moparacer  Offline
PA
Speaking of NGK, I had a set of 7 heat range plugs show up in 8 boxes recently too.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: fyi- NGK plug lengths [Re: 69Mcode440] #2574070
11/04/18 08:47 PM
11/04/18 08:47 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
yes, we generally index on race engines.
Ones on that chebby- couple were "bumped" with index rings on them.
Perhaps all plugs vary a little in lengths and we just never realized it before?
who knows.
I will be checking lengths from now on for any engine with domes in it for sure.
